Narrowed my choices: Now need the help of the gurus - AVS Forum | Home Theater Discussions And Reviews
 29Likes
post #1 of 35 Old 10-24-2019, 02:46 PM - Thread Starter
bamajas13's Avatar
Quoted: 50 Post(s)
Liked: 24
So I have narrowed down my choices of new home theater music speakers to either the Polk LSI series(707 as mains) or the Emotiva T2+ with the C2 center, E2's for side surrounds and the A1's for height speakers. I will be running a Dennon AVR 930H. They will be placed in a large room with the seating position against the rear wall. Thank you for the help/suggestions on this. I am not able to audition nthese in person which is a real bummer.
bamajas13 is offline
post #2 of 35 Old 10-25-2019, 02:15 PM
gajCA's Avatar
Quoted: 9349 Post(s)
Liked: 6440
On looks alone I'd go with the Polks as both have been deemed excellent speakers on AVS.
The Emotiva T1 measured quite well when tested by Sound & Vision and the LSiM 703 measured almost perfectly when measured by Soundstage.
Lp85253 and Vikram Iyengar like this.
Geoff A. J., California
gajCA is offline
post #3 of 35 Old 10-25-2019, 02:32 PM
Kini62's Avatar
Quoted: 2757 Post(s)
Liked: 2602
Looks wise the Polks are in a different universe with real wood veneer etc.. Performance wise only you would be able to make that choice.
The Emotiva towers are a 4 ohm load which with your AVR and no sub it's probably a no go if you want to listen at anything beyond average volume.
The Polks are rated as 8 ohm but are a little less sensitive. I think you have to go with the Polks unless your willing to change out your AVR or add an external amp if that AVR has preouts for the L/R/C.
Lp85253 likes this.
Def Tech SC8000
Onkyo RZ820
Roku Ultra, Apple TV, Sharp 70" Quattron
Kini62 is offline
post #4 of 35 Old 10-25-2019, 02:39 PM - Thread Starter
bamajas13's Avatar
Quoted: 50 Post(s)
Liked: 24
No doubt the Polk’s look amazing. I’m really close to grabbing these. Will 100 watts drive the Polk’s decent enough?
post #5 of 35 Old 10-25-2019, 02:41 PM
zieglj01's Avatar
Quoted: 3287 Post(s)
Liked: 3182
Well sometimes audio decisions are tough, I do not know if we should feel bad for you or not. ... but for looks, the Polk ... now if you can not decide, then maybe flip a quarter. But you did good with narrowing it down to 2 choices
Lp85253 likes this.
Who AM I
zieglj01 is online now
post #6 of 35 Old 10-25-2019, 02:57 PM - Thread Starter
bamajas13's Avatar
Quoted: 50 Post(s)
Liked: 24
Yeah I thought I was doing pretty good too. So many choices out there.
Lp85253 likes this.
post #7 of 35 Old 10-25-2019, 02:59 PM
Quoted: 1073 Post(s)
Liked: 601
Depending on how loud you want it and how far away you sit 100 watts should be ok. Its amazing how little power you normally use to power a speaker at say normal non reference level.
liffie420 is offline
post #8 of 35 Old 10-25-2019, 03:12 PM
Quoted: 548 Post(s)
Liked: 50
Do you have a link to the soundstage Polk LSiM 703 measurement or review?
Vikram Iyengar is offline
post #9 of 35 Old 10-25-2019, 03:18 PM
zieglj01's Avatar
Liked: 3182
Sterepohile
https://www.stereophile.com/content/...r-measurements
SoundStage
https://www.soundstagenetwork.com/in...ents&Itemid=18
Who AM I
post #10 of 35 Old 10-25-2019, 03:25 PM
Quoted: 2187 Post(s)
Liked: 1835
just a thought, drop the emo's off the list and put the ascend sierra 1's on the list .. easy to drive and pretty good fr. response...
Ryan Statz and psuKinger like this.
YAMAHA TSR 5790.. front l/r Dennis Murphy modded emotiva b1's ..BIC v1220.....Emotiva basx10.... infinity alpha 20 center.. polk t15 rears..samsung 55" j620d
bedroom .. YAMAHA r-xv 383... front l/r.. ascend cbm 170 se... kef q100 center ... Emotiva basx8... samsung ku6300 50 in
Lp85253 is online now
post #11 of 35 Old 10-25-2019, 03:53 PM
Quoted: 548 Post(s)
Liked: 50
Great measurements but as the reviewer says treble may be a little forward. I'm sure 99% of listeners will not hear it, being such a great product.
post #12 of 35 Old 10-26-2019, 06:47 AM
m0j0's Avatar
Quoted: 747 Post(s)
Liked: 810
Yes and no. If you are able to dedicate 100-125 watts each to them, they will sound great! However, if you are using only an AVR and if you are powering a lot of other speakers (such as a 5.x.4 setup) then the available watts per channel is going to go down and these speakers really sound their best when they have a good amount of dedicated power. I would recommend a dedicated amplifier to power them. That's what I did with my LSiM 705's and the difference is really noticeable.
m0j0 is online now
post #13 of 35 Old 10-26-2019, 09:54 AM - Thread Starter
bamajas13's Avatar
Quoted: 50 Post(s)
Liked: 24
I will need to see if my receiver has outputs for an additional amplifier if I go this route.
post #14 of 35 Old 10-26-2019, 10:01 AM
Liked: 1835
i think you may be getting ahead of yourself a bit: imo, no need to worry about the polks (especially the 703's) being hard to drive.. there is a *lot* of "audiophile angst" that gets folks to dive deeeeep into the rabbit hole.. the polks are 8 ohm, they may be a *bit* harder to drive than some other 8 ohm speakers but any avr will drive them to moderate/ high levels without issue ..get speakers you like *first* then worry about "amp upgrades".. this of course is all opinion , others will disagree, but i'm just trying to save you some coin...
psuKinger likes this.
post #15 of 35 Old 10-26-2019, 10:05 AM - Thread Starter
bamajas13's Avatar
Quoted: 50 Post(s)
Liked: 24
Thank you for that. My receiver doesn’t have the outputs anyways. And I think I’m just going to go ahead and get the Polk’s and Try them out with what I have. If I don’t like it then I will look into more power.
head_unit, Lp85253 and WOKNROX like this.
post #16 of 35 Old 10-26-2019, 11:12 AM
gajCA's Avatar
Liked: 6440
Here's the actual written Soundstage review:
Conclusions
It’s reassuring to buy a pair of loudspeakers designed and built by a company as large and well-established, and with as diversified a product line, as Polk Audio’s -- but the speakers still have to deliver. With the LSiM703, Polk has rediscovered their audiophile roots. Not only does it sound very good; it’s also well built, its curved cabinet is attractive in its real-wood veneer, and it’s available at a reasonable price for all that it offers. If you’re in the market for a high-quality, full-size bookshelf loudspeaker, the Polk LSiM703 deserves your consideration.
https://www.soundstagehifi.com/index...3-loudspeakers
m0j0 and Ryan Statz like this.
gajCA is offline
post #17 of 35 Old 10-26-2019, 12:14 PM
Ryan Statz's Avatar
Quoted: 588 Post(s)
Liked: 337
I think that's the right choice. For the price they're being offered at right now, you really can't go wrong.
Lp85253 likes this.
Home Theatre: Onkyo TX-NR747 | Polk Audio RTi A3 Front L/R | Polk Audio CSi A6 Centre | Polk Audio RTi A1 Surround L/R | HSU ULS-15 MK2 Subwoofer | Sony XBR55X900E | PlayStation 4 Pro | Xbox One S
Music: Cambridge Audio AXR100 | Stanton T.62 | Cambridge Audio AXC35 | KEF Q150 L/R | Elac S10EQ Subwoofer
Ryan Statz is online now
post #18 of 35 Old 10-26-2019, 03:31 PM
zieglj01's Avatar
Liked: 3182
For the most part they stay between 4 and 7 ohms -- as stated start with what you have, then make a decision
Lp85253 likes this.
Who AM I
post #19 of 35 Old 10-26-2019, 05:49 PM
WOKNROX's Avatar
Quoted: 408 Post(s)
Liked: 339
I've been following along with this thread and was under the impression that the OP is interested in the LSIM707's.... when did it switch to the 703's....?
Orotund Desert Theater:14'x20'x10',100amp service, JVC RS620, 120" AT screen, Carada Masquerade Masking, OPPO-203 & Panny ub820, Anthem AVM60, Simaudio Moon Titan 7&5 channel amplifiers, ACInfinity Fans, L&R Polk SDA SRStl Fully built, CC 2 Polk RTA15tl in Custom Cabinets Fully build, SS-BS Triad Gold, 4 Atmos 3 way Core5's, Subs-1 Rythmik FV25HP & 4 HSU VTF-MK5-HP, 2 Rows of 3 Seatcraft Excalibur Lx Seats and more.
WOKNROX is offline
post #20 of 35 Old 10-26-2019, 06:53 PM
zieglj01's Avatar
Liked: 3182
Your right -- the OP was looking at the 707 -- another person asked about the 703 bookshelf, since he is interested in bookshelf speakers, and even I got off course -- the OP seems to want towers in his room and is looking at the 707
Lp85253 likes this.
Who AM I
post #21 of 35 Old 10-26-2019, 07:09 PM
JonfromCB's Avatar
Quoted: 236 Post(s)
Liked: 165
So much for Guru's. Wisdom says get them side-by-side and let YOUR ears decide.
vavan likes this.
JonfromCB is online now
post #22 of 35 Old 10-26-2019, 07:14 PM
Zorba922's Avatar
Quoted: 7434 Post(s)
Liked: 5675
I'd get the Polks for L/R but the C2 for your center...the towers are more visible/noticeable so the handsomer Polks will impress, whereas there's just one of the C2 and I'd trust it over the Polk center. (Just ignore the TMP, lol.)
vavan likes this.
~ Are you a "geek hobbyist" obsessed with squeezing out that last 5-10% improvement? The economy will thank you...especially the Chinese one. Or are you more of a get-set-and-forget "casual user" who simply wants to increase your enjoyment of movies, TV and gaming? Relax, HT isn't rocket science, nor does it have to cost an arm and a leg---especially if you ignore the aforementioned vocal minority. And remember to smile...it's just a silly hobby, after all. :)
Zorba922 is offline
post #23 of 35 Old 10-26-2019, 10:51 PM - Thread Starter
bamajas13's Avatar
Quoted: 50 Post(s)
Liked: 24
Yes I am looking at the 707 towers. They will be in a large room and not sure the bookshelves will cut it. I don’t have the opportunity to hear them so this is why I was asking for your opinions. Also I always thought the LCR should be of the same brand to timbre match.
Lp85253 likes this.
post #24 of 35 Old 10-26-2019, 11:17 PM
WOKNROX's Avatar
Quoted: 408 Post(s)
Liked: 339
If you're interested in the 707's then I'd just stick with the 706c for the matching mid and tweeter..
Lp85253 likes this.
WOKNROX is offline
post #25 of 35 Old 10-26-2019, 11:48 PM
Liked: 1835
timbre matching is a nice luxury .. how much you want to worry about it directly corresponds with how much you value "perfect panning " across the front stage .. i don't value it as much as others do.. i pretty much worry about 2.1 music .. but if ht is the thing that you want to concentrate on timbre matching can be valuable...
post #26 of 35 Old 10-27-2019, 12:00 AM
WOKNROX's Avatar
Quoted: 408 Post(s)
Liked: 339
What you are saying here is very contradicting..
Even if you're mainly concerned with 2.1 why not get the matching cc speaker (if possible) so you can have a good match for HT....?
The OP has this luxury with the Polk Lsmi's and should be advised to take advantage of it...
WOKNROX is offline
post #27 of 35 Old 10-27-2019, 12:43 AM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 1851
"For compatibility with the widest range of loudspeakers the AVR-S930H is equipped with low impedance drive capability that provides operational stability with 4 ohm speakers."
HT: Samsung PN64H5000 (recommended settings) | NAD T758 V3 | Buchardt S400 (2) | Polk LSiM 702 F/X (2) | Infinity RS152 (4) | Subs TBD (2)
PC: Micca OriGen G2 | Mackie MR624 (2)
Soulburner is offline
post #28 of 35 Old 10-27-2019, 05:01 AM
Liked: 1835
it's not contradictory at all.. i value 2.1 music , i don't really care about timbre matching a center.. i *did* say having a matching front is a nice luxury.. were is the contradiction? if the op wants matching fronts , he should get matching fronts, if his main goal is 2.0/2.1 music it's not as important.. i can see people disagreeing , but as far as contradictory .. na , not even close..
zieglj01 likes this.
post #29 of 35 Old 10-27-2019, 11:05 AM
Zorba922's Avatar
Liked: 5675
Nah, that's just a very persistent old wives' tale, pushed by salesmen and self-identified "audiophiles" trying to demonstrate their golden eardrums.
The only true "timbre matched" front stage would be 3 identical speakers vertically aligned, as in the photo below.
Name:	AT screen with 3 towers behind.jpg
Lp85253 likes this.
Zorba922 is offline
post #30 of 35 Old 10-27-2019, 11:21 AM
psuKinger's Avatar
Quoted: 1626 Post(s)
Liked: 715
*insert obligatory "it can't be ideal to push those speakers that far up against the back wall" post here*
Speakers are so much fun... I love 'em.... but there is an awful lot of Darned-if-ya-do darned-if-ya-don't to them in terms of optimization and competing priorities.....
Zorba922 and Lp85253 like this.
Living Room: Sony x940E; Denon x4400h; Ascend Sierra RAAL Tower L/R's and 2EX center, Ascend HTM-200SE Rears, Rythmik F25 sub. NVidia Shield, ATV4k, OPPO UDP-203, CCA.
Basement: Samsung PN58B650 LN-T4065F (x2); Onkyo TX-NR809; Polk Monitor 70 Series II L/R's, SVS PB-1000 sub. NVidia Shield (x2), Windows Desktop, CCA.
psuKinger is online now
Reply Speakers
