advise - AVS Forum | Home Theater Discussions And Reviews
 6Likes
  • 1 Post By gajCA
  • 1 Post By cocrh
  • 1 Post By cocrh
  • 1 Post By Zorba922
  • 1 Post By gajCA
  • 1 Post By cocrh
post #1 of 23 Old 11-11-2019, 10:42 AM - Thread Starter
Noel25's Avatar
Liked: 1
advise
Need advise please planning to set up a bookshelf speakers and a receiver for a budget of $1000. I’ll attach this to my 4k tv and 4k blu ray player i use my 4k blu ray in watching Netflix and CD listening im just a beginner in speakers. right now im using a soundbar but not really impressed with the sound quality. Whats the brand please for bookshelf speakers and receiver with good sound quality. Thanks a lot
Noel25 is offline
post #2 of 23 Old 11-11-2019, 10:46 AM
gajCA's Avatar
Quoted: 9382 Post(s)
Liked: 6462
Are you in the US?
If so where are you located in case there is a great manufacturer or vendor near you?
Stereo receiver or 5.1 receiver?
Vikram Iyengar likes this.
Geoff A. J., California
gajCA is online now
post #3 of 23 Old 11-11-2019, 11:30 AM - Thread Starter
Noel25's Avatar
Liked: 1
Yes im here in California
Noel25 is offline
post #4 of 23 Old 11-11-2019, 11:52 AM
RayGuy's Avatar
Quoted: 2980 Post(s)
Liked: 2749
There are hundreds of options and you need to pare them down for us to recommend any to you. For instance:
- Size and shape parameters? Thin or narrow, or the usual bookshelf shape? Any particular finish requirements?
- Mounted on stands, on furniture, on wall, attached to TV wall bracket?
- How far away do you sit? How loud do you listen?
- Will you be using a subwoofer or just the speakers alone?
- Two speakers, or more?
- Have you done any listening sessions? Is there a specific sound signature you like/dislike?
That will help narrow the field a bit ...
It's a VIRTUAL channel unless stated otherwise.
RayGuy is offline
post #5 of 23 Old 11-11-2019, 12:45 PM
Quoted: 534 Post(s)
Liked: 473
Crutchdfield has the Denon's on sale. The X3500H has the better room correction software XT32 Audyssey but of course is the most expensive. If your are just doing 2 bookshelf speakers you probably don't need that high end of a receiver. .
X1500H
https://www.crutchfield.com/p_033AVX...0H.html?tp=179
X2500H
X3500H
Best Buy has some deals on speakers. You might want to bring a few pairs home and try them. Return the ones you don't like.
Sony Core 3 way
https://www.bestbuy.com/site/sony-co...acampID=614286
KEF Q150
https://www.bestbuy.com/site/kef-q-s...?skuId=5913623
https://www.bestbuy.com/site/kef-q-s...?skuId=6379830
Elac Debut 2.0
https://www.bestbuy.com/site/elac-de...?skuId=6198593
cocrh is online now
post #6 of 23 Old 11-11-2019, 12:45 PM - Thread Starter
Noel25's Avatar
Liked: 1
Thanks for the reply ill put this on my living room apartment regular size apartment, yes ill use the stand and ill just used the speakers without sub I don’t have any listening speakers option yet! Any suggestions please! Thanks
Noel25 is offline
post #7 of 23 Old 11-11-2019, 12:50 PM
Quoted: 534 Post(s)
Liked: 473
Without a sub the ELAC I mentioned at Best Buy would give you better low end then the KEF or Sony but would be good to try them in your own home.
Oh and if you wait a few weeks the ELAC's might go down to 150 a pair like they did last year.
cocrh is online now
post #8 of 23 Old 11-11-2019, 01:02 PM
Zorba922's Avatar
Quoted: 7474 Post(s)
Liked: 5697
Where in CA? If anywhere near LA, you are within driving distance of Ascend and Hsu headquarters where you could go listen. They're among the best internet-direct speaker makers around.
With a $1K budget you can get a pair of bookshelf speakers, a receiver, and a subwoofer too. If this is a music only system, the sub might be unnecessary but for HT it's essential unless you don't really watch action/thriller movies.
~ Are you a "geek hobbyist" obsessed with squeezing out that last 5-10% improvement? The economy will thank you...especially the Chinese one. Or are you more of a get-set-and-forget "casual user" who simply wants to increase your enjoyment of movies, TV and gaming? Relax, HT isn't rocket science, nor does it have to cost an arm and a leg---especially if you ignore the aforementioned vocal minority. And remember to smile...it's just a silly hobby, after all. :)
Zorba922 is offline
post #9 of 23 Old 11-11-2019, 01:07 PM - Thread Starter
Noel25's Avatar
Liked: 1
Thanks a lot! Appreciate
Noel25 is offline
post #10 of 23 Old 11-11-2019, 02:08 PM
zieglj01's Avatar
Quoted: 3294 Post(s)
Liked: 3190
You want some good bass, and some good mids, and some good highs -- this is my clear preference ... the DCM TFE60, they are on clearance pricing and use to list for $500 a pair when they first came out -- and the seller is a good one
https://www.ebay.com/itm/2-DCM-by-MT...B/193087808575
Who AM I
zieglj01 is online now
post #11 of 23 Old 11-11-2019, 03:00 PM
gajCA's Avatar
Liked: 6462
HSU and Ascend are in Southern California, NHT is in Northern California.
All make solid speakers so if you can visit and audition that would be ideal.
Call before visiting to make an appointment.
HSU research: 985 N Shepard St, Anaheim, CA 92806 (714) 666-9260
http://www.hsuresearch.com/products/ccb-8.html
http://www.hsuresearch.com/products/hb-1.html
Ascend Acoustics: 1062 Calle Negocio G, San Clemente, CA 92673 (949) 366-1455
http://www.ascendacoustics.com/pages...m/cmt340m.html
http://www.ascendacoustics.com/pages...70/cbm170.html
NHT: 1057, 533 Stone Rd suite b, Benicia, CA 94510 (707) 747-0122
https://www.amazon.com/NHT-Bookshelf.../dp/B019PZ96RS
Receiver:
https://www.crutchfield.com/p_022RN3...ha-R-N303.html
azada likes this.
gajCA is online now
post #12 of 23 Old 11-11-2019, 04:58 PM - Thread Starter
Noel25's Avatar
Liked: 1
Thanks a lot guys
Noel25 is offline
post #13 of 23 Old 11-11-2019, 11:35 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 1861
If you plan on not using a receiver, then you want active speakers with an optical input and a remote.
Recommend the Swans M300: https://www.amazon.com/Swan-Speakers.../dp/B07C1TVLDX
Otherwise, I really like the Denon 3400 and 3500 for an AV receiver. Then, there are many speaker options.
Without a subwoofer, one of the fuller-sounding speakers in your price range will be the ELAC B6.2. Also look at the JBL 530 if you can swing them (sometimes they are on sale or there is a refurb available from Harman.com)
HT: Samsung PN64H5000 (recommended settings) | NAD T758 V3 | Buchardt S400 (2) | Polk LSiM 702 F/X (2) | Infinity RS152 (4) | Subs TBD (2)
PC: Micca OriGen G2 | Mackie MR624 (2)
Soulburner is offline
post #14 of 23 Old 11-12-2019, 10:01 AM - Thread Starter
Noel25's Avatar
Liked: 1
Thanks 😊 I’ll check it sir! Appreciate
Noel25 is offline
post #15 of 23 Old 11-12-2019, 10:19 AM
pase22's Avatar
Quoted: 3474 Post(s)
Liked: 2933
If you're not planning on a sub, you should consider Emotiva T1's if you have the space. The towers will have better dynamics, more depth and deeper extension. It can't replace a sub, but will fill the gap a little.
https://emotiva.com/collections/loud...1-loudspeakers
This receiver should have everything you'll need and has good room correction.
https://www.accessories4less.com/mak...eos-new/1.html
Kef LS50,Q200C, Q100, Kef Kube 10B (X2) , Denon AVR-X3400H, NAD 216 THX, Panasonic 50" Plasma, Xbox One.
Bedroom: Kef Q100 ,JBL Loft 20, SVS SB-2000, Denon AVR-S710W, PS3, 32" Insigna LED.
pase22 is online now
post #16 of 23 Old 11-12-2019, 10:24 AM - Thread Starter
Noel25's Avatar
Liked: 1
Advise
Hi guys ask please about the triangle borea bro3 bookshelf speakers. Is this bookshelf speakers really good in sound quality!? Thanks
Noel25 is offline
post #17 of 23 Old 11-12-2019, 10:33 AM
Quoted: 1853 Post(s)
Liked: 1443
I’m going to guess that they look better than they’ll sound.
I don’t see any mention of who OEM’s their drivers. And the front baffle is not treated in any way for diffraction effects.
At $549/pr there are definitely other options.
But do give them a try if you like and let us know.
Leave it at 8 ohms and call it a day :)
Russdawg1 is online now
post #18 of 23 Old 11-12-2019, 11:06 AM
zieglj01's Avatar
Liked: 3190
They look interesting and are worth an audition
Who AM I
post #19 of 23 Old 11-12-2019, 11:14 AM - Thread Starter
Noel25's Avatar
Liked: 1
Thanks guys
Noel25 is offline
post #20 of 23 Old 11-12-2019, 11:33 AM - Thread Starter
Noel25's Avatar
Liked: 1
Sir Russdawg 1 any suggestions please at that price range i will not use sub just connect it with denon 800 h 2 channel. 4k tv and 4k blu ray player for audio listening, thanks
Noel25 is offline
post #21 of 23 Old 11-12-2019, 11:43 AM
Quoted: 534 Post(s)
Liked: 473
The Polk LSiM 703 is a very nice 3 way bookshelf speaker that will dig pretty deep in the low end without a sub. Available in Black or Cherry. $449 a pair
https://www.adorama.com/pklsim703b2....ce=rflaid62905
https://www.adorama.com/pklsm703mvc2...ce=rflaid62905
Ryan Statz likes this.
cocrh is online now
post #22 of 23 Old 11-13-2019, 11:09 AM - Thread Starter
Noel25's Avatar
Liked: 1
Noel25 is offline
post #23 of 23 Old 11-13-2019, 03:36 PM
gajCA's Avatar
Liked: 6462
$550/pair or less?
Order the very well respected Focal Chorus 706 (French) and PSB Imagine XB (Canadian) from Crutchfield.
Return the losers for free as they will take the nominal $10/box return shipping fee per box out of the rewards points for the pair you choose to keep.
You have 60 days to audition/return.
The Focals are available in two different finishes.
Nothing beats auditioning at home.
https://www.crutchfield.com/p_760IMN...magine-XB.html
https://www.crutchfield.com/p_091C70...06-Walnut.html
gajCA is online now
Reply Speakers
