Surround replacement ideas - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 11-16-2019, 04:21 PM - Thread Starter
Liked: 0
Good evening. I am looking to replace my current surround speakers with some in walls. My position is rather high, about 8' from the floor due to the walkway from the foyer into the living room. The room is 17' wide. I was thinking about using Klipsch CDT-5650-C's since I can pivot the woofer and tweeter. I am also planning on replacing my Boston VR2's with PRO-250RPW LCR's. Any other suggestions or thoughts would be great.
mstemphoski is offline
post #2 of 5 Old 11-16-2019, 06:02 PM
darthray's Avatar
Quoted: 2337 Post(s)
Liked: 3456
Since I am not a fan of any in wall speakers, I got another suggestion, how about these;
https://www.svsound.com/products/prime-elevation
They can be mounted in many different way, including ceiling mount.
Darth
darthray is offline
post #3 of 5 Old 11-16-2019, 07:04 PM - Thread Starter
Liked: 0
Darth
Thanks Darth,
I have looked at those. My wife... doesn't like the look of the speakers on the wall/floor. That being said, I am in process of building my 7.2.4 theater in the basement so I'm willing to sacrifice a little upstairs. What do you dislike about in wall speakers?
post #4 of 5 Old 11-16-2019, 07:14 PM
darthray's Avatar
Liked: 3456
Thanks Darth,
For me, everything is sound quality. Just a quick look at my Theater link, will show how obsess I am into this hobby;
The Chimaera theater
Speakers mounted on a wall, instead of in wall. Give better options for fine tuning, as angles to your MLP.
I also got a 7.2.4 system, but since you are here to learn. While not important, since I knew and others know what you meant.
I say 7.1.4 (two subs), since there is only one sound track when it come to bass in any type of recording.
While it is the proper way to say-it, many got confuse. The reason of saying 7.2.4 is so popular
Darth
darthray is offline
post #5 of 5 Old 11-16-2019, 07:39 PM
zieglj01's Avatar
Quoted: 3291 Post(s)
Liked: 3185
Angled woofer and pivoting tweeter and on clearance pricing ... DCM TFE in-ceiling speakers ... use to list for $299 each -- price is for 4 speakers
https://www.ebay.com/itm/6-5-Angled-...cAAOSwTfNco6~5
DCM TFE in-wall LCR speakers -- also clearance pricing ... price is for 2 ... use to list for $449 each
https://www.ebay.com/itm/2-Pack-6-5-...sAAOSwMkhdcVT5
Price for one
https://www.ebay.com/itm/DCM-by-MTX-...8AAOSw4lNdcVBK
Who AM I
zieglj01 is online now
Reply Speakers
