Replace center channel. JBL NSPII set - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 11-17-2019, 01:16 PM - Thread Starter
StephenZ's Avatar
Had this set since 2002 with a JB10 sub. It all still sounds great. Used for TV and movies. So my wife talked me into all new furniture and the center speaker is just too big. Have a 6” high opening. Can I use like the Sony Core 4” center and still be happy? Maybe use this as a stepping stone to replace all? I hate making this change but sometimes the wife wins. I really appreciate all responses.
StephenZ is offline
post #2 of 4 Old 11-17-2019, 02:53 PM
Quoted: 569 Post(s)
Liked: 296
With that clearance requirement, check out the RSL CG23
Main: Sony XBR75900E, Denon AVR-x4400, Denon POA-5200 (L/R(a) Goldenear supersat 60, (b)FW Boston acoustic Bravo 2. C Goldenear supersat 60C,
SSR DIYSG Volt 6v2. RSS Volt 6, Atmos(.4) Boston acoustics soundware XS
HSU research ULS -15, Episode ES-IW-Dual 8 / Monitor audio IWA 250 amp 2nd Rm: Visio E55, Denon avr730H, Boston Acoustics CR8, cr400 sub.
smithsabom is offline
post #3 of 4 Old 11-17-2019, 07:50 PM
Zorba922's Avatar
Quoted: 7414 Post(s)
Liked: 5660
The previously mentioned RSL center will be leaps and bounds better than both the Core center and your JBL center. Plus you get free return shipping just in case.
https://rslspeakers.com/products/new...enter-channel/
~ Are you a "geek hobbyist" obsessed with squeezing out that last 5-10% improvement? The economy will thank you...especially the Chinese one. Or are you more of a get-set-and-forget "casual user" who simply wants to increase your enjoyment of movies, TV and gaming? Relax, HT isn't rocket science, nor does it have to cost an arm and a leg---especially if you ignore the aforementioned vocal minority. And remember to smile...it's just a silly hobby, after all. :)
Zorba922 is offline
post #4 of 4 Old 11-18-2019, 01:13 PM - Thread Starter
StephenZ's Avatar
Reviewing the RSL Center, looks like a great choice if it will fit. I have yet to get the new furniture so need to verify it is a true 6" opening height. Is this speaker a true 6" height? Is this works, I will add two RSL book shelf speakers and use my current JBL as the surrounds for now. Then go from there. Thanks for the replies.
Note: The RSL outlet has some blemished speakers at a discount so looks like a place to start.
StephenZ is offline
Reply Speakers
