Home Theater Speakers 5.1 configuration - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 11Likes
post #31 of 32 Old 11-22-2019, 02:42 PM
Zorba922's Avatar
Quoted: 7759 Post(s)
Liked: 5878
Originally Posted by vijay chennupati View Post
Regarding the surge protector and power conditioner. Do I need a power conditioner? Can I use the tripplite surge protector ($33 one). Any recommendations here.
Tripplite is fine, that's what I've used for years. Zero issues, and they've been tripped before, did their job perfectly.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Power conditioners are in similar snake-oil territory as magical voodoo cables.
~ Are you a "geek hobbyist" obsessed with squeezing out that last 5-10% improvement? The economy will thank you...especially the Chinese one. Or are you more of a get-set-and-forget "casual user" who simply wants to increase your enjoyment of movies, TV and gaming? Relax, HT isn't rocket science, nor does it have to cost an arm and a leg---especially if you ignore the aforementioned vocal minority. And remember to smile...it's just a silly hobby, after all. :)
Zorba922 is offline
post #32 of 32 Old 11-22-2019, 02:44 PM
Zorba922's Avatar
Liked: 5878
Will compare those and if they can price match can order it.
The x1500 should be perfectly fine, saves you a couple hundred bucks you can put into more important things like the center and sub.
https://www.crutchfield.com/p_033AVX....html?skipvs=T
Zorba922 is offline
Reply Speakers
