Is this just a lateral move? - AVS Forum | Home Theater Discussions And Reviews
 7Likes
  • 3 Post By Lp85253
  • 1 Post By Darren Chan
  • 1 Post By stngray72
  • 2 Post By Soulburner
post #1 of 20 Old 11-21-2019, 03:07 PM - Thread Starter
Quoted: 140 Post(s)
Liked: 124
im thinking of getting polk lsim 705's to replace my emotiva t1's do you think these would be much of an upgrade?
stngray72 is offline
post #2 of 20 Old 11-21-2019, 03:13 PM
Quoted: 2181 Post(s)
Liked: 1830
quality wise probably next level up.. so *if* you think you *need*an upgrade than it may well be worth it, but if you can go up a couple levels it will probably save money in the long run( if you delete your avs account )...
vavan, tjcinnamon and jkozlow3 like this.
YAMAHA TSR 5790.. front l/r Dennis Murphy modded emotiva b1's ..BIC v1220.....Emotiva basx10.... infinity alpha 20 center.. polk t15 rears..samsung 55" j620d
bedroom .. YAMAHA r-xv 383... front l/r.. ascend cbm 170 se... kef q100 center ... Emotiva basx8... samsung ku6300 50 in
Lp85253 is offline
post #3 of 20 Old 11-21-2019, 03:18 PM
zieglj01's Avatar
Quoted: 3282 Post(s)
Liked: 3175
I expect them to be -- but no one can speculate for your ears
Who AM I
zieglj01 is offline
post #4 of 20 Old 11-21-2019, 03:18 PM
Class A's Avatar
Quoted: 764 Post(s)
Liked: 5068
Thumbs up
It's an upgrade if they sound better to you.
Class A is offline
post #5 of 20 Old 11-21-2019, 03:26 PM
bear123's Avatar
Quoted: 2827 Post(s)
Liked: 4306
Find good measurement data on both speakers. If they measure better, they should sound better. What is the intended use? How far do you sit from the speakers? What is the loudest you would like to ever listen?
bear123 is online now
post #6 of 20 Old 11-21-2019, 03:33 PM - Thread Starter
Quoted: 140 Post(s)
Liked: 124
I intend on using them as mains for music and some theater music i like to jam once in a while on my yamaha 870A 100 watts a channel. Im 8 to 10 feet from listening area. Im mainly looking for more upper end presence.
post #7 of 20 Old 11-21-2019, 04:06 PM - Thread Starter
Quoted: 140 Post(s)
Liked: 124
I pulled the trigger on a pair 465 with tax. I cant wait till the 705's get here.
post #8 of 20 Old 11-21-2019, 06:38 PM
zieglj01's Avatar
Liked: 3175
Cool
Who AM I
zieglj01 is offline
post #9 of 20 Old 11-21-2019, 07:36 PM
Zorba922's Avatar
Quoted: 7421 Post(s)
Liked: 5667
Only in the mid-bass department if you're comparing them in 2.0 (no sub).
For mids and highs, I'd be surprised if there was any significant upgrade unless you simply prefer stronger treble.
Will be curious to read about your impressions, though!
~ Are you a "geek hobbyist" obsessed with squeezing out that last 5-10% improvement? The economy will thank you...especially the Chinese one. Or are you more of a get-set-and-forget "casual user" who simply wants to increase your enjoyment of movies, TV and gaming? Relax, HT isn't rocket science, nor does it have to cost an arm and a leg---especially if you ignore the aforementioned vocal minority. And remember to smile...it's just a silly hobby, after all. :)
Zorba922 is offline
post #10 of 20 Old 11-22-2019, 01:14 AM
Darren Chan's Avatar
Quoted: 82 Post(s)
Are you sure you bought a pair? $465 tax in sound like the price for one 🤔
Lp85253 likes this.
Marantz SR7013, Polk Signature S60s/S30/S15s/HTS12s, Polk MC80 (x4), AC Infinity T9/S9, AAB4 HTPC,...still to come - Panasonic DP-UB820K, 82" 4K QLED or eqv.
Darren Chan is offline
post #11 of 20 Old 11-22-2019, 05:58 AM
djp2k7's Avatar
Quoted: 391 Post(s)
Liked: 315
Maybe he meant 703's? I do see a single 705 at Adorama in VG condition for $289.
ADS L710 / KEF Q150 / HIFIMAN HE400i / Martin Logan Dynamo 300
NAD 720Bee / Schiit Modi 3 / Yamaha CD-S300 / XBOX One X
djp2k7 is offline
post #12 of 20 Old 11-22-2019, 07:26 AM - Thread Starter
Quoted: 140 Post(s)
Liked: 124
yes i had to purchase twice on two different links.on fleabay...they were used though from andromeda.
Lp85253 likes this.
post #13 of 20 Old 11-22-2019, 04:16 PM
nonametofame's Avatar
Quoted: 12 Post(s)
Andromeda??
Adorama?
nonametofame is offline
post #14 of 20 Old 11-22-2019, 07:19 PM - Thread Starter
Quoted: 140 Post(s)
Liked: 124
Originally Posted by nonametofame View Post
Andromeda??
Adorama?
yes
post #15 of 20 Old 11-22-2019, 09:41 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 1845
The Polk LSiM's will give you that - the Emotivas will sound more tame by comparison.
HT: Samsung PN64H5000 (recommended settings) | NAD T758 V3 | Buchardt S400 (2) | Polk LSiM 702 F/X (2) | Infinity RS152 (4) | Subs TBD (2)
PC: Micca OriGen G2 | Mackie MR624 (2)
Soulburner is offline
post #16 of 20 Old 11-22-2019, 10:46 PM
pwiss's Avatar
Quoted: 159 Post(s)
Liked: 196
I have the T1’s and am posting the Audyssey XT32 measurements for my setup. Not REW measurements but can be used as a gauge. I also will post the 703 Stereophile measurements. Assuming the 703’s have a similar crossover to the 705’s then you will see an elevated upper treble response as I could not find measurements for the 705’s. Given the price you paid for the 705’s and if you like brighter treble then you have made a good choice. Also the Polk’s are better looking speakers if that matters.
ID:	2644392   Click image for larger version
ID:	2644394   Click image for larger version
pwiss is offline
post #17 of 20 Old 11-22-2019, 11:08 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 1845
Yes - and keep in mind that is directly on-axis. The tweeter on the LSiM line is flat at 15 degrees off-axis, and falls off rapidly starting at 7 kHz beyond 30 degrees off-axis, as seen here:
https://www.soundstagenetwork.com/in...nts&Itemid=153
This will sound different than a speaker that emits more high-frequency sound to its sides.
vavan and pwiss like this.
post #18 of 20 Old 11-22-2019, 11:20 PM
Quoted: 170 Post(s)
Liked: 27
Right, my revel f208s sound different from lsim 705 it replaced
Sent from my Mi Note 3 using Tapatalk
Parasound Halo Integrated, Pioneer SC-LX 901, Oppo-205, Revel F208 + Heco Aurora Center 30 + Heco Victa Prime 202, Takstar HF 580
vavan is online now
post #19 of 20 Old 11-22-2019, 11:25 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 1845
Originally Posted by vavan View Post
Right, revel my f208 sound different from lsim 705 it replaced
Can you describe the differences?
post #20 of 20 Old 11-22-2019, 11:34 PM
Quoted: 170 Post(s)
Liked: 27
Lsim sounded somewhat harsh and edgy for me and were quite directional while there are more spaciousness with revels. Revels may sound even more unforgivable and hard on poorly mastered material with excessive mids/highs. F208s have some built-in means to tame or raise highs though
vavan is online now
Reply Speakers
