Speakers grills - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By zieglj01
post #1 of 13 Old 11-22-2019, 07:01 AM - Thread Starter
Quoted: 165 Post(s)
Liked: 31
Speakers grills
Apologies for a lay man question
Should we just take the grills off speaker or use with them?
Newuser2018 is offline
post #2 of 13 Old 11-22-2019, 08:24 AM
CatBus's Avatar
Quoted: 37 Post(s)
Liked: 63
They're for looks, and also to protect the speakers against little peanut-butter covered fingers and pencils. You could go either way. I've got kids, so they're a necessity.
CatBus is offline
post #3 of 13 Old 11-22-2019, 08:50 AM
m0j0's Avatar
Quoted: 746 Post(s)
Liked: 796
I used to leave them on, but now I run without grilles and much prefer both the sound and the look.
m0j0 is offline
post #4 of 13 Old 11-22-2019, 08:53 AM
Quoted: 424 Post(s)
Liked: 308
most prefer to leave them off unless you need extra protection from kids and pets or WAF. I use grills for above reasons but if its just me at home then they come off
Rgarc is offline
post #5 of 13 Old 11-22-2019, 08:57 AM
zieglj01's Avatar
Quoted: 3283 Post(s)
Liked: 3180
Only a few companies voice them with the grills on -- so with that exception, a lot of us listen with the grills off
Who AM I
zieglj01 is offline
post #6 of 13 Old 11-22-2019, 09:06 AM
Zorba922's Avatar
Quoted: 7428 Post(s)
Liked: 5671
Off if you prefer the look or sound.
On if you don't, or if you have pets/kids to worry about.
~ Are you a "geek hobbyist" obsessed with squeezing out that last 5-10% improvement? The economy will thank you...especially the Chinese one. Or are you more of a get-set-and-forget "casual user" who simply wants to increase your enjoyment of movies, TV and gaming? Relax, HT isn't rocket science, nor does it have to cost an arm and a leg---especially if you ignore the aforementioned vocal minority. And remember to smile...it's just a silly hobby, after all. :)
Zorba922 is offline
post #7 of 13 Old 11-22-2019, 09:19 AM
pjp
pjp's Avatar
Quoted: 794 Post(s)
Liked: 456
Very interesting. I never gave it any thought and always assumed they typically voiced them to compensate for the grills (since "grills on" is probably the more common case, at least among the mainstream customer base). I've never done any critical listening with grills removed -- going to need to try that.
pjp is offline
post #8 of 13 Old 11-22-2019, 12:15 PM
gajCA's Avatar
Quoted: 9344 Post(s)
Liked: 6431
As I have cats I never take the chance to leave them off.
Plus I prefer the look with them on and don't notice much change if any with them on or off.
Geoff A. J., California
gajCA is offline
post #9 of 13 Old 11-23-2019, 04:39 AM
chucky7's Avatar
Quoted: 3672 Post(s)
Liked: 4865
I primarily use my HT for movies. I take the speaker grills off during use and put them back right after.
Speakers: L/C/R: JTR Noesis 212HT. Surrounds: Jamo C103, KEF Q100, Polk Audio RTiA3.
Subwoofer: JTR Captivator 4000ULF.
AVR: Denon AVR-X4400H. TV: Samsung UN75NU8000FXZA.
FS: Jamo C103, KEF Q100 and Polk RTiA3
chucky7 is offline
post #10 of 13 Old 11-23-2019, 07:01 AM
Quoted: 1040 Post(s)
Liked: 835
Off unless I won’t use that set-up for day or 2. Have 3 main set-ups and grilles off on all 3; prefer the look also but also we have no pets or little kids
Primary set-up 5.1.4; Yamaha A2050, Paired w/Parasound P5 & ATI 522NC 2 channel amp
Revel F206 fronts & Revel M16 rears; Outlaw X12 Sub & 4 RSL C34e in-ceilings
Secondary 5.1: Denon S900W, Polk LSiM703/704C, Polk RC80i in-ceiling rears, RSL Speedwoofer 10s
yanks1 is offline
post #11 of 13 Old 11-23-2019, 12:20 PM
gajCA's Avatar
Liked: 6431
See post 92 in this thread of a member who measured the RSL CG5 and CG25 with grills on and off.
https://www.avsforum.com/forum/89-sp...l#post58861966
gajCA is offline
post #12 of 13 Old 11-23-2019, 02:37 PM
Ryan Statz's Avatar
Quoted: 587 Post(s)
Liked: 337
Either or is fine. I have them on only because I have a cat that can potentially put his claws through the woofer, otherwise I would probably leave them off.
Home Theatre: Onkyo TX-NR747 | Polk Audio RTi A3 Front L/R | Polk Audio CSi A6 Centre | Polk Audio RTi A1 Surround L/R | HSU ULS-15 MK2 Subwoofer | Sony XBR55X900E | PlayStation 4 Pro | Xbox One S
Music: Cambridge Audio AXR100 | Stanton T.62 | Cambridge Audio AXC35 | KEF Q150 L/R | Elac S10EQ Subwoofer
Ryan Statz is offline
post #13 of 13 Old 11-23-2019, 03:29 PM
zieglj01's Avatar
Liked: 3180
You can not narrow it down to one set of speakers, and/or one set of speaker measurements for one speaker .... if one can not really hear much difference with their speakers, then go by preference. Sometimes it is more about the frames and not the cover material. In the end it is more about what the personal ear can pick-up, and what may or may not irritate them .... I know what I tend to hear with certain sets of speakers ... in the end cats tend to have the last word.
Ryan Statz likes this.
Who AM I
zieglj01 is offline
Reply Speakers
