Best elevation speakers for surround use - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 11-22-2019, 03:19 PM - Thread Starter
Bill97Z's Avatar
Quoted: 157 Post(s)
Liked: 40
I am planning to use elevation speakers as side and rear surrounds. I want something sleek that can be wall mounted without angling brackets, and my only option is to mount them high aiming down. These will be side and rear surrounds for a 7.1 system. I really wanted to use the klipsch rp-500SA as all my other speakers are klipsch but every review I have read claims the SVS prime elevation speakers are better for surround use (fuller range, wider frequency response, etc). I was wondering if there is anything else I can consider before I buy the SVS Prime Elevations.
Sketch of the room (red boxes are approx placement....
Bill97Z is offline
post #2 of 15 Old 11-22-2019, 04:55 PM
nonametofame's Avatar
Quoted: 13 Post(s)
https://www.amazon.com/Definitive-Te.../dp/B000V41XII
I use these large satellites for my atmos heights. They work quite well with the Pro Mount 90 bracket, so you have some flexibility in positioning.
nonametofame is offline
post #3 of 15 Old 11-23-2019, 12:06 PM
gajCA's Avatar
Quoted: 9387 Post(s)
Liked: 6468
Seems like they would be ideal for your use; wait for Holiday sales at SVS.
Geoff A. J., California
gajCA is offline
post #4 of 15 Old 11-24-2019, 06:24 PM
Liked: 0
Has anyone spent any time comparing the SVS with the Dali Alteco C-1? They seem to be targeting a similar space.
farmanz is offline
post #5 of 15 Old 11-24-2019, 11:00 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 1866
Is it not possible to mount side surrounds in their proper location (ear level)?
HT: Samsung PN64H5000 (recommended settings) | NAD T758 V3 | Buchardt S400 (2) | Polk LSiM 702 F/X (2) | Infinity RS152 (4) | Subs TBD (2)
PC: Micca OriGen G2 | Mackie MR624 (2)
Soulburner is offline
post #6 of 15 Old 11-25-2019, 01:57 PM
chemist323's Avatar
im in the same predicament, can't mount side surrounds at ear level? also looking at 4 SVS vs 4 small bookshelfs aimed downward. Looking for recommendations. The monitor audio 3 with a directional tweeter sounded like a good idea but expensive.
chemist323 is offline
post #7 of 15 Old 11-26-2019, 11:38 AM
gajCA's Avatar
Liked: 6468
3010is with wall mounts.
https://www.qacoustics.com/sale.html
https://www.qacoustics.com/3000-seri...t-bracket.html
gajCA is offline
post #8 of 15 Old 11-26-2019, 01:57 PM
chemist323's Avatar
Originally Posted by gajCA View Post
Wondering why you like these and if you'd choose these over something like the SVS elevations. thanks again
post #9 of 15 Old 11-26-2019, 08:11 PM - Thread Starter
Bill97Z's Avatar
Quoted: 157 Post(s)
Liked: 40
I am in the same boat. I really wanted to get the klipsch elevations but the SVS seem superior all around.
Bill97Z is offline
post #10 of 15 Old 11-26-2019, 08:14 PM - Thread Starter
Bill97Z's Avatar
Quoted: 157 Post(s)
Liked: 40
I could, but it would have to be something low profile wall mount. Like the Klipsch RP-240D, and I didn't think they were worth the asking price.
Bill97Z is offline
post #11 of 15 Old 11-26-2019, 08:17 PM - Thread Starter
Bill97Z's Avatar
Quoted: 157 Post(s)
Liked: 40
Seems like the black Friday sale is on the subs only
Bill97Z is offline
post #12 of 15 Old 11-26-2019, 08:18 PM - Thread Starter
Bill97Z's Avatar
Quoted: 157 Post(s)
Liked: 40
SVS seems to have better specs.....higher sensitivity, wider frequency response (lower extension)
Bill97Z is offline
post #13 of 15 Old 11-26-2019, 08:20 PM - Thread Starter
Bill97Z's Avatar
Quoted: 157 Post(s)
Liked: 40
I am wondering if I was able to find low profile wall mounts for side surrounds - mount at ear level.
Then the SVS elevations mounted high on the wall in the rear....instead of 7.1, use them as atmos....so 5.1.2. Thoughts? Or am I better off with 7.1
Bill97Z is offline
post #14 of 15 Old 11-26-2019, 08:20 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 1866
I'm using Polk LSiM 702 F/X surrounds because they are low profile yet not low power.
You'll never get around the fact that you need cabinet volume to achieve better bass output, so they are decent size in the width and height dimensions. It's gotta go somewhere
post #15 of 15 Old 11-27-2019, 08:04 AM
gajCA's Avatar
Liked: 6468
I tested my friend's Q Acoustics Concept 20s in my home and the build and sound quality was every bit as good as my Martin Logans that have a msrp nearly double that price.
While the 3010is are a lower tier to the Concepts all reports are they perform above their price point and also have first class built quality.
Half the price of the SVS with similar specs albeit the SVS come with brackets in the box while the Q Acoustics brackets are a bit extra.
gajCA is offline
Reply Speakers
