Is Atmos (front height speakers) worth doing if only 3 feet above mains? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By Legairre
post #1 of 19 Old 12-02-2019, 12:58 PM - Thread Starter
ghart999's Avatar
Quoted: 219 Post(s)
Liked: 72
My only options are to place the atmos front heights on top of my entertainment center. The height between the mains and atmos would be 36-40 inches. I would build some kind of a stand to angle the atmos down to listening position. I'm still debating on which atmos speakers. But likely a 2-way with a 4" and tweeter. As I need something small.
Thanks all.
Audio: Denon AVR-X3400H - Behringer NX6000D - miniDSP
Speakers: LCR: DIYSoundGroup Cobalt 8s | Surrounds: NHT SuperOnes | Atmos: Boston Acoustic SoundWare | Subs: Marty cube w/ Ultimax UM18 and (4) JBL CS1214s
Automation: Fire Cube - Harmony Hub- Insteon Plugs - Sensi Thermostat
Video Image: TCL 55r625 - Roku - nVidia Shield Pro 2019 - Xbox One X
ghart999 is offline
post #2 of 19 Old 12-02-2019, 01:09 PM
Legairre's Avatar
Quoted: 1261 Post(s)
Liked: 703
Thanks all.
If the Atmos speakers are above your mains and not above you then it will sound as if the atmos effects are coming from your front speakers and not overhead. Have you considered the atmos add on modules that bounce the sound off the ceiling? I know they are not idea but they would probably work better at giving you the effect of sound overhead.
"What do you mean it's too loud? My ears aren't even bleeding yet!"
Dedicated ARC Genesis Thread
Legairre is online now
post #3 of 19 Old 12-02-2019, 01:14 PM
sdurani's Avatar
Quoted: 7375 Post(s)
Liked: 6453
The front soundstage will sound slightly taller. Not worth it. Any chance of putting a pair of small speakers high up on the side walls in line with your listening position?
Sanjay
sdurani is offline
post #4 of 19 Old 12-02-2019, 01:25 PM - Thread Starter
ghart999's Avatar
Quoted: 219 Post(s)
Liked: 72
Unfortunately my ceiling slants from 14 feet at the front of the room down to 9 feet at the listening position. So any chance of getting a good reflection seems impossible to me. Plus there is a huge ceiling fan right where the reflections would need to go. Side height isn't an option because the listening position is against the back wall. So I had to mount my rears to the sides already. So the only option is front height which is 3.5 feet higher than the listening position. Ugh.
ghart999 is offline
post #5 of 19 Old 12-02-2019, 01:28 PM - Thread Starter
ghart999's Avatar
Quoted: 219 Post(s)
Liked: 72
I meant to quote you in that the Atmos would be about 3.5 feet above the listening position whereas the mains are at ear level.
ghart999 is offline
post #6 of 19 Old 12-02-2019, 01:37 PM
Legairre's Avatar
Liked: 703
Thanks that's what I though. With them above the mains it will probably sound like an extension of the fronts and make it seem like you have really really tall fronts when the atmos effects are in a movie.
post #7 of 19 Old 12-02-2019, 01:48 PM - Thread Starter
ghart999's Avatar
Quoted: 219 Post(s)
Liked: 72
OK thanks. So according the Dolby, front height speakers work if they are between 30-45 degrees from the listening position. After taking some measurements I would be 28.5 degrees. I wish I could really test this but since I would have to buy speakers and build a mount for them, it's not too easy.
ghart999 is offline
post #8 of 19 Old 12-02-2019, 01:58 PM
sdurani's Avatar
Liked: 6453
Can you lower the surrounds so that they are closer to seated ear height?
30-45 degrees elevation (above seated ear height). How far are you from your front L/R speakers?
Sanjay
sdurani is offline
post #9 of 19 Old 12-02-2019, 02:00 PM
Legairre's Avatar
Liked: 703
Are you using 2 or 4 atmos speakers? If 4 speakers then the front could be between 30 and 55 degrees with the back atmos speakers between 125 and 150 degrees. If just 2 atmos speakers then they need to be closer to directly over head at 65 to 100 degrees.
ID:	2648524   Click image for larger version
post #10 of 19 Old 12-02-2019, 02:10 PM - Thread Starter
ghart999's Avatar
Quoted: 219 Post(s)
Liked: 72
Originally Posted by sdurani View Post
Can you lower the surrounds so that they are closer to seated ear height? 30-45 degrees elevation (above seated ear height). How far are you from your front L/R speakers?
Rears are pretty high up, so I could certainly bring them down about 2 feet. So rear height could potentially work if they were placed up at the ceiling. But what speaker could I use the would allow me to angle so far down? In ceiling is not an option.
It's 138" from MLP to LCR.
ghart999 is offline
post #11 of 19 Old 12-02-2019, 02:11 PM - Thread Starter
ghart999's Avatar
Quoted: 219 Post(s)
Liked: 72
This would be for 2 speakers only.
ghart999 is offline
post #12 of 19 Old 12-02-2019, 02:20 PM
Legairre's Avatar
Liked: 703
OK so ideally they would be 65-100 degrees. How high are your surround speakers right now?
post #13 of 19 Old 12-02-2019, 02:35 PM - Thread Starter
ghart999's Avatar
Quoted: 219 Post(s)
Liked: 72
82" to center of baffle. I know they are probably too high. I mounted them before I knew much about placement. And they are directly on the sides. Should I bring down to ear level or slightly higher? I think read something about 1.25X the height of mains?
ghart999 is offline
post #14 of 19 Old 12-02-2019, 02:35 PM
Legairre's Avatar
Liked: 703
If you do as sdurani suggested and move the surround speakers to where the tweeters are closer to ear height then you could use SVS elevation speakers up high on the sides like at 65-100 degrees like in this diagram.
That way your surrounds and fronts would be the bed layer down at ear level and the SVS speakers would be up high as the atmos speakers. and you would have the required separation
https://www.svsound.com/pages/prime-elevation
sdurani likes this.
post #15 of 19 Old 12-02-2019, 02:38 PM - Thread Starter
ghart999's Avatar
Quoted: 219 Post(s)
Liked: 72
I was thinking of these speakers since they have the nice angling options.
https://www.accessories4less.com/mak...ck-each/1.html
ghart999 is offline
post #16 of 19 Old 12-02-2019, 02:55 PM
Legairre's Avatar
Liked: 703
Oh yeah those will work and at a much better price too.
post #17 of 19 Old 12-02-2019, 03:29 PM
sdurani's Avatar
Liked: 6453
The whole point of Atmos is to separate sounds around you versus sounds above you. You will get that effect by lowering the surround speakers closer to ear height and adding height speakers much higher above them. The speakers high up on the side walls will create a soundstage between them, complete with overhead imaging. This is much more in keeping with the intent of Atmos than a slightly taller front soundstage.
Any small bookshelf speaker should work. Even better if you can find ones from the same manufacturer as your other speakers (to maintain consistent sound all around). Like another pair of NHT Super Zero 2.1 speakers. To aim the speakers down, you just need flexible wall mounts.
https://www.nhthifi.com/products/107...round-speakers
At that distance, speakers placed 36-40 inches above ear height would result in a 15-16 degree elevation angle. Not even close the 30-45 degrees of elevation that Dolby recommends.
Sanjay
sdurani is offline
post #18 of 19 Old 12-02-2019, 10:47 PM - Thread Starter
ghart999's Avatar
Quoted: 219 Post(s)
Liked: 72
Thanks all. I ordered the Boston Acoustic SoundWares I linked above. 4.5" with 3/4" tweeter coax. Got em for $150 shipped. They have very flexible mounts for wall and corner mounting. I'll be placing these on the side walls where it meets the ceiling. Can't wait....
ghart999 is offline
post #19 of 19 Old 12-02-2019, 11:11 PM
bobknavs's Avatar
Quoted: 2436 Post(s)
Liked: 1739
Looks like a good choice.
I see that they tilt down 40°, which is pretty good.
bobknavs is offline
Reply Speakers
