Is it an upgrade to go from Boston Acoustics VR3 to Infinity Reference 253 Speakers? - AVS Forum | Home Theater Discussions And Reviews
 5Likes
  • 3 Post By bear123
  • 1 Post By bear123
  • 1 Post By Madmax67
post #1 of 6 Old 12-02-2019, 05:49 PM - Thread Starter
Megasabin's Avatar
In my current home theater setup I use an Onkyo-TXSR605 receiver with Boston Acoustics VR3 floor standing speakers, a Boston Acoustics center channel speaker, and an elemental design A2-300 sub. I bought my whole set up around 2009-2010.
I've been planning to do a big home theater upgrade next year before PS5 comes out with a new TV and receiver. I was going to leave my speakers be and simply add two reference speakers for 5.1, but I just saw the fantastic Cyber Monday deal where I can snag Infinity Reference RC253x2, RC263, RC162x2 for around 600 bucks. I'm trying to figure out if it's worth it.
I have the disposable income to make the purchase, but I'd only want to snag the deal if it actually makes sense. My set up is used exclusively for movies & gaming. Would I see a significant improvement over my current Boston Acoustic speakers if I went with the Infinity Reference range? Or would it be about the same/worse and not worth doing?
Megasabin is offline
post #2 of 6 Old 12-02-2019, 06:22 PM
bear123's Avatar
Quoted: 2831 Post(s)
Liked: 4316
The VR3's are 91.5-93 dB sensitive, 3 way with dual 7" woofers and measure fairly well.....I can't see the Infinity being an upgrade.....
So for a home theater setup, you will be getting a smaller cab, smaller woofers, lower power handling, and lower sensitivity. It sounds like a step in the wrong direction to me.
I'd upgrade the sub. Big time, your biggest area for improvement. Grab a Hsu VTF3.5 for a huge and drastic upgrade for your theater.
Lp85253, Zorba922 and drh3b like this.
bear123 is online now
post #3 of 6 Old 12-02-2019, 06:58 PM - Thread Starter
Megasabin's Avatar
Thank you. That was a direct helpful answer. I will hold off on this purchase. I don't see any cyber monday deal for the Hsu VTF3.5, but I will keep that subwoofer in mind when next year rolls around and I'm ready to upgrade my multimedia room.
post #4 of 6 Old 12-02-2019, 07:07 PM
bear123's Avatar
Liked: 4316
Just don't expect a huge discount ever being offered on that sub. You get about as much bang for the buck with that sub as you can get. Occasionally you see $30 off or something but thats about it. I don't think there is enough markup for a drastic sale as with most retail items.
Zorba922 likes this.
post #5 of 6 Old 12-02-2019, 10:01 PM
Quoted: 12 Post(s)
Liked: 8
There is a huge markup on speakers, sometimes 60-80% for towers, I would think subs can be easily 50%+
I have been a infinity fan since the 80’s, just love their speakers. That is love their old speakers.... not a fan of what they offer now. I did purchase 3 infinity 12in home subs, they are just kinda meh..... not bad, not great.... they were over half off if I recall (I think they are doing the same deal now, under $200 for the home sub). They are unfortunately a big box store brand now.
I have zero first hand experience with what you presently have and those infinity speakers, however for $600 for everything I would stay away.
What do you want to improve with your HT setup? Or I guess what are you missing?
NC25T is offline
post #6 of 6 Old 12-02-2019, 11:09 PM
Madmax67's Avatar
Quoted: 2306 Post(s)
Liked: 2603
Big box speakers and subs yes. More niche ID brands not so much.
drh3b likes this.
Chane A5 towers,Chane A2.4 center,RBH bipole side surrounds, Rythmik LV12R x2,Denon X4300H, Outlaw 5000,Front B speakers: Wharfedale Diamond 10.1 books. https://www.avsforum.com/forum/90-rec...d-part-ii.html
Madmax67 is offline
Reply Speakers
