In-wall vs On-wall for surround and rear speakers - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By zieglj01
post #1 of 5 Old 12-03-2019, 07:47 AM - Thread Starter
BlueWRXPride's Avatar
Quoted: 151 Post(s)
Liked: 49
I'm doing some upgrades to my dedicated home theater and one change is I want to make the surround speakers in-wall since they get in the way a bit walking in the room due to where the walking path is. While I'm at it, I'm debating also making the rear speakers in-wall for consistency. Right now my surrounds are Paradigm Atoms and the surrounds are Paradigm ADP-170. If I go in-wall, I plan on a speaker that has an enclosure, or building a backer box since it is important I don't have a lot of sound leakage.
My question is, are in-wall speakers inherently worse performers for a given price point? If I don't need to, should I keep the ADP-170 for rears and just do in-wall for the surround?
Home Theater: Marantz SR6012, Fronts: Paradigm Titans, Sides: Paradigm Atoms, Surrounds: Paradigm ADP-170, Sub: RBH I-12
BlueWRXPride is offline
post #2 of 5 Old 12-03-2019, 01:48 PM
Signaly's Avatar
Liked: 0
I wouldn't say worse, but they might be more susceptible to room gain which may or may not be useful. But given that you're using them for surrounds, you probably wouldn't notice it too much. I'd personally just do the in walls for surrounds, but that's just me. Curious what others have to say.
Made my first website that I think turned out pretty good. Hopefully it's helpful to somebody. https://easyhometheater.net/
Signaly is offline
post #3 of 5 Old 12-03-2019, 03:26 PM
bear123's Avatar
Quoted: 2834 Post(s)
Liked: 4322
In wall speakers definitely have some sound quality advantages over box speakers mounted on or near a wall. When you factor in the improved aesthetics you get with in walls, its a win win. As you said, backer boxes will be needed to control sound leakage.
bear123 is online now
post #4 of 5 Old 12-03-2019, 03:32 PM - Thread Starter
Quoted: 151 Post(s)
Liked: 49
Is there a rule of thumb as to how much volume to make the backer box with?
post #5 of 5 Old 12-03-2019, 03:42 PM
zieglj01's Avatar
Quoted: 3288 Post(s)
Liked: 3183
I would check with the manufacturer, there is more to it than to just build a simple back box
Jonas2 likes this.
Who AM I
zieglj01 is offline
Reply Speakers
