Help with finishing Denon and Klipsch 7.2 Setup - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By gajCA
  • 1 Post By SaleenS7TT
post #1 of 17 Old 12-05-2019, 03:26 PM - Thread Starter
SaleenS7TT's Avatar
Question Help with finishing Denon and Klipsch 7.2 Dolby Atmos Setup
Hello,
I have an older Denon AVR-X2300W 7.2 with an older Klipsch Reference R-25C center channel and R-12SW sub and really old, cheap Yamaha speakers ha. I would like to upgrade the Yamaha surround sound speakers and add side speakers. What would match best with my current receiver and Klipsch speakers to build a 7.1 or 7.2 setup?
If some other brand pairs well with Klipsch, that would be great as well!
Thanks for any input!
SaleenS7TT is offline
post #2 of 17 Old 12-06-2019, 08:38 AM - Thread Starter
SaleenS7TT's Avatar
Bump, this would be to achieve Dolby Atmos 7.2 surround sound eventually. Maybe a bit at a time, second sub would be last.
post #3 of 17 Old 12-06-2019, 09:46 AM
pase22's Avatar
Quoted: 3600 Post(s)
Liked: 3036
Originally Posted by SaleenS7TT View Post
Hello,
I have an older Denon AVR-X2300W 7.2 with an older Klipsch Reference R-25C center channel and R-12SW sub and really old, cheap Yamaha speakers ha. I would like to upgrade the surround sound speakers. What would match best with my current receiver and Klipsch speakers to build a 7.1 or 7.2 setup?
What are you looking to upgrade? FL/FR? Surround channels?
What is your budget?
Are you in the US?
Kef LS50,Q200C, Q100, Kef Kube 10B (X2) , Denon AVR-X3400H, NAD 216 THX, Panasonic 50" Plasma, Xbox One.
Bedroom: Kef Q100 ,JBL Loft 20, SVS SB-2000, Denon AVR-S710W, PS3, 32" Insigna LED.
pase22 is online now
post #4 of 17 Old 12-06-2019, 09:53 AM - Thread Starter
SaleenS7TT's Avatar
Looking to upgrade all left and right front, rear, and side speakers. I only have the center speaker and sub currently, the rest is all old and cheap Yamaha speakers.
post #5 of 17 Old 12-06-2019, 10:23 AM
Quoted: 543 Post(s)
Liked: 485
This line of DCM speakers are pretty good and priced right.
https://pricedrightsales.com/product...lf-and-2-tower
cocrh is online now
post #6 of 17 Old 12-06-2019, 11:03 AM - Thread Starter
SaleenS7TT's Avatar
Never heard of them... From research it seems they're not as good as when the company originally opened since it was bought out. Very limited reviews too from what I can find quickly.
post #7 of 17 Old 12-06-2019, 12:12 PM
Quoted: 543 Post(s)
Liked: 485
Here is one person who recently received them after having some Polks.
https://www.avsforum.com/forum/122-g...l#post58905368
Lots of discussion and positive comments on this thread.
https://www.avsforum.com/forum/89-sp...l#post58918898
This is the bit better model TFE100's
https://www.avsforum.com/forum/89-sp...right-now.html
cocrh is online now
post #8 of 17 Old 12-06-2019, 03:42 PM
gajCA's Avatar
Quoted: 9567 Post(s)
Liked: 6613
If you liked the R series from years ago the newer Klipsch RP series is light years ahead.
There is no such thing as 7.2 Atmos.
The more common variations are 5.1.2 and 7.1., 5.2.2 and 7.2.2.
First number is the number of base layer speaker less than half way up the wall, center number is sub(s) third number is Atmos speakers.
Geoff A. J., California
gajCA is online now
post #9 of 17 Old 12-06-2019, 09:31 PM - Thread Starter
SaleenS7TT's Avatar
Oh okay, well 7.1 works for me! So you suggest to pair my two current Klipsch speakers with front, side and rear RP series? I'm up for whatever pairs well, even if a different brand.
post #10 of 17 Old 12-07-2019, 08:32 AM
gajCA's Avatar
Liked: 6613
I would think the RP would pair best but right now while the iron is hot I'd replace the sub as the PB12 can be had for a VERY short time for $500.
Here it is compared to the PB1000 which is regularly $500; you are getting much more bang for your $500 than any other time during the year and it is a massively better sub than what you have now.
https://www.svsound.com/products/pb1...hoCb_EQAvD_BwE
5 years 300watts =15w19h20d= 46 lbs 10" [18hz] $499 SVS PB1000, (extension from Sound & Vision Review)
5 years 400watts =17w21hx22d= 66 lbs 12" [19hz] $500 SVS PB12 NSD, (extension from Sound & Vision Review)
Last year at this time they were selling the PB12 for $549.
Zorba922 likes this.
gajCA is online now
post #11 of 17 Old 12-10-2019, 06:19 AM - Thread Starter
SaleenS7TT's Avatar
I may actually go with the ELAC lineup, as they have a good sale right now and I'm on a bit of a budget ($1200 with sub for just 5.1 for now). I also will probably be upgrading my sub to the SVS PB12.
post #12 of 17 Old 12-13-2019, 01:23 PM - Thread Starter
SaleenS7TT's Avatar
Bumping this up. Now I'm considering Paradigm, HSU Hybrid 3 package, or Emotiva (Emotiva as an affect cost saving option). My sub will be SVS or HSU for sure.
post #13 of 17 Old 12-13-2019, 06:01 PM
Zorba922's Avatar
Quoted: 7763 Post(s)
Liked: 5880
I would expect the Paradigm to have the most forward/aggressive sound with the possibility of a little treble sharpness, the Emotiva being neutral, and the Hsu HB-1 being slightly warm (or the Hsu CCB-8 being similarly forward/aggressive like the Paradigm). Which one you'll prefer is all a matter of personal taste and individual room acoustics.
~ Are you a "geek hobbyist" obsessed with squeezing out that last 5-10% improvement? The economy will thank you...especially the Chinese one. Or are you more of a get-set-and-forget "casual user" who simply wants to increase your enjoyment of movies, TV and gaming? Relax, HT isn't rocket science, nor does it have to cost an arm and a leg---especially if you ignore the aforementioned vocal minority. And remember to smile...it's just a silly hobby, after all. :)
Zorba922 is offline
post #14 of 17 Old 12-14-2019, 07:40 AM - Thread Starter
SaleenS7TT's Avatar
That is very helpful, thank you! Now I just wish I knew which sound I liked most, since I'm new to home theater. I'm unsure about ELAC after listing to them and the cheaper Klipsch I'm not fond of really.
post #15 of 17 Old 12-14-2019, 08:04 AM
Zorba922's Avatar
Liked: 5880
If you are buying unheard, the Emotiva B1s (or T-Zero if you prefer towers) would be a very safe choice.
Two other very safe choices if you're looking for bookshelves would be the Ascend 170SE and Chane A1.5 for your front L/R, around $300-325.
There's also the NHT SuperOnes for your L/R, $260/pair:
https://www.amazon.com/NHT-SuperOne-...dp/B00LJX4HCY/
For your rear and side surrounds, these would be fine, $280 for all 4:
https://www.amazon.com/NHT-SuperZero...dp/B00CKNOYWK/
Zorba922 is offline
post #16 of 17 Old 12-15-2019, 01:27 AM - Thread Starter
SaleenS7TT's Avatar
So we were able to hear the Paradigm Monitor SE 6000F with the wife and we really liked them. Much more than the cheaper Klipsch series and ELAC speakers. Also heard SVS Prime Tower speakers, which were close to Paradigm in sound, but $500 each vs $374 each. I wasn't too sure what it was about Paradigm, but my wife swore it sounded better regardless of price.
We also heard the SVS PB-2000 and decided we will put a deposit on that Monday to hold it for the $559 price of their last demo model (since the Pro is out now for $800). Figured $59 increase vs the PB12-NSD for $500 was worth the upgrade!
gajCA likes this.
post #17 of 17 Old 12-15-2019, 10:02 AM
gajCA's Avatar
Liked: 6613
Excellent.
Looking forward to your opinion on the sound once installed at home.
gajCA is online now
Reply Speakers
