Which is better speaker positioning : straight vs higher but angled downward? - AVS Forum | Home Theater Discussions And Reviews
View Poll Results: Which would you choose among the 2 speaker placement options?
Position A 3 60.00%
Position B 2 40.00%
Voters: 5. You may not vote on this poll
 3Likes
  • 1 Post By ipca204
  • 1 Post By m0j0
  • 1 Post By gajCA
post #1 of 9 Old 12-10-2019, 04:39 AM - Thread Starter
joms's Avatar
Quoted: 122 Post(s)
Speaker = KEF Q350
Which would you choose below, position A or B?
Position A: Speaker is aimed straight but tweeter is above ear level
Position B: Speaker is 3" higher than position A (due to Isoacoustics Aperta speaker stand) but angles downward
joms is offline
post #2 of 9 Old 12-10-2019, 05:21 AM
Quoted: 268 Post(s)
Liked: 137
easy one! The position that sounds best to you! No two people hear the same way nor see the same way..
eljaycanuck likes this.
ipca204 is offline
post #3 of 9 Old 12-10-2019, 05:45 AM
m0j0's Avatar
Quoted: 896 Post(s)
Liked: 1081
Is the speaker on a stand or on a table as in the picture above? If on a stand, I would lean toward Option A. If on a table, Option B.
m0j0 is online now
post #4 of 9 Old 12-10-2019, 06:47 AM - Thread Starter
joms's Avatar
Quoted: 122 Post(s)
I would like to know the answer before buying the Aperta stand so I can't really audition it both ways. FYI im in the Philippines and dont have the luxury to buy/test/return items.
joms is offline
post #5 of 9 Old 12-10-2019, 07:17 AM - Thread Starter
joms's Avatar
Quoted: 122 Post(s)
Option A = speaker is on a table
Option B = speaker on a speaker stand which is placed on top of a table
joms is offline
post #6 of 9 Old 12-10-2019, 07:32 AM
m0j0's Avatar
Quoted: 896 Post(s)
Liked: 1081
I would try to ensure with either option that the speaker is at the edge of the table or can properly clear the table so you don't get any comb filtering type of effect. Also, typically, there is a reasonable amount of vertical dispersion (somewhere around 5-15%) so you don't have to mess with tilting speakers to get a good effect.
m0j0 is online now
post #7 of 9 Old 12-10-2019, 09:43 AM
gajCA's Avatar
Quoted: 9539 Post(s)
Liked: 6584
Speaker = KEF Q350
As the KEFs don't care if they are on their sides vs standing upright simply place them on a stand on their sides and the speaker should be the perfect height without any angling required.
Alan P likes this.
Geoff A. J., California
gajCA is offline
post #8 of 9 Old 12-10-2019, 03:52 PM
Quoted: 20 Post(s)
A: tweeters are not laser beams
soundsdivine is offline
post #9 of 9 Old 12-10-2019, 03:56 PM
Quoted: 20 Post(s)
If you want the tweeters aimed ideally, just put some furniture pads under the rear of the speakers so they are very slightly aimed down. I don’t think you’ll notice a difference though.
Reply Speakers
