Beginner's level speaker setup - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By bobknavs
post #1 of 5 Old 12-14-2019, 08:33 AM - Thread Starter
Liked: 0
Hey guys,
I'm not looking for a super low budget solution here, but just some practical suggestions:
I have a PC connected to a beamer being my very basic home theater. Now I'm looking ot improve sound.
Since I don't want to have cables lying all around my living room, I'm really just thinking to have 2 decent speakers connected to my PC as the sound system. I want the speakers behind me, because that's how I can put the cables nicely to the PC which is next to me.
What kind of speakers would you recommend and since I've so far been using on board sound, I probably need some advice on sound cards too.
I'd appreciate any and all suggestions!
Jakob
Linguss is offline
post #2 of 5 Old 12-14-2019, 12:47 PM
eljaycanuck's Avatar
Quoted: 1990 Post(s)
Liked: 2822
I'm a bit baffled by the idea of wanting a projected image in front of you and all of your audio behind you but if that's how you want it a couple of options include:
- powered bookshelf/desktop speakers (Audioengine, etc.); or
- a good soundbar.
eljaycanuck is offline
post #3 of 5 Old 12-14-2019, 12:49 PM
bobknavs's Avatar
Quoted: 2509 Post(s)
Liked: 1785
Is a "beamer" a projector?
(To me, it's a BMW motorcycle. A Bimmer is a BMW automobile.)
Peja likes this.
bobknavs is offline
post #4 of 5 Old 12-14-2019, 12:54 PM
Zorba922's Avatar
Quoted: 7715 Post(s)
Liked: 5853
Speakers behind you is really not a good idea. You would get better sound from a good pair of headphones in that case, like the $100 Grado SR80.
Otherwise, all you need is a single long USB cable between your PC and this paperback book sized $145 mini-amp under your screen, or connect to it using BlueTooth:
https://www.amazon.com/SMSL-AD18-Amp.../dp/B071JN7GXN
And a good pair of passive speakers flanking the screen. What's your budget?
~ Are you a "geek hobbyist" obsessed with squeezing out that last 5-10% improvement? The economy will thank you...especially the Chinese one. Or are you more of a get-set-and-forget "casual user" who simply wants to increase your enjoyment of movies, TV and gaming? Relax, HT isn't rocket science, nor does it have to cost an arm and a leg---especially if you ignore the aforementioned vocal minority. And remember to smile...it's just a silly hobby, after all. :)
Zorba922 is offline
post #5 of 5 Old 12-14-2019, 03:21 PM
gajCA's Avatar
Quoted: 9553 Post(s)
Liked: 6593
I've owned three Beamers since 1987 but none of them a boxer engine strangely enough.
But I have to agree with the consensus that having the speakers behind you would be poor, but having then one either side (like one on each end tabpe) would be ok; at least one AVS member did that with good results.
A pair of self powered Kali LP6s are just $300 and available at Guitar Center or Sweetwater.
https://www.sweetwater.com/store/det...studio-monitor
Geoff A. J., California
gajCA is offline
Reply Speakers
