Wireless speaker system puzzle - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By sbarnhar
  • 1 Post By Wayne A. Pflughaupt
post #1 of 6 Old 12-14-2019, 12:39 PM - Thread Starter
Plug's Avatar
I'd like to use a wireless speaker setup for a HT/music system in a great room used mainly for casual viewing and listening. The problem I have, if I understand correctly, is that it looks like most of these systems like the Sonos 5.1 system are designed to connect an HDMI out directly to a sound bar, and then the sound bar plays the L/center/R channels in the contained speakers, and wirelessly broadcasts the surround and sub channels.
But I'm using an overhead projector, so using a sound bar doesn't make sense.
It doesn't look like Sonos has a way to broadcast a 5.1 signal that can then be played by speakers around the room. Am I missing something? Is there a different product out there that does do this?
Plug is offline
post #2 of 6 Old 12-14-2019, 03:04 PM
sbarnhar's Avatar
If you read this Lifewire article and scroll down to “The WiSA Solution”, there are several interesting solutions that might work for you.
Plug likes this.
Scott Barnhart
sbarnhar is offline
post #3 of 6 Old 12-15-2019, 04:53 AM
Wayne A. Pflughaupt's Avatar
Quoted: 468 Post(s)
Liked: 390
What exactly are you wanting when you say “wireless speaker system?” The back speakers, or all of them, including the front three?
Wayne A. Pflughaupt
Plug likes this.
Equipment List
"A nice mid-fi system," according to an audiophile acquaintance.
Reviews and Tech Articles
Wayne A. Pflughaupt is offline
post #4 of 6 Old 12-15-2019, 09:28 PM - Thread Starter
Plug's Avatar
Thank you, WiSA is exactly what I had in mind.
And it's great that it's a standard, instead of getting locked into one manufacturer. Will be interesting to see how many manufacturers make products supporting this.
Plug is offline
post #5 of 6 Old 12-15-2019, 09:35 PM - Thread Starter
Plug's Avatar
Wayne A. Pflughaupt
Yes, including the front three.
Normally folks have a TV and source all grouped in the front of the room. I'm sure this is why Sonos and others make products specific to that arrangement. But with a projector, it's not uncommon to have the center of gravity for the system (sources, etc.) be in the back of the room, or in my case, in a closet in the back of the room. WiSA appears to be better suited for those configurations.
Plug is offline
post #6 of 6 Old 12-17-2019, 12:54 PM
Quoted: 468 Post(s)
Liked: 390
There aren't many. As far as speakers go, Klipsch and Bang & Olufsen are probably the only brands you've ever heard of.
You'll require the hub from Axiim. It's the only one available, from what I can see.
The major downside to WiSA is that it does not support auto room calibration, second-zone capability, Dolby Atmos and tons of other audio processing formats, nor the myriad of streaming services. Aside from the wireless capability, it's actually extremely limited.
Wayne A. Pflughaupt
Equipment List
Reply Speakers
