Speaker help (from the experts) decisions, decisions - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By Zorba922
post #1 of 10 Old 12-14-2019, 05:02 PM - Thread Starter
Liked: 1
Hi All,
I am in search of speakers to replace my current Kef floor standing models. The reason is due to a recent move and lack of space.
Background on room:14 by 17 and open on 2 sides ( one side leading to kitchen the other to the entry way and stairs). Also, I do have a SVS sub and a Yamaha receiver.
I am struggling to decide between a high quality bar and a 3-1 set up. My local place let me borrow a Yamaha YSP 5600 sound bar which I like but not sure if it is good as standard speakers and I do not want to regret down the road. My price point is around 1500.
My question is should I go the sound bar route as noted above or do 3 speakers? My place has PSB, Kef, Paradigm, Martin Logic, etc. as options. I am sticking with them as I can trade in my old speakers.
Any thoughts/opinions are greatly appreciated.
Ryan
lenny3332 is offline
post #2 of 10 Old 12-14-2019, 05:10 PM
solarrdadd's Avatar
Quoted: 370 Post(s)
Liked: 239
what are the speaker dimensions and with a room that size, what is the lack of space? do you mean that you have so much stuff that will be that close to the speakers that they won't fit? is there no way they will work?
TCL-65R615, 55P605 DV/HDR10 & 49S405 HDR10, Philips BDP7501, BPD7502 UHD Players
Oppo BDP-105D, 105, 93, Marantz AV7702MKII, NR1607. Xbox One S
Emotiva XPA5,UPA2, UPA200 & Mini X Amps, ATV4K 32gb
Speakers, Polk SDA-2, Monitor 10A & 5A, Axiom M80,
VP180, QS8, M2, QS4, ATMOS 7.1.4 & 5.1.2 NYGiants!
solarrdadd is offline
post #3 of 10 Old 12-14-2019, 05:11 PM
pase22's Avatar
Quoted: 3586 Post(s)
Liked: 3021
Originally Posted by lenny3332 View Post
Hi All,
Ryan
If you like how the Kef sound, just get smaller speakers such as Q150 or LS50's. You have a pretty good sub that easily handle a 90-100hz crossover. A soundbar will not even come close.
Kef LS50,Q200C, Q100, Kef Kube 10B (X2) , Denon AVR-X3400H, NAD 216 THX, Panasonic 50" Plasma, Xbox One.
Bedroom: Kef Q100 ,JBL Loft 20, SVS SB-2000, Denon AVR-S710W, PS3, 32" Insigna LED.
pase22 is online now
post #4 of 10 Old 12-14-2019, 05:15 PM - Thread Starter
Liked: 1
Thanks both. The reason for the lack of space is we have sort of a half wall due the openings on both sides and a large fireplace cabinet. The speakers kind of stick out in the openings.
I should mention that I was looking for on wall options, knew I missed something...
post #5 of 10 Old 12-14-2019, 05:19 PM
solarrdadd's Avatar
Quoted: 370 Post(s)
Liked: 239
to keep us from imagining/trying to understand, may I suggest pictures, nice clear pictures!
post #6 of 10 Old 12-14-2019, 05:26 PM - Thread Starter
Liked: 1
Picture a good idea although struggling to attach with iPad. I did take a pic but struggling...
post #7 of 10 Old 12-14-2019, 05:32 PM
KenM10759's Avatar
Quoted: 3544 Post(s)
Liked: 1997
I couldn't find where Paradigm or Martin Logan (same parent company as Anthem, BTW) have any true on-wall speakers. The only ones KEF has at the moment are the KEF T-series, including T201 and T301 variants.
As much as I like KEF, the best true on-wall speakers I've ever heard are the Totem Acoustics Tribe series.
KEF R500, R200C, R100, R50, SVS SB2000 sub, NAD T758v3 AVR, LG UP875 4K BlueRay, Samsung UN55JU6500F 4K LED TV, KEF M500 headphones, Sony CDP-CE500 CD changer. Office: NAD M10, KEF LS50, KEF Kube 10b, Pro-Ject RPM1 TT w/ Ortofon 2M Red. Guest room: Hafler 300 L-R, KEF Reference Model 100 center, KEF iQ10 surrounds, modded M&K V-90 sub, Bluesound Vault 2.
KenM10759 is online now
post #8 of 10 Old 12-14-2019, 05:38 PM
Zorba922's Avatar
Quoted: 7683 Post(s)
Liked: 5841
Hi All,
You can spend as little as $400-500 for 3 bookshelf speakers (mostly internet-direct brands not retail ones) that would easily run circles around any soundbar at any price. Physics is physics.
Spending much more than say, $1K on your front 3 speakers will simply get you prettier cabinets, if that is high on your list of priorities.
solarrdadd likes this.
~ Are you a "geek hobbyist" obsessed with squeezing out that last 5-10% improvement? The economy will thank you...especially the Chinese one. Or are you more of a get-set-and-forget "casual user" who simply wants to increase your enjoyment of movies, TV and gaming? Relax, HT isn't rocket science, nor does it have to cost an arm and a leg---especially if you ignore the aforementioned vocal minority. And remember to smile...it's just a silly hobby, after all. :)
Zorba922 is offline
post #9 of 10 Old 12-14-2019, 05:44 PM - Thread Starter
Liked: 1
Thank you. I will check them out.
post #10 of 10 Old 12-15-2019, 09:42 AM
gajCA's Avatar
Quoted: 9541 Post(s)
Liked: 6585
I have this as my center speaker in my secondary room.
Plays surprising loud and clear for such a small box.
Come with hardware to mount vertically or horizontally as the tweeter has equal dispersion horizontally and vertically.
The slightly curved cabinet seems to take care of any "lobing issues" related to the mid/tweeter/mid design.
Plus is they are small and relatively attractive.
Unfortunately the "new" version of this speaker is $450 a retailers which is ridiculously high so unless your dealer can work with you on getting that price closer to this price, (the "new" and "old" are essentially identical), you might not be interested.
https://www.amazon.com/MartinLogan-M...50465177&psc=1
You can also use these for left and right and save some money. They also come with wall brackets.
https://www.crutchfield.com/p_839MO4...Motion-4i.html
Here is a review AVS Forum did of that kind of system:
https://www.avsforum.com/martinlogan...system-review/
Geoff A. J., California
gajCA is offline
Reply Speakers
