Possibly Upgrading - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #1 of 40 Old 01-06-2020, 08:08 PM - Thread Starter
adubree86's Avatar
Possibly Upgrading
So I built my system about 7 years ago on a bit of a budget. I’m currently running a 5.1 system. Receiver Onkyo RX-V373. (2) Bic DV-64 towers, (1) DV-62CLR and (2) DV-62sib and a Klipsch Sub-10. Was considering an upgrade. Didn’t know if I’d be better off sticking with my current speakers and just upgrading the receiver or if I should look into upgrading everything. Was looking into Klipsch or Paradigm speakers. I know the Klipsch will be much brighter than what I’m used to but I’ve auditioned them and they don’t seem to bother me. And are the newer paradigms worth the $$? System used for 90% movies/sports/tv and 10% music.
L/R Klipsch RP-260f Center Klipsch RP-450c, Surrounds Bic American 62si Sub SVS PB12-nds Receiver Onkyo TX-nr686
adubree86 is offline
post #2 of 40 Old 01-07-2020, 11:11 AM
gajCA's Avatar
Quoted: 9573 Post(s)
Liked: 6618
I'd start by upgrading the subwoofer.
Your current sub is a ported 10" 200 watt sub with 28hz claimed extension.
All of these would be a significant improvement.
5 years 300watts =15w19h20d= 46 lbs 10" [18hz] $499 SVS PB1000, (extension from Sound & Vision Review)
5 years 500watts =15w19h20d= 72 lbs 10" [20hz] $500 MONOPRICE MONOLITH THX 10"
3 years 300watts =16w22h21d= 69 lbs* 12" [19hz] $569 RHYTHMIK LV12F
2 years 350watts =15w21h22d= 62 lbs 12" [18hz] $607 HSU VTF2 MK5, (extension from Audioholics review)
* = shipping weight
Geoff A. J., California
gajCA is online now
post #3 of 40 Old 01-07-2020, 11:37 AM
pase22's Avatar
Quoted: 3600 Post(s)
Liked: 3037
What is your all in budget?
Kef LS50,Q200C, Q100, Kef Kube 10B (X2) , Denon AVR-X3400H, NAD 216 THX, Panasonic 50" Plasma, Xbox One.
Bedroom: Kef Q100 ,JBL Loft 20, SVS SB-2000, Denon AVR-S710W, PS3, 32" Insigna LED.
pase22 is online now
post #4 of 40 Old 01-07-2020, 12:11 PM - Thread Starter
adubree86's Avatar
Always seems to be a moving target.
post #5 of 40 Old 01-07-2020, 12:15 PM
pase22's Avatar
Liked: 3037
Can you give us a ballpark figure so we can make appropriate recommendations?
You don't need to upgrade everything at once either.
post #6 of 40 Old 01-07-2020, 12:23 PM - Thread Starter
adubree86's Avatar
Honestly I'm unsure. My biggest complaint is the system just seems to lack that immersive experience I'm after. Maybe speaker setup. I tried to set up everything manually again last night with a tape and decibel meter and it still seamed a bit lack luster. I am in a new house with vaulted ceilings and a much larger space. Didn't know if upgrading the receiver may help that or not. As far as sub, I'm pretty satisfied with what I'm running. Not sure if I'd want to drop $500-700 on a new sub.
post #7 of 40 Old 01-07-2020, 12:42 PM
Zorba922's Avatar
Quoted: 7767 Post(s)
Liked: 5884
First, check your receiver settings. If you're using default AccuEQ settings, turn it off and just start over by manually setting all 5 speakers on "small" and at 80Hz crossover. Often times those auto-calibration tools screw things up more than anything.
If still unhappy, I'd upgrade the center first: Chane A2.4, Ascend 340SE, Emotiva C1, HTD Level 3 center ... these are all around $250-300.
See how it sounds after that...the center does 70-80% of the HT output so this is what you're actually hearing during your HT/TV usage.
After that, see if you're still missing the "immersive" effect, or if you want a FULLER, DEEPER sound.
If it's the first, then upgrade the front L/R to whatever matches the center you chose (Chane A1.5, Ascend 170SE, Emotiva B1, HTD Level 3 books.
If it's the second, upgrade the sub.
~ Are you a "geek hobbyist" obsessed with squeezing out that last 5-10% improvement? The economy will thank you...especially the Chinese one. Or are you more of a get-set-and-forget "casual user" who simply wants to increase your enjoyment of movies, TV and gaming? Relax, HT isn't rocket science, nor does it have to cost an arm and a leg---especially if you ignore the aforementioned vocal minority. And remember to smile...it's just a silly hobby, after all. :)
Zorba922 is offline
post #8 of 40 Old 01-07-2020, 12:44 PM
gajCA's Avatar
Liked: 6618
Well usually with the subwoofer you do not want to use a tape measure to set the distance, you should let YPAO set the distances as the sub will be further away in the menu than a tape measure will show while all the other passive speakers will be very close to that measured by the tape.
Are all speakers set to "small" with an 80hz crossover?
The difference between a 28hz sub and a 20hz or lower sub is substantial in terms of impressiveness.
Easy enough to order the SVS PB1000 to see for yourself and return it a no cost to you at all if not happy.
gajCA is online now
post #9 of 40 Old 01-07-2020, 12:59 PM
pase22's Avatar
Liked: 3037
Subs see the entire space so if you have an open floor plan with vaulted ceiling that 200w Klipsch sub doesn't stand a chance. Areceiver with better room correction and sub eq would help, but shouldn't be top priority. Get yourself a good sub that can pressurize that space more efficiently like an HSU VTF-3 MK5 or go dual VTF-2 MK5's which would be even better. After that upgrade the front 3 and receiver.
http://www.hsuresearch.com/products/vtf-3mk5HP.html
http://www.hsuresearch.com/products/vtf-2mk5.html
post #10 of 40 Old 01-07-2020, 01:11 PM - Thread Starter
adubree86's Avatar
Sub wasn't set with tape. It's actually like 10' from listening position but distance was set to around 22'6"
I have my front towers set to Large but everything else set to small. crossover was set to 60hz. I'll try that change tonight.
post #11 of 40 Old 01-07-2020, 01:16 PM - Thread Starter
adubree86's Avatar
I'm also very limited by room layout. I'll throw a plan of my space up here tonight. It's honestly not a great space for a setup but it's what I've got to work with.
post #12 of 40 Old 01-07-2020, 02:01 PM
gajCA's Avatar
Liked: 6618
Things should sound better when you set the towers to "small" as they and the amp only have to reproduce frequencies above the crossover point which ideally should be at 80hz.
My towers are set to "small" and my receiver never gets more than 10 degrees hotter than room temperature.
gajCA is online now
post #13 of 40 Old 01-07-2020, 02:32 PM
Zorba922's Avatar
Liked: 5884
Especially because BIC systematically and shamelessly lies about their specs.
They list those 34lb, un-ported towers as having 29Hz bass extension...in the REAL world I'll bet 70-90Hz is much more likely.
@adubree86 - I would try an 80Hz or even 100Hz crossover.
Zorba922 is offline
post #14 of 40 Old 01-07-2020, 03:33 PM
bezlar's Avatar
Quoted: 171 Post(s)
Liked: 162
Immersive sound usually comes from a sub that can pressurize a whole room. I wouldn’t upgrade speakers till you get a real sub. I would start at no less than a 15 inch from psa or rhythmic. Prob ported as well. You would really be surprised what you are missing with your current sub. You could prob find someone who lives close to you that would demo their systems. Just ask around in the manufactures forums for psa and rhythmic. Trust when I say you can never have enough bass.
bezlar is offline
post #15 of 40 Old 01-07-2020, 04:00 PM - Thread Starter
adubree86's Avatar
Room layout
post #16 of 40 Old 01-07-2020, 04:28 PM - Thread Starter
adubree86's Avatar
I could pick up a used Klipsch SW-115 for $500 which is a 15” sub with frequency response down to 18Hz 400 watt continuous
post #17 of 40 Old 01-07-2020, 08:15 PM
Zorba922's Avatar
Liked: 5884
For $500 you could get a *new* SVS PB12 from Amazon, very similar to their $700 PB2000.
Zorba922 is offline
post #18 of 40 Old 01-07-2020, 08:20 PM - Thread Starter
adubree86's Avatar
I was able to get the guy down to $425 on the sub. Would you recommend the new SVS PB 12” over the Klipsch 15” based on my room size?
post #19 of 40 Old 01-07-2020, 08:29 PM
Zorba922's Avatar
Liked: 5884
Your room appears to be about 500-600 square feet? Yes, I think the PB12 would do it. I am not sure I would really trust Klipsch's specs, they are known to fudge a lot...and also being a used sub you don't know just how much wear and tear the amplifier inside the sub has had.
Zorba922 is offline
post #20 of 40 Old 01-08-2020, 09:06 PM
Quoted: 871 Post(s)
Liked: 707
The 115-SW is actually a capable sub, from what I have read on here. Klipsch seemingly has corrected their amplifier issues, and for $425, is a pretty good deal for it.
sigpig is online now
post #21 of 40 Old 01-08-2020, 10:48 PM
Zorba922's Avatar
Liked: 5884
I think you're referring to the R-115SW, which only came out 1-2 years ago.
The OP is referring to a much older model:
https://www.audioholics.com/subwoofe...sch-sw-115-pre
Zorba922 is offline
post #22 of 40 Old 01-09-2020, 05:01 PM
Quoted: 871 Post(s)
Liked: 707
Damn Klipsch and their confusing product names!
post #23 of 40 Old 01-09-2020, 05:26 PM
Zorba922's Avatar
Liked: 5884
yep. Makes it convenient for the reseller, though.
If I were the OP I'd pay no more than $200 for what is probably a +10 year old sub, though I'll bet the original owner paid through the nose for it compared to a comparable sub today.
Zorba922 is offline
post #24 of 40 Old 01-12-2020, 03:32 PM - Thread Starter
adubree86's Avatar
Well I went ahead and pulled the trigger of the SVS pb12-nsd. Now I’m looking to figure out my LRC. Gonna leave my Surrounds for now.
post #25 of 40 Old 01-12-2020, 03:42 PM
Zorba922's Avatar
Liked: 5884
Good for you, I think you'll be pleased.
If you can, post a photo of your current set up.
Zorba922 is offline
post #26 of 40 Old 01-12-2020, 03:48 PM - Thread Starter
adubree86's Avatar
My living room setup
ID:	2668892   Click image for larger version
post #27 of 40 Old 01-12-2020, 04:07 PM
Zorba922's Avatar
Liked: 5884
Some things I'd do asap to see how much improvement might be had:
1. Pull the center forward so that its front edge juts out 1-2" forward of the front edge of the table it's sitting on. Or, put rubber doorstop wedges under it so that it's angled slightly upwards.
2. Pull the towers forward so that their front edges are on the same plane as the front edge of the TV table, or 1-2" in front of it.
3. Turn your surrounds so that they face each other, not directly at the front speakers---your are likely experiencing some cancellation with the current positioning. Consider angling them upwards so that the tweeters are aimed at 1-2 feet ABOVE your ear level.
https://www.crutchfield.com/learn/le...placement.html
4. Buy a 20ft subwoofer cable and move your sub into a corner to get more output out of it. Likewise, when your SVS sub arrives, try your best NOT to put it where your current sub is---it's currently too close to the right tower, and floating in the middle of the room like that will not have any boundary reinforcement benefits. Google up "subwoofer crawl" and if possible, use it to find optimal positioning for your sub.
Zorba922 is offline
post #28 of 40 Old 01-12-2020, 04:12 PM - Thread Starter
adubree86's Avatar
3. Buy a 20ft subwoofer cable and move your sub into a corner to get more output out of it. Likewise, when your SVS sub arrives, try your best NOT to put it where your current sub is---it's currently too close to the right tower, and floating in the middle of the room like that will not have any boundary reinforcement benefits. Google up "subwoofer crawl" and if possible, use it to find optimal positioning for your sub.
I’ve got a sub cable running to the back corner of the room but recently moved it to the front of the room to see if I’d like the difference. Will pulling the towers off the wall improve anything without rear ports? I’ll try moving the center and see if that helps any. Need to move my TV up a few inches as well.
post #29 of 40 Old 01-12-2020, 04:19 PM - Thread Starter
adubree86's Avatar
I’ve been thinking very seriously on the Klipsch RP-440c
post #30 of 40 Old 01-12-2020, 04:23 PM
Zorba922's Avatar
Liked: 5884
The reason for my suggestion is to get all 3 front speakers to share the same horizontal plane depth-wise, and to avoid having part of their output bouncing off the cabinet.
Additionally, you should always experiment with different amounts of toe-in for the L/R speakers, this can vary widely depending on the speakers, room acoustics, sitting position, and personal preferences.
Zorba922 is offline
Reply Speakers
