DIY speaker driver selection - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 01-14-2020, 01:24 AM - Thread Starter
ece2k2's Avatar
Quoted: 31 Post(s)
Liked: 3
I am trying to put together a DIY 2 way speaker using Beyma drivers for home theater (LCR channels) usage. I have 4 number of 18" subwoofers to take care of the LFE and I will be using the LCR speakers with bass management.
Please let me know if Beyma TPL-150H (https://usspeaker.com/beyma%20tpl150h-1.htm) and 12P80Nd (https://usspeaker.com/beyma%2012p80Nd-1.htm) are good choice of drivers for building a HT LCR speaker that is supposed to sit behind an AT screen. If not, could you please suggest alternate Beyma drivers that I could use for this purpose. Thank you!
ece2k2 is offline
post #2 of 2 Old 01-14-2020, 03:06 PM
RayGuy's Avatar
Quoted: 3089 Post(s)
Liked: 2884
You'd probably get better responses in the DIY portion of the forum ...
It's a VIRTUAL channel unless stated otherwise.
RayGuy is online now
Reply Speakers
