Upgrade from pioneer 52s - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 02-10-2020, 01:18 PM - Thread Starter
Quoted: 12 Post(s)
Liked: 1
I currently have 5.1 surround with 4 pioneer 52s I was looking at upgrading to something with a richer tone, I like the 52s but they sound flat for lack of a better description. I'm looking at going to 7.2.4, so I intend to repurpose the front speakers to surround duty. I was looking at q acoustics 3050 for my front speakers. Recommendations are welcome budget is about 1200 for front 3.
Mike_w_j2003 is offline
post #2 of 8 Old 02-10-2020, 01:30 PM
Ryan Statz's Avatar
Quoted: 758 Post(s)
Liked: 436
Where are you based?
I think you could go with a pair Ascend Acoustics CMT-340 SEs + the CMT-340 SE center at your budget (with room to spare), and be perfectly happy.
Home Theatre: Onkyo TX-NR747 | Polk Audio RTi A3 Front L/R | Polk Audio CSi A6 Centre | Polk Audio RTi A1 Surround L/R | HSU ULS-15 MK2 Subwoofer | Sony XBR55X900E | PlayStation 4 Pro | Xbox One S
Music: Cambridge Audio AXR100 | Stanton T.62 | Cambridge Audio AXC35 | KEF Q150 L/R
Ryan Statz is offline
post #3 of 8 Old 02-10-2020, 01:41 PM - Thread Starter
Quoted: 12 Post(s)
Liked: 1
Dallas Texas area, lots of stores around to test speakers out, I'd just like a starting point, so I'm not wondering aimlessly.
post #4 of 8 Old 02-10-2020, 01:55 PM
Ryan Statz's Avatar
Quoted: 758 Post(s)
Liked: 436
I'd look at the Ascends, then. Or if you're not averse to bookshelf speakers, the HSU HB-1 + HC-1 3.0 speaker package will net you less than half of your budget for the satin black finish (and still well under if you go for the rosenut finish). You could even do the HSU 7.0 package for less than your budget!
post #5 of 8 Old 02-10-2020, 03:01 PM
Zorba922's Avatar
Quoted: 7973 Post(s)
Liked: 6084
If looking for towers, then Emotiva T2 + C1 center = $1200 exactly. Less if you go with the allegedly "factory renewed" versions, or if you go with the T1 or TZero models.
Also, being in Dallas you should go check out HTD speakers, probably less than an hour's drive from where you are...google them.
~ Are you a "geek hobbyist" obsessed with squeezing out that last 5-10% improvement? The economy will thank you...especially the Chinese one. Or are you more of a get-set-and-forget "casual user" who simply wants to increase your enjoyment of movies, TV and gaming? Relax, HT isn't rocket science, nor does it have to cost an arm and a leg---especially if you ignore the aforementioned vocal minority. And remember to smile...it's just a silly hobby, after all. :)
Zorba922 is offline
post #6 of 8 Old 02-10-2020, 04:24 PM - Thread Starter
Quoted: 12 Post(s)
Liked: 1
Htd level 3's look pretty nice, that may just do the trick. I have to go listen to them now. It might be a little above the budget but it a loose figure to start with.
post #7 of 8 Old 02-14-2020, 08:23 AM - Thread Starter
Quoted: 12 Post(s)
Liked: 1
I ended up getting pioneer elite speakers, I ran across a really good deal on some used speakers. Definitely better than what I had, we'll see how long i keep them.
post #8 of 8 Old 02-14-2020, 06:29 PM
Zorba922's Avatar
Liked: 6084
Good luck!
btw, if you decide to get a sub later, you're also within easy driving distance of one of the best internet-direct brands, Rythmik Audio.
Zorba922 is offline
Reply Speakers
