Def Tech Pro Cinema 800 Speaker Stands - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By pstapler
post #1 of 10 Old 02-14-2020, 04:56 PM - Thread Starter
pstapler's Avatar
After many years of absence from any sort of home theater equipment, I have recently purchased some new equipment including the Pro Cinema 800 speaker system. Our living room isn't too large so it should suffice. So now my venture is to find some stands for the rears. Our walls are situated for wall mounting. Did some reading through the Def Tech thread. Have done lots of searching online. Haven't really seen anything that grabs my attention. I didn't care for the Def Tech specific stands.
For owners of similar size systems, what are you using for surround speaker stands? What are your likes and dislikes? I'd like to find something with wire passage through the tube if possible.
Sorry if this is in the wrong forum.
TIA...
pstapler is offline
post #2 of 10 Old 02-14-2020, 06:10 PM
Zorba922's Avatar
Quoted: 7976 Post(s)
Liked: 6086
This is what I use for my rear surrounds, and they do have wire management capability but I'm too lazy to use it, lol.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
PS. If you haven't ordered that DT system yet, there are far, far better ways to spend $900 for a 5.1 setup if you are open to alternatives.
~ Are you a "geek hobbyist" obsessed with squeezing out that last 5-10% improvement? The economy will thank you...especially the Chinese one. Or are you more of a get-set-and-forget "casual user" who simply wants to increase your enjoyment of movies, TV and gaming? Relax, HT isn't rocket science, nor does it have to cost an arm and a leg---especially if you ignore the aforementioned vocal minority. And remember to smile...it's just a silly hobby, after all. :)
Zorba922 is offline
post #3 of 10 Old 02-14-2020, 06:44 PM - Thread Starter
pstapler's Avatar
I actually did review those stands today. Yes I have already ordered and received the Def Tech system. I have several constraints I am having to work within...including and most important, my wife.
Thank you for posting.
Zorba922 likes this.
pstapler is offline
post #4 of 10 Old 02-14-2020, 08:23 PM
Quoted: 421 Post(s)
Liked: 319
When I had the 800s I found the Def Tech stands to be well worth it, particularly at the discounted price you can often find them at.
KSpan is online now
post #5 of 10 Old 02-14-2020, 08:57 PM
RayGuy's Avatar
Quoted: 3168 Post(s)
Liked: 2965
These seem to fit the bill at a reasonable price:
https://www.amazon.com/dp/B002HZHUCW..._t2_B00170O1J8
or these:
https://www.amazon.com/ECHOGEAR-Adju...07C9CTWS7ZCMCX
It's a VIRTUAL channel unless stated otherwise.
RayGuy is offline
post #6 of 10 Old 02-15-2020, 05:55 AM - Thread Starter
pstapler's Avatar
I did review the DT stands and I like them. However, I’m afraid the base is too large for the area I need to place them. I actually have a set of the first Amazon link posted in our kids room. I’m good with those, but they didn’t meet my wife’s approval.
I’m leaning towards these... https://www.amazon.com/dp/B07925B8PD/?coliid=I2Z55ZTTG84JWV&colid=2I4CA97FKP4P&psc=1&re f_=lv_ov_lig_dp_it
Because I think I can position the feet in a manner to fit where I need them. Some have complained they aren’t well made. Can’t expect much for $35 I presume.
Thank you all for the suggestions.
pstapler is offline
post #7 of 10 Old 02-15-2020, 01:53 PM
RayGuy's Avatar
Liked: 2965
Looks like a good choice. Pics when it's all set up!
RayGuy is offline
post #8 of 10 Old 02-15-2020, 04:00 PM - Thread Starter
pstapler's Avatar
Copy that. My neighbor finished building my built-in shelves today. He's bringing them over tonight. I got the front L/R wired and mounted today. Didn't know the ProCenter 1000 needed special mounts. Ordered those today. I think my wife is getting tired of this project and I needed to work on my racecar today...fun times.
pstapler is offline
post #9 of 10 Old 02-15-2020, 08:47 PM
Liked: 2
Only responding because I can relate some, and I found the similarity amusing. I've been fussing with my HT setup in the basement since Christmas, picked up some new stuff today that I now need to spend tomorrow installing/running cable for. What I SHOULD be doing, is putting the engine back in my autocross car.
FISHTAILN5OH is offline
post #10 of 10 Old 02-16-2020, 04:52 AM - Thread Starter
pstapler's Avatar
I hear you. It’s a damned if you do and damned if you don’t. Need to get this done, need to get that done...
pstapler is offline
Reply Speakers
