What speakers do I keep for my theater? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By eljaycanuck
post #1 of 15 Old 02-14-2020, 06:53 PM - Thread Starter
dykstrajl's Avatar
I am getting ready to finish my basement and build out a dedicated theater room with two rows of seating. The second row will be on a platform. Dimensions of the room will be roughly 21.5' x 13' with an 8.5' ceiling. I am trying to figure out which speakers that I currently own I am going to build the system with. I will need to add speakers to the system unless I use a hodgepodge of them. I plan on doing a 7.1.4 system with a projector. 90% of the use will be watching movies/tv.
What I need help with is determining which speakers I utilize and add to. I know I will need to get ceiling speakers for the heights, but just curious on your thoughts. I plan to run a processor and amps as well so power shouldn't be an issue.
Speakers I currently have that are available for the theater.
KEF
2 - Q350
1 - Q650c
2 - Kube 12b subs
2 - Q500
2 - Q5
2 - Q1
1 - Q9c
B&W
2 - 704 s1
2 - CDM SNT
1 - HTM7
2 - DS6
Klipsch
2 - Chorus II
1 - RW10d sub
1 - R10SWi sub
Thank you in advance for your input
dykstrajl is offline
post #2 of 15 Old 02-14-2020, 06:59 PM
eljaycanuck's Avatar
Quoted: 2022 Post(s)
Liked: 2877
IMO:
- For the LCR, keep the ones that sound best to you.
- For all other speakers, keep the ones that are the best overall fit to the LCR and to the available space.
- For subwoofers, get two (or more) of something better.
eljaycanuck is offline
post #3 of 15 Old 02-14-2020, 07:03 PM - Thread Starter
dykstrajl's Avatar
IMO:
- For all other speakers, keep the ones that are the best overall compromise (best overall sound, best fit to space, best integration with LCR, etc.).
Thank you for the reply. Is timber matching not much of a thing for side, rear and height speakers? The front I would imagine it being pretty important, but never gave much thought to the rest.
post #4 of 15 Old 02-14-2020, 07:08 PM
Liked: 2877
Timber matching matters most up front, where the bulk of the audio content is handled.
raistlin65 likes this.
post #5 of 15 Old 02-14-2020, 07:22 PM - Thread Starter
dykstrajl's Avatar
post #6 of 15 Old 02-15-2020, 10:31 AM
Ryan Statz's Avatar
Quoted: 760 Post(s)
Liked: 437
Originally Posted by dykstrajl View Post
i am getting ready to finish my basement and build out a dedicated theater room with two rows of seating. The second row will be on a platform. Dimensions of the room will be roughly 21.5' x 13' with an 8.5' ceiling. I am trying to figure out which speakers that i currently own i am going to build the system with. I will need to add speakers to the system unless i use a hodgepodge of them. I plan on doing a 7.1.4 system with a projector. 90% of the use will be watching movies/tv.
What i need help with is determining which speakers i utilize and add to. I know i will need to get ceiling speakers for the heights, but just curious on your thoughts. I plan to run a processor and amps as well so power shouldn't be an issue.
Speakers i currently have that are available for the theater.
Kef
2 - q350
1 - q650c
2 - kube 12b subs
2 - q500
2 - q5
2 - q1
1 - q9c
b&w
2 - 704 s1
2 - cdm snt
1 - htm7
2 - ds6
klipsch
2 - chorus ii
1 - rw10d sub
1 - r10swi sub
thank you in advance for your input
kef
Home Theatre: Onkyo TX-NR747 | Polk Audio RTi A3 Front L/R | Polk Audio CSi A6 Centre | Polk Audio RTi A1 Surround L/R | HSU ULS-15 MK2 Subwoofer | Sony XBR55X900E | PlayStation 4 Pro | Xbox One S
Music: Cambridge Audio AXR100 | Stanton T.62 | Cambridge Audio AXC35 | KEF Q150 L/R
Ryan Statz is online now
post #7 of 15 Old 02-15-2020, 08:01 PM - Thread Starter
dykstrajl's Avatar
Originally Posted by Ryan Statz View Post
kef
Thanks for the reply. Just curious is there any specific reasoning?
post #8 of 15 Old 02-15-2020, 08:23 PM
Ryan Statz's Avatar
Quoted: 760 Post(s)
Liked: 437
I think they're arguably the better speakers. Plus, it looks like you'd have the least amount of adding to/replacing if you have all of those that are listed.
post #9 of 15 Old 02-16-2020, 01:25 AM
pase22's Avatar
Quoted: 3650 Post(s)
Liked: 3099
Kef image very well, project a wide soundstage, and have excellent detail and clarity. Kef is also known to have excellent off axis performance which can be advantageous if you have listeners sitting off center. They will also perform quite well musically.
Kef LS50,Q200C, Q100, Kef Kube 10B (X2) , Denon AVR-X3400H, NAD 216 THX, Panasonic 50" Plasma, Xbox One.
Bedroom: Kef Q100 ,JBL Loft 20, SVS SB-2000, Denon AVR-S710W, PS3, 32" Insigna LED.
pase22 is offline
post #10 of 15 Old 02-16-2020, 05:07 AM
spacecowboy's Avatar
Quoted: 198 Post(s)
Liked: 157
Tough choice. All are worthy. If I had a gun to my head.....Kef.
"Excuse me...What does God need with a Starship?" (Captain Kirk - Star Trek V: The Final Frontier)
spacecowboy is offline
post #11 of 15 Old 02-16-2020, 07:14 AM
altpensacola's Avatar
Quoted: 297 Post(s)
Liked: 173
Klipsch
2 - Chorus II
1 - RW10d sub
1 - R10SWi sub
USE the Chorus and a sub in the critical 2 channel music listening room!
Hey Kids Rock and Roll, Rock on.
Music, more music.
altpensacola is offline
post #12 of 15 Old 02-16-2020, 07:55 AM
Quoted: 27 Post(s)
Liked: 51
Use the KEF speakers. They are great.
Get some 12" ported subs from HSU Research, Rythmik Audio, or SVS. You'll appreciate the difference over the ones you have.
raistlin65 is online now
post #13 of 15 Old 02-16-2020, 06:47 PM
Elihawk's Avatar
Quoted: 2000 Post(s)
Liked: 2157
What do you have...a speaker warehouse?
A others have said, I would pick the set you enjoy the most. If you like abit dynamic and forward, the Kefs or Klipsch would be the choice. If you prefer neutral and accurate, the B&W would be great..
And again, as others have said...you got lot of good speaker choice, but you are lacking in good sub choices! Ditch the Klipsch subs, IMHO, at the very least!
Set up #1: EMP e5Ti, e5Ci, and EMP e5Bi surrounds, Outlaw LFM1 Plus sub, SVS NSD SB12 sub, Marantz Slimeline 1504 AV receiver
Set up #2: Def Tech SM450, CLR2002, SLS Qline surrounds and EMPtek10i10i sub, Denon 1910 AV receiver
Set up #3: Philharmonics- BMR in a 2.0 system, music only, Yamaha RXV-363 AV receiver
Elihawk is offline
post #14 of 15 Old 02-16-2020, 08:59 PM
Quoted: 27 Post(s)
Liked: 51
Have you looked at your own forum signature?
post #15 of 15 Old Yesterday, 05:06 AM
Elihawk's Avatar
Liked: 2157
Guilty as charged, but that doesn't make it right! Yes, I got two 5.1 systems and a 2.0 and a closet full of misc old speakers/sub.
Elihawk is offline
Reply Speakers
