Best center for Dolby Atmos - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By oldtexasdog
post #1 of 12 Old 02-19-2020, 08:38 AM - Thread Starter
oldtexasdog's Avatar
Quoted: 27 Post(s)
I am looking for the best dialog centric center for Dolby Atmos.
Space--24" X 12" x 19"
Denon X3300W
Fronts B&W 705
In ceiling RSL X 4
Subs 2 X Sunfire Sig's
Room size 25' X 30'
The B&W HTS 7 is too high and will not fit. The Denon has a very good Audessey
set up to timber match whatever I put in so I am looking for something that I will not have to turn the volume way up to hear the dialog. Music is not important as I use a different system for that.
I have been looking at the Klipsch RC-62 II ?
There are two holes in Daddys head where all the money goes.
oldtexasdog is offline
post #2 of 12 Old 02-19-2020, 01:01 PM
Kini62's Avatar
Quoted: 2841 Post(s)
Liked: 2735
Denon X3300W
Fronts B&W 705
In ceiling RSL X 4
Room size 25' X 30'
Audyssey can't change the timbre of the speaker. It can only eq to a predetermined curve or if you have the app you can tweak the eq your self. It won't fundamentally change the tone of the speaker.
You might be better off finding a speaker that fits that uses a dome tweeter of some type. The SVS Prime or Ultra or Aperion Versus or Nova centers would be good candidates to try and both include 2 way shipping and generous trial periods.
Another speaker that is worth looking at is the RSL CG52.
Def Tech SC8000
Onkyo RZ820
Roku Ultra, Apple TV, Sharp 70" Quattron
Kini62 is offline
post #3 of 12 Old 02-19-2020, 03:06 PM
Quoted: 308 Post(s)
Liked: 113
What are the measurement constraints for a center speaker?
Boombox13 is online now
post #4 of 12 Old 02-19-2020, 03:39 PM
sdurani's Avatar
Quoted: 7613 Post(s)
Liked: 6788
From the original post:
Denon X3300W
Fronts B&W 705
In ceiling RSL X 4
Room size 25' X 30'
Sanjay
sdurani is offline
post #5 of 12 Old 02-19-2020, 04:15 PM - Thread Starter
Quoted: 27 Post(s)
Thanks I will check those suggestions out.
post #6 of 12 Old 02-19-2020, 04:27 PM
Kipa's Avatar
Quoted: 93 Post(s)
Liked: 34
Kipa is offline
post #7 of 12 Old 02-20-2020, 04:50 AM - Thread Starter
Quoted: 27 Post(s)
Originally Posted by Kipa View Post
That would certainty fit but I worry about the rear ports and the fact that it will be in a basically 3 sided open front box in the AV cab that I use.
post #8 of 12 Old 02-20-2020, 06:36 AM
216dB Shockwave of pain
Adamg (Ret-Navy)'s Avatar
Quoted: 1065 Post(s)
Liked: 2508
Denon X3300W
Fronts B&W 705
In ceiling RSL X 4
Room size 25' X 30'
I just happen to have one for sale. https://www.avsforum.com/forum/209-a...l#post59004712
AdamG, ...out!
The government cannot give to anybody,
anything that the government does not first,
take from somebody else.
Adamg (Ret-Navy) is offline
post #9 of 12 Old 02-20-2020, 02:29 PM - Thread Starter
Quoted: 27 Post(s)
Thanks that's a great price!! I have adjusted my thinking though, with all I have been finding out and am now leaning toward either a Aperion Versus II (not sure if it will fit so need to make up a mock frame) or a Aperion 5C, or a Elac Debut C6.2. They all closer fit the B&W 705's as far as specs go. I am thinking 3 way.
Kini62 likes this.
post #10 of 12 Old 02-20-2020, 08:57 PM
dswierenga's Avatar
Quoted: 139 Post(s)
Liked: 174
How much are you planning to spend?
NHT SuperCenter is $125 on Amazon. It's a sealed acoustic suspension model.
The NHT C-LCR is about $500 direct from NHT. It's the center I use and I recommend it.
https://www.nhthifi.com/products?cat...enter-speakers
Panasonic TCP65VT60, Denon AVR-x6200w
Oppo UDP-203, Dish Hopper
NHT C4 front speakers, NHT C LCR center spkr
NHT Classic 3 surrounds
Velodyne Optimum 12 & DLS-5000R subs
dswierenga is offline
post #11 of 12 Old 02-21-2020, 05:42 AM - Thread Starter
Quoted: 27 Post(s)
I will check them out thanks.
post #12 of 12 Old 02-21-2020, 05:44 AM - Thread Starter
Quoted: 27 Post(s)
Have looked at that one and the B&W HTM61 S2 but they have rear ports so I would have to bung them and that messes with the sound I would think?
However I found a Aperion Intimus 5C for a good price and think I will try it.
Reply Speakers
