Polk CSI a4 or a6? - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 2 Post By Sean Spamilton
post #1 of 14 Old 02-19-2020, 06:31 PM - Thread Starter
mchief117's Avatar
Liked: 1
Polk CSI a4 or a6?
Hi everyone. Im looking to upgrade my current Polk HT system: TSI 400, CS10 center, Polk sub and Denon x2500 receiver. The receiver is a recent upgrade and havent made any real adjustements. Im looking to buy the Polk RTi A7. Curious to hear people's thoughts on the center channel... a4 vs a6. I have the room for the a6. But, it seems big. my issue now is hearing dialogue when watching movies. Thanks.
mchief117 is offline
post #2 of 14 Old 02-19-2020, 06:37 PM
Sean Spamilton's Avatar
Quoted: 448 Post(s)
Liked: 555
Definitely the a6 - its dialogue is very clear, I had one myself.
Ryan Statz and SaskCanesFan like this.
Denon X-4300 | Onkyo M-282 | Audio Technica AT-LP3 | HTPC |
Polk RTiA3 x 6 - RTiA6 x 1 - Polk Atrium 5 x 4 | PSA 15s | PSA XS30
Epson HC 2100 | 100" Elite Screen |
Sean Spamilton is offline
post #3 of 14 Old 02-19-2020, 06:39 PM
Ryan Statz's Avatar
Quoted: 925 Post(s)
Liked: 616
If you're getting the RTiA7s, then the CSiA6 is the better choice. I have both center channel speakers. The A4 is also good, but the A6 will pair better with the A7s.
And yes, it is fairly sizeable, but it shouldn't be a problem if you have the room.
Home Theatre: Marantz SR6014 | Polk Audio RTi A3 Front L/R | Polk Audio CSi A6 Centre | Polk Audio RTi A1 Surround L/R | HSU ULS-15 MK2 Subwoofer | Sony XBR55X900E | PlayStation 4 Pro | Xbox One S | Nintendo Switch
Music: Cambridge Audio AXR100 | Stanton T.62 | Cambridge Audio AXC35 | KEF Q150 L/R
Ryan Statz is online now
post #4 of 14 Old 02-19-2020, 06:52 PM
rhelliott2's Avatar
Quoted: 303 Post(s)
Liked: 567
You can probably save some $$ if you can find a older CSi5 center.
rhelliott2 is offline
post #5 of 14 Old 02-19-2020, 10:19 PM
Zorba922's Avatar
Quoted: 8298 Post(s)
Liked: 6332
A6 over A4, mismatched center over both.
Or, if you get either Polk center, make sure you have a good return policy just in case.
Let's just say that nobody buys Polk centers except Polk owners chasing the "timbre matching" unicorn.
As opposed to all the happy owners of for example, Chane A2.4 or Emotiva C1 or C2 deliberately bought for use with mismatched L/R speakers.
~ Are you a "geek hobbyist" obsessed with squeezing out that last 5-10% improvement? The economy will thank you...especially the Chinese one. Or are you more of a get-set-and-forget "casual user" who simply wants to increase your enjoyment of movies, TV and gaming? Relax, HT isn't rocket science, nor does it have to cost an arm and a leg---especially if you ignore the aforementioned vocal minority. And remember to smile...it's just a silly hobby, after all. :)
Zorba922 is offline
post #6 of 14 Old 02-20-2020, 02:39 AM
pase22's Avatar
Quoted: 3713 Post(s)
Liked: 3159
Are you dead set on the A7's?
What is your budget?
What sub(s) do you currently have?
Kef LS50,Q200C, Q100, Kef Kube 10B (X2) , Denon AVR-X3400H, Panasonic 50" Plasma, Xbox One.
Bedroom: Kef Q100 ,JBL Loft 20, SVS SB-2000, Denon AVR-S710W, PS3, 32" Insigna LED.
pase22 is offline
post #7 of 14 Old 02-20-2020, 04:19 AM - Thread Starter
mchief117's Avatar
Liked: 1
Thanks everyone. Appreciate the comments
post #8 of 14 Old 02-20-2020, 04:23 AM - Thread Starter
mchief117's Avatar
Liked: 1
Im not dead set on the rti a7. I still need to go to best buy and listen to them. I currently have the Polk PSW10 10-Inch sub. Budget is under $1000 for 3.1 setup
post #9 of 14 Old 02-20-2020, 09:56 AM
Zorba922's Avatar
Liked: 6332
With $1K you can get 3 much better bookshelf speakers with a decent sub, or at least as a second PSW10 if you're really happy with it.
Or even a great pair of towers that cost the same as good pair of bookshelf speakers: the Emotiva T-Zero ($400/pr) with C1 center ($200) then add an RSL Speedwoofer 10S ($400) ... I'd take that over the Polk RTiA7 + CSiA6 by a country mile.
Zorba922 is offline
post #10 of 14 Old 02-20-2020, 10:07 AM
macgallant's Avatar
Quoted: 797 Post(s)
Liked: 516
I've spend a lot of time with the A6 center and it doesn't fair well at high volumes.
Dialogue gets muddy but at low/moderate volumes it was ok.
Depending on your listening habits it may/may not be an issue.
I would take up Zorba's suggestions
Speakers: KEF Q100, Q300, Q750, Q650C, Q50a / Fluance Signature Series/ DCM TP160S-CH Subwoofers: Outlaw Ultra X12 (x2) / BIC H100-IIReceiver: Denon AVR-X4500H, AVR-X1400H Integrated Amplifier: Yamaha A-S501/ Fosi Audio TPA3116 mini amp Extras: MiniDSP Umik-1 Amplifier: Emotiva BasX-A300 Next Speakers: Triangle BR03, Revel Concerta2 M16, Dynaudio Emit M20, Buchardt S400, Triangle Comet ez, KEF R3
macgallant is offline
post #11 of 14 Old 02-20-2020, 10:29 AM
Ryan Statz's Avatar
Quoted: 925 Post(s)
Liked: 616
How high of a volume level are we talking about?
post #12 of 14 Old 02-20-2020, 10:43 AM
macgallant's Avatar
Quoted: 797 Post(s)
Liked: 516
-5 to 0 MV
MLP roughly 6-7ft.
Although it did slightly improve once my friend added his Emotiva BasX 5175.
His old AVR-x2200w may of been running out of steam.
I personally don't listen that loud, at most -15 to-7 but often around -20.
post #13 of 14 Old 02-20-2020, 10:45 AM
Ryan Statz's Avatar
Quoted: 925 Post(s)
Liked: 616
-5 to 0 MV
MLP roughly 6-7ft.
Yeah, that's pretty loud. The relative MV on my Onkyo is generally -32db to -42dB, and I sit somewhere between 5-6 feet away.
post #14 of 14 Old 02-20-2020, 03:15 PM - Thread Starter
mchief117's Avatar
Liked: 1
Thanks. I dont want book shelf speakers for my front left/right speakers. But i will look into the towers you mentioned.
Reply Speakers
