Convince me not to buy a soundbar! - AVS Forum | Home Theater Discussions And Reviews
 6Likes
post #1 of 41 Old 02-21-2020, 05:24 PM - Thread Starter
Malodium's Avatar
Quoted: 63 Post(s)
So I am finally in the process of finishing my basement and the expensive (for me anyway) 5.1 sound system and Denon receiver are moving downstairs to be hooked up to a projector. I bought them a year ago thinking I was going to be ready for them back then, but wasn't, so they have been hooked up to my TV upstairs this whole time. That monolith 15" sub is taking up a lot of room though! I am going to miss them upstairs and want to replace it all with something fairly inexpensive but an upgrade over the TV speakers (LG 65" oled).
I have looked at sound bars a bit, but I know that with a bit of know how, I should be able to purchase a 3.1 system that could crush most soundbars for not too much moola. I hesitate at buying a second receiver (no way really of hooking them up to the one downstairs), but if it's cheap enough and will do the trick, I might be able to do it.
I was hoping to keep it all under $500 though. Is that even going to be possible?
Thanks for the help
Malodium is offline
post #2 of 41 Old 02-21-2020, 05:33 PM
taz291819's Avatar
Quoted: 445 Post(s)
Liked: 333
I'd go with a HTIB over a sound bar any day. And then replace speakers/sub/AVR one by one as you're able.
And the HTIB wouldn't go to waste at the end. You can put it out in the garage, backyard, etc.
EDIT:
And don't forget you can always buy used gear. If you live in the Tampa area, there is a killer deal on ebay right now:
https://www.ebay.com/itm/Jbl-7-Chann...sAAOSwyJVdXz2j
Vizio P65-C1 (2016)
Onkyo Tx-NR656 (5.1.2 setup)
JBL Studio S-Center, JBL Studio S26ii (FL/FR), JBL N24 (LS/RS), JBL N24 (Overhead Atmos), JBL Studio SUB250
Nvidia Shield TV 2019 Pro / Fire Stick 4K
taz291819 is offline
post #3 of 41 Old 02-21-2020, 05:36 PM
mastacow53's Avatar
Quoted: 31 Post(s)
Soundbars are a major cause of ED.
D Bone likes this.
mastacow53 is offline
post #4 of 41 Old 02-21-2020, 05:39 PM
Transistorious's Avatar
Quoted: 148 Post(s)
Liked: 69
EDIT:
The best course of action. That JBL speaker set looks promising.
Transistorious is online now
post #5 of 41 Old 02-21-2020, 05:39 PM
Quoted: 141 Post(s)
Liked: 162
I agree with the HTIB route. I have an Energy Take Classic 5.1 and love it. It's in my den and it's really great for what it is. Look it up online, you won't find many, if any, negative reviews. Look on that auction site and you will find it is well under your budget.
Gary Mertz is offline
post #6 of 41 Old 02-21-2020, 05:41 PM
lizrussspike's Avatar
Quoted: 1445 Post(s)
Liked: 2156
If you're like 60 then probably not worried about ED, and want a soundbar in the room
lizrussspike is offline
post #7 of 41 Old 02-21-2020, 05:42 PM
Quoted: 560 Post(s)
Liked: 497
You could get close with DCM speakers. They are on closeout and very nice sounding.
3 way tower.
https://pricedrightsales.com/product...p260-ch-2-pack
2 way tower
https://pricedrightsales.com/product...p160-ch-2-pack
Center
https://pricedrightsales.com/product...-mtx-tp160c-ch
See what receivers Accessories4less has cheap. They also have Boston Acoustics on sale so check them out also. Very good for the price.
https://www.accessories4less.com/mak...ceivers/1.html
Sub is going to be a challenge.
cocrh is offline
post #8 of 41 Old 02-21-2020, 05:56 PM
taz291819's Avatar
Quoted: 445 Post(s)
Liked: 333
3 way tower.
2 way tower
Center
If that's not his primary display, he could get by without a sub if the mains are 3-way (and decent).
Vizio P65-C1 (2016)
post #9 of 41 Old 02-21-2020, 06:01 PM
taz291819's Avatar
Quoted: 445 Post(s)
Liked: 333
I was going to buy that set, but it's an 11-hour drive each way for me.
Vizio P65-C1 (2016)
post #10 of 41 Old 02-21-2020, 06:04 PM - Thread Starter
Malodium's Avatar
Quoted: 63 Post(s)
I probably should have mentioned, I dont have room for towers. I need bookshelves. For some reason I was thinking that people looked down on an HTIB quite a bit, so I had not looked into that.
I dont really really need a sub, but, I really really want one And it would be best of course with only bookshelves.
I should probably also mention, I do have a very old 5.1 Polk RM6000BD speaker set. Its not bad, but wanted a bit of an upgrade.
Ok I can maybe go a bit over $500.....
Malodium is offline
post #11 of 41 Old 02-21-2020, 06:25 PM - Thread Starter
Malodium's Avatar
Quoted: 63 Post(s)
Ok how about this. I buy that Denon 5.2 receiver on Accessories4less for $188, then get the best LRC bookshelf speakers I can for under $400. I can worry about a sub later. I am going to be watching movies downstairs anyway. This will mostly be for Netflix while eating dinner, stuff like that.
In that case, maybe some speaker recommendations in that range? Thanks all.
I could get a pair of CBM-170 SE from Ascend for $300 on sale right now, and grab an HTM-200 center for $160. Would be in the $700 range at that point, but sure would be nice stuff. Although those speakers are kind of on the large side. Center wouldn't even fit under my TV I dont think lol.
Lp85253 and PlanetAVS like this.
Malodium is offline
post #12 of 41 Old 02-21-2020, 06:36 PM
Quoted: 2326 Post(s)
Liked: 2000
that's actually a good idea..
YAMAHA TSR 5790.. front l/r Dennis Murphy modded emotiva b1's ..BIC v1220.....Emotiva basx10.... infinity alpha 20 center.. polk t15 rears..samsung 55" j620d
bedroom .. YAMAHA r-xv 383... front l/r.. ascend cbm 170 se... kef q100 center ... Emotiva basx8... samsung ku6300 50 in
Lp85253 is offline
post #13 of 41 Old 02-21-2020, 06:40 PM
Quoted: 148 Post(s)
Liked: 69
i was going to buy that set, but it's an 11-hour drive each way for me.
ouch
post #14 of 41 Old 02-21-2020, 07:09 PM
Alex F.'s Avatar
Quoted: 1008 Post(s)
Liked: 609
Here is my preference over a soundbar, an excellent 2.0 system:
For use by my wife and myself only (no guests) in our theater room, we prefer using the two-channel phantom mode.
If I had to choose between a tiny center speaker or phantom mode with nice main speakers, as suggested below, I would go with phantom mode every time, even with visitors filling the room.
For slightly more than your stated budget consider a Yamaha AV receiver ($250) and a nice pair of loudspeakers, such as Wharfedale 225s ($300) from their highly regarded Diamond series. The speakers have a 6.5-inch bass driver, which would provide a very nice low end. If desired, add a little bass boost with the AVR's tone control or EQ. An inexpensive pair of speaker stands, if you do not have any, are available from Amazon for about $60.
Links:
https://www.crutchfield.com/p_022RXV...a-RX-V385.html
https://www.crutchfield.com/p_336D22...nut-Pearl.html
https://www.crutchfield.com/p_336D22...Blackwood.html
Music room: Cary SLI-80 tube integrated amplifier, McIntosh MA6500 integrated amplifier, Quad 99 preamp, Quad 909 power amp, Acoustic Research AR9 loudspeakers, Yamaha CD-N500 CD player, Teac UD-503 DSD DAC, Phase Linear 8000 II linear-tracking turntable.
Theater room: Panasonic 65S60 plasma television; Yamaha RX-A2020 (preamp section); Adcom GFA-5503 and GFA-5400 amplifiers; Polk LSi25, LSiC, and LSiF/X loudspeaker system; Velodyne FSR-18 servo-subwoofer.
Alex F. is offline
post #15 of 41 Old 02-21-2020, 07:15 PM
Anderegg's Avatar
Quoted: 617 Post(s)
Liked: 361
How about a compromise?
I use a Definitive SSA42 soundbar...passive, meaning it's a long soundbar filled with larger than your average powered soundbards speakers, full 5.1 set on the bar. The SSA50 is for larger TV's...it's basically a convinient way to mount/hold a full set of speakers under the front of the TV if you are limited on room to position them all over the place on stands or such. Just add an A/V receiver of your choice.
Paul
*they are cheaper on the used market ;-)
https://www.definitivetechnology.com.../mythos-ssa-50
Sony X900F SDR and HDR Calibrations https://www.avsforum.com/forum/166-l...l#post57551552
Anderegg is offline
post #16 of 41 Old 02-21-2020, 07:55 PM
Quoted: 560 Post(s)
Liked: 497
Then have a look at those Boston A26 or A25 bookshelf speakers (buy one get one 1/2 off) at Accessories4less. The A225C is the center model.
A26
https://www.accessories4less.com/mak...ck-each/1.html
A25
Center A225C
https://www.accessories4less.com/mak...r-black/1.html
cocrh is offline
post #17 of 41 Old 02-21-2020, 08:14 PM
_tk
Quoted: 727 Post(s)
Liked: 338
What about something like this? Pair it with a decent receiver and it'd make a nice small setup under a TV.
https://www.parts-express.com/dayton...black--300-686
_tk is offline
post #18 of 41 Old 02-21-2020, 08:38 PM
RayGuy's Avatar
Quoted: 3332 Post(s)
Liked: 3132
If you want the entire bundle (sans receiver):
https://www.parts-express.com/dayton...oofer--300-747
Or save even more with the 10" sub ...
Seems to me both the MK402x and MK442 were reviewed here (Jim Wilson?) a number of months ago and were said to well outperform their price tag. BTW, if you are expecting the sub bundled with this set of speakers to perform anything like the Monolith it replaces, you are just kidding yourself. In this price range, there will be compromises, especially in bass performance.
It's a VIRTUAL channel unless stated otherwise.
RayGuy is online now
post #19 of 41 Old 02-21-2020, 09:44 PM
Ryan Statz's Avatar
Quoted: 920 Post(s)
Liked: 611
Don't buy a sound bar.
DavAbq likes this.
Home Theatre: Marantz SR6014 | Polk Audio RTi A3 Front L/R | Polk Audio CSi A6 Centre | Polk Audio RTi A1 Surround L/R | HSU ULS-15 MK2 Subwoofer | Sony XBR55X900E | PlayStation 4 Pro | Xbox One S | Nintendo Switch
Music: Cambridge Audio AXR100 | Stanton T.62 | Cambridge Audio AXC35 | KEF Q150 L/R
Ryan Statz is online now
post #20 of 41 Old 02-21-2020, 10:03 PM
taz291819's Avatar
Quoted: 445 Post(s)
Liked: 333
All of suggestions above are good ideas, can't knock any of them. It really depends on the sound you like.
Since I don't know where you live, I don't know if that link I posted is an option (no, I'm not the seller, and don't know them). But those S38's are great bookshelf speakers, and they are 3-way. I'm more jealous that I can't buy them due to no shipping, but would rather an AVS member get them than someone that doesn't really care about sound. Back in the day (2000), that set new would have cost around ~$1500, even without a sub.
Vizio P65-C1 (2016)
post #21 of 41 Old 02-21-2020, 10:29 PM - Thread Starter
Malodium's Avatar
Quoted: 63 Post(s)
I am rather distant. SE Idaho.
I am somewhat interested in the two-channel phantom mode Alex mentioned above. There is precious little space below the TV. It's wall mounted, and I like them lower than most people, and there is a large cabinet right under it that is only a year old and im not moving it so there . I just went and measured and I only have 4 inches between the cabinet and the bottom of the screen.
So, something like the Definitive speaker bar mentioned, or the two-channel phantom mode. I could spend more obviously on a nice pair of bookshelves if I didn't bother with a center channel. I assume this phantom mode something that is set up in the receiver?
Malodium is offline
post #22 of 41 Old 02-21-2020, 10:33 PM
Ryan Statz's Avatar
Quoted: 920 Post(s)
Liked: 611
Sort of. You just don't connect a center channel speaker, and set the AVR to 2.1/4.1/6.1.
Going phantom center is not a bad option, either if space under the TV is rather tight for your conventional center channel speaker.
post #23 of 41 Old 02-21-2020, 10:40 PM - Thread Starter
Malodium's Avatar
Quoted: 63 Post(s)
A lot of people seem to really like the Wharfedale Diamond 225s. Would those work nicely without a center or sub? With possibly getting a sub later?
I guess if I am assuming around $200 for a lower end receiver, about $300 for the bookshelves would be about right, which is what the Wharfedale cost.
There is also a pair of refurb KEF Q150s on accessories4less for $300. And I guess, for that matter a pair of Canton Chrono 502.2 for $279.
Guess I need to start reading up on all these speakers at this level!
Malodium is offline
post #24 of 41 Old 02-21-2020, 10:52 PM
PlanetAVS's Avatar
Quoted: 2349 Post(s)
Liked: 2261
Get 3 NHT Super Ones with a used 5.1 AVR from Craigslist. Add the RSL Speedwoofer sub later when budget permits
https://www.amazon.com/NHT-SuperOne-...H3P0KGE6RNKQ8D
PlanetAVS is offline
post #25 of 41 Old 02-21-2020, 10:54 PM
taz291819's Avatar
Quoted: 445 Post(s)
Liked: 333
Remember, if you're going without a sub, you want 3-way speakers for your mains.
Vizio P65-C1 (2016)
post #26 of 41 Old 02-21-2020, 10:56 PM - Thread Starter
Malodium's Avatar
Quoted: 63 Post(s)
I do plan on adding a sub at some point.
I have been finding many threads about bookshelves in this price range. The options are many it looks like. Maybe I need to narrow it down by use. These will be almost 100% used for watching crap on Netflix, Amazon etc.... not too much music.
Malodium is offline
post #27 of 41 Old 02-21-2020, 11:05 PM
taz291819's Avatar
Quoted: 445 Post(s)
Liked: 333
Than bookshelf and a sub is what you want.
Music is a little different, but it really comes down to your preference. IMO, the three speakers up front (LCR) are the most important, the sub is next, and the surrounds and overheads are last.
I like a warmer sound, something that soundbars and some brand of bookshelf speakers just don't do. But that's me.
Vizio P65-C1 (2016)
post #28 of 41 Old 02-21-2020, 11:10 PM
Ryan Statz's Avatar
Quoted: 920 Post(s)
Liked: 611
There aren't a lot of bookshelf speakers that wouldn't require a sub, especially if it's for a 100% HT set up.
The KEFs wouldn't be a bad idea.
post #29 of 41 Old 02-21-2020, 11:48 PM - Thread Starter
Malodium's Avatar
Quoted: 63 Post(s)
Welp, thanks all for the help in directing me. I just bought a Denon X1600H and a pair of KEF Q150s from accessories4less.
A little over budget but they were offering the full 3 year warranty on the receiver so I decided to get that one over a slightly less expensive one.
Now to prowl for a sub for purchase at some future date
pase22 likes this.
Malodium is offline
post #30 of 41 Old 02-21-2020, 11:57 PM
Ryan Statz's Avatar
Quoted: 920 Post(s)
Liked: 611
I run a pair of Q150s for my 2ch music area. They do well.
Reply Speakers
