best recommendations for 1000 or less a pair floorstanding speakers - AVS Forum | Home Theater Discussions And Reviews
 51Likes
post #1 of 93 Old 02-22-2020, 09:55 AM - Thread Starter
Quoted: 225 Post(s)
Liked: 147
I have a pair of emotiva t1 speakers ive grown tired of and looking to replace them. Im looking for a broad list of best bang for buck.
stngray72 is offline
post #2 of 93 Old 02-22-2020, 10:22 AM
pase22's Avatar
Quoted: 3713 Post(s)
Liked: 3159
What don't you like or would like improved?
Are you just looking for a different sound? Going to be hard to beat the T1's for under 1K.
Ryan Statz likes this.
Kef LS50,Q200C, Q100, Kef Kube 10B (X2) , Denon AVR-X3400H, Panasonic 50" Plasma, Xbox One.
Bedroom: Kef Q100 ,JBL Loft 20, SVS SB-2000, Denon AVR-S710W, PS3, 32" Insigna LED.
pase22 is offline
post #3 of 93 Old 02-22-2020, 10:26 AM - Thread Starter
Quoted: 225 Post(s)
Liked: 147
the bass on the t1's just isnt tight like i want them and the tweeters arent what i like either im more a silk dome person i guess. im driving the emotivas with a yamaha a860 reciever.
post #4 of 93 Old 02-22-2020, 10:31 AM
Ryan Statz's Avatar
Quoted: 925 Post(s)
Liked: 615
Do you have a subwoofer?
And to echo what @pase22 said - you probably won't find much outside of the Emotivas for less than $1k - DCM is the only thing that comes to mind.
Home Theatre: Marantz SR6014 | Polk Audio RTi A3 Front L/R | Polk Audio CSi A6 Centre | Polk Audio RTi A1 Surround L/R | HSU ULS-15 MK2 Subwoofer | Sony XBR55X900E | PlayStation 4 Pro | Xbox One S | Nintendo Switch
Music: Cambridge Audio AXR100 | Stanton T.62 | Cambridge Audio AXC35 | KEF Q150 L/R
Ryan Statz is online now
post #5 of 93 Old 02-22-2020, 10:38 AM - Thread Starter
Quoted: 225 Post(s)
Liked: 147
I do have a monolith 10 subwoofer and thats great but im not diggin the emotivas anymore. I do like the sound of focal a lot but id have to go bookshelf to get under 1000 a pair.
post #6 of 93 Old 02-22-2020, 10:52 AM
Ryan Statz's Avatar
Quoted: 925 Post(s)
Liked: 615
Are you 100% set on it being floorstanding? What's your room size? Distance sitting away from the speakers?
An option could be a pair of Ascend CMT-340 SE: http://www.ascendacoustics.com/pages...m/cmt340m.html
post #7 of 93 Old 02-22-2020, 10:59 AM - Thread Starter
Quoted: 225 Post(s)
Liked: 147
Its a small apartment. About 9 to 10 feet away. No im not set on it being floorstanding. Ill check those speakers out.
Lp85253 likes this.
post #8 of 93 Old 02-22-2020, 11:01 AM
Ryan Statz's Avatar
Quoted: 925 Post(s)
Liked: 615
Ascend is a top-notch ID company. You're going to get way more speaker per dollar than going with something like Focal, B&W, Monitor, ML, etc...
These Chanes could be an option as well: https://www.chanemusiccinema.com/ind...product_id=196 however, they're ribbon tweeters.
post #9 of 93 Old 02-22-2020, 11:06 AM
mboy's Avatar
Quoted: 36 Post(s)
Liked: 49
Chane?
Sent from my SM-G960U using Tapatalk
TCL 65 6 Series
Firec TV Cube 4k
Denonn X3500H
Chane A5.5 L/R, A2.5 C, JBL E10s surrounds
HSU VTF 3 MK 5
mboy is offline
post #10 of 93 Old 02-22-2020, 11:12 AM
rhelliott2's Avatar
Quoted: 303 Post(s)
Liked: 567
Originally Posted by mboy View Post
Chane?
Chane makes amazing stuff. They do have a ribbon tweeter tho.
rhelliott2 is offline
post #11 of 93 Old 02-22-2020, 11:19 AM
Quoted: 2327 Post(s)
Liked: 2003
personally , and this is just thinking out loud , i don't think you are going to get a significant upgrade at under $1000.. why not try to go "the extra yard" and save a bit and maybe try some ascend sierra towers or the 2ex .. you might get a significant upgrade in sq trying some $1000 level books (nht c3, sierra 1, dynaudio emit 10 or 20, ect.).. but trying other $900 floorstanders is going to be trading one set of problem for another set...jmo, ymmv .. best of luck ....
YAMAHA TSR 5790.. front l/r Dennis Murphy modded emotiva b1's ..BIC v1220.....Emotiva basx10.... infinity alpha 20 center.. polk t15 rears..samsung 55" j620d
bedroom .. YAMAHA r-xv 383... front l/r.. ascend cbm 170 se... kef q100 center ... Emotiva basx8... samsung ku6300 50 in
Lp85253 is offline
post #12 of 93 Old 02-22-2020, 11:19 AM - Thread Starter
Quoted: 225 Post(s)
Liked: 147
Honestly so far im looking to try the focal chorus 706 for 400 a pair. I am listening to recomendations and searching about brands.
Lp85253 likes this.
post #13 of 93 Old 02-22-2020, 11:23 AM - Thread Starter
Quoted: 225 Post(s)
Liked: 147
aperion looks like some good stuff and decent prices???
post #14 of 93 Old 02-22-2020, 11:30 AM
Ryan Statz's Avatar
Quoted: 925 Post(s)
Liked: 615
Focal wouldn't be a bad choice, especially if you know you like their sound.
Lp85253 likes this.
post #15 of 93 Old 02-22-2020, 11:34 AM - Thread Starter
Quoted: 225 Post(s)
Liked: 147
these aperion
Verus III Grand Bookshelf Speaker
looks nice too
Lp85253 likes this.
post #16 of 93 Old 02-22-2020, 11:36 AM
pase22's Avatar
Liked: 3159
Since you have a decent sub, you should go down to BB and listen to KEF LS50's. Detail and clarity and overall resolution would be a step up and they would be in budget.
https://www.accessories4less.com/mak...te-pair/1.html
Ryan Statz and Lp85253 like this.
pase22 is offline
post #17 of 93 Old 02-22-2020, 01:50 PM - Thread Starter
Quoted: 225 Post(s)
Liked: 147
Jbl studio 530 seem interesting or even the 580's
post #18 of 93 Old 02-22-2020, 02:18 PM
Quoted: 308 Post(s)
Liked: 115
For $200.00 more you can get Canton Chrono SL 596 DC (599.99 ea @ A4L) which will easily smoke your Emotivas (Definitely more for your money).
https://www.accessories4less.com/mak...ck-each/1.html
If you want bookshelves.....Canton Vento, Canton Chrono SL, Canton Chrono, or Kef.....all at A4L.
A quote from Zorba922 (Anyone compared Emotiva T2+C2 vs Chane A5. 5 +2.4? post #6 )
"I'd put the Chane and Emotiva speakers neck and neck---can't go wrong with either"
So don't bother with Chane....it will be more of the same.
Lp85253 likes this.
59" Samsung Series 7000 Plasma TV Samsung BD-D5500 Blu-ray player
Onkyo TX-NR609 AV Receiver
Canton TBD (Center) Canton Chrono SL 596 DC (L & R)
JBL SP6CII (Frt Height & RR Surround)
Martin Logan Dynamo 1000
Boombox13 is offline
post #19 of 93 Old 02-22-2020, 02:26 PM
zieglj01's Avatar
Quoted: 3379 Post(s)
Liked: 3278
I prefer the DCM TFE60 over the Focal and JBL Studio 530 -- I would put DCM on a short list ... the seller is a good one
https://pricedrightsales.com/product...479ade25&_ss=r
Lp85253 and Deaf-Forever like this.
Who AM I
zieglj01 is offline
post #20 of 93 Old 02-22-2020, 02:33 PM
zieglj01's Avatar
Liked: 3278
If you are game -- then look hard at the Canton Vento with their ceramic tweeter
https://www.accessories4less.com/mak...ck-pair/1.html
Who AM I
zieglj01 is offline
post #21 of 93 Old 02-22-2020, 02:37 PM - Thread Starter
Quoted: 225 Post(s)
Liked: 147
Thanks for the heads up i was just going to ask about the cantons. Ill have to wait to have enough to get them but it will be worth it i think.
post #22 of 93 Old 02-22-2020, 02:43 PM
Ryan Statz's Avatar
Quoted: 925 Post(s)
Liked: 615
I don't think Chane is the same as Emotiva, so ignore that. You can scratch Chane off of your list if you're not a fan of the ribbon tweeter, though.
So far, there are no bad choices. You couldn't go wrong with Ascend, Focal, Chane, Canton, etc... Even KEF Q350s or 150s could be a decent choice.
post #23 of 93 Old 02-22-2020, 02:49 PM
jwskud's Avatar
Quoted: 172 Post(s)
Liked: 422
According to the research I did (on here and elsewhere), the Emotivas are really, really good speakers at their price point. I was guided more towards Chanes (A5.4s) because the Emotivas are 4 ohm and the Chanes are purported to hold their composure better at high volumes. So while some called it a toss-up (including the very knowledgeable @Zorba922 , others thought the Chanes were a slight step up and added top-end smoothness (ribbon tweeter).
I will say I've never read a comment from anyone saying they didn't like the Chanes, and that the "openness" and clarity they provide at their price point are stellar. For more info, check out the Chane link in my signature (it includes links to lots of shootouts/comparison threads), or go query Jon Lane (owner of Chane) on the Chane owners thread.
I couldn't be happier with my A5.4s, but my in-person listening experience is limited.
Chane A2.4 center, Chane A5.4s L/R, Chane A1.5s surround, Kenwood KS-505HTs rear
Sub: Klipsch R-120SW [wish list = Rythmik FV18 Rev2 (paper cone)]; Rythmik FAQ
Onkyo TX-RZ620, Samsung 4k 43NU7100, PS3
Protection: Tripp Lite Isobar 8 Ultra and Isobar 4; Aircom T10; VCE SP250-2P-CA
jwskud is offline
post #24 of 93 Old 02-22-2020, 03:03 PM
bear123's Avatar
Quoted: 3249 Post(s)
Liked: 4879
Revel F35. Should be close to your budget with a good deal.
JD23 and SinGA like this.
bear123 is offline
post #25 of 93 Old 02-22-2020, 03:31 PM
RayGuy's Avatar
Quoted: 3334 Post(s)
Liked: 3132
https://www.whathifi.com/reviews/dali-oberon-5
If tight bass is the top priority, look at Dynaudio products.
KenM10759, Spectah and morasp like this.
It's a VIRTUAL channel unless stated otherwise.
RayGuy is offline
post #26 of 93 Old 02-22-2020, 04:41 PM
Quoted: 308 Post(s)
Liked: 115
Here is a link to a variety of comparisons between these speakers: Canton, Focal, Kef, Dali, Monitor, Elac, BNS, Phillips, & Heco.
https://www.youtube.com/channel/UC-y...a4G9KSQ/videos
post #27 of 93 Old 02-22-2020, 05:21 PM
JD23's Avatar
Quoted: 764 Post(s)
Liked: 468
Yes, they should be only above his budget by a small amount and are a legitimately good speaker.
SinGA likes this.
JD23 is offline
post #28 of 93 Old 02-22-2020, 06:07 PM
Quoted: 119 Post(s)
Liked: 70
I like the recommendation above about saving up. However, if you’re looking to liven up the sound (note that it might not necessarily tighten up the bass) you can get close to $1K on my Dali Zensors 7s. I have to say these are fun.
Would also look at Monitor SE 6000F for $1K, but I tend to like a bigger sound. The bass will be tighter here but not as full at your T1s.
Main 7.1 HT: Dali Zensor (7s, Vokal, and 1s), Emotiva E2s, HSU ULS-15 MK2, Emotiva BasX preamp/amps (MC-700, A-300, A-500)
Kid’s 5.1 HT: Dali Oberon (5s, Vokal), RSL C34Es, HSU VTF-2 MK5, Denon X2400H
7-Zone CCA/Spotify WHA: Paradigm (E-80Rs x6, P-80SM), Def Tech AW6500s, Polk MC-80, Emotiva BasX amps (A-700, A-500), FiiO D3 DACs
Spectah is offline
post #29 of 93 Old 02-23-2020, 01:19 AM - Thread Starter
Quoted: 225 Post(s)
Liked: 147
I am going to add the kef q 750's to the list they are only 1000 a pair too.
Lp85253 likes this.
post #30 of 93 Old 02-23-2020, 01:29 AM
iamsabit313's Avatar
Quoted: 76 Post(s)
Liked: 76
Klipsch RP8000F. Can be had under $800 if bought from a dealer.
JBL Stage A190. $700 from various online dealers. (this speaker retails for 4 times more outside of North America, i have no idea why)
Both are efficient (in room 98db and 97db) and moderate impedance drops, should get you to reference with midrange avrs.
Screen: Elite Aeon, 138-inch 2.35:1, Subwoofer: Rythmik FV18 ALC
Speakers: Klipsch Forte III LCR, Surrounds: Klipsch RP 502s
AVR: Yamaha RX-A3080, Projector: Sony 695ES
Media: nVidia Shield Pro running custom Kodi api with 72tb Media Storage
iamsabit313 is offline
Reply Speakers
