Tweeter height - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 03-25-2020, 04:26 AM - Thread Starter
Quoted: 143 Post(s)
Liked: 165
Tweeter height
Im getting ready to perform a bookshelf shootout among 4 speakers that will serve as surrounds for the base layer. I'd like some help determining tweeter height so I can order strands that will at least approximate getting the tweeters at my sitting ear height. Any measurements you can offer would be appreciated! Contenders in no particular order:
Chane A1.5
PSB Imagine XB
Ascend Sierra 1
Aperion Verus III
I'd like to add the Emotiva B1+ but they are out of stock presently. Hopefully they will get back in stock soon as if like to be able to consider them as well.
Thanks for any help you can offer!
Gary Mertz is online now
post #2 of 8 Old 03-25-2020, 05:16 AM
Transmaniacon's Avatar
Quoted: 1799 Post(s)
Liked: 1666
Chane A1.5
PSB Imagine XB
Ascend Sierra 1
Aperion Verus III
Tweeters should be at ear-level. Sit in a chair how you would listen and measure floor to ear height. Since you're demoing several speakers with varying sizes, consider an adjustable height speaker stand.
5.1: Samsung PN60F5300 | Sony BDP-S1700 | Denon AVR-1713 | EMP E55Ti | EMP E56Ci | EMP E5Bi | Outlaw Ultra-X12
2.0: Oppo DV-980H | Apple Airport Express | Schiit SYS | Topping D30 | Parasound HCA-1500a | Chane A1.4
Transmaniacon is online now
post #3 of 8 Old 03-25-2020, 07:17 AM - Thread Starter
Quoted: 143 Post(s)
Liked: 165
Yes I understand the tweeter height, hence the question. I haven't however come across any adjustable stands that are as substantial as what I would prefer such as offerings from Monoprice and Sanus. I prefer mass loaded stands. Maybe there are good sturdy stands that are adjustable? Does anyone have a link to such a stand?
Also, anyone with the speakers I listed, I'd like to know what your measurement is from bottom of speaker to tweeter center if you could please share?
post #4 of 8 Old 03-25-2020, 07:42 AM
Liked: 1666
You probably won't find such a stand as there needs to be room for the adjustable mechanism. I would probably just get some small end tables from your house and use them during demos, and then buy a nice fixed height stand once you know which speaker you will be keeping. You can use some books to provide decoupling for the speakers.
post #5 of 8 Old 03-25-2020, 08:03 AM
Zorba922's Avatar
Quoted: 8298 Post(s)
Liked: 6333
These are not mass loaded but are adjustable and can handle up to 80lbs:
https://www.amazon.com/Hola-Music-Pr...dp/B07F3XLPNL/
Have never seen any mass-loaded stands that ARE adjustable, come to think of it.
~ Are you a "geek hobbyist" obsessed with squeezing out that last 5-10% improvement? The economy will thank you...especially the Chinese one. Or are you more of a get-set-and-forget "casual user" who simply wants to increase your enjoyment of movies, TV and gaming? Relax, HT isn't rocket science, nor does it have to cost an arm and a leg---especially if you ignore the aforementioned vocal minority. And remember to smile...it's just a silly hobby, after all. :)
Zorba922 is offline
post #6 of 8 Old 03-25-2020, 08:11 AM
JonfromCB's Avatar
Quoted: 261 Post(s)
Liked: 186
Google "images of speaker stands". You will see several sort options such as "bookshelf", "adjustable", etc. If you see something you are interested in click it to go to product website.
JonfromCB is offline
post #7 of 8 Old 03-25-2020, 11:34 AM
bobknavs's Avatar
Quoted: 2684 Post(s)
Liked: 1921
These aren't as elegant as Zorba922's suggestion (post 5), but I have a pair, and they're serviceable, if unlovely. https://www.amazon.com/ZENY-Monitor-...ruments&sr=1-1
They're of generic Chinese origin, so you may be able to find identical ones for less.
They have pins that lock the height, so you wouldn't have to worry about the clamp slipping with heavy speakers.
For extra weight and ugliness, set bags of steel shot on the base. (Sand isn't dense enough. Lead shot isn't environmentally friendly.)
bobknavs is offline
post #8 of 8 Old 03-25-2020, 04:47 PM - Thread Starter
Quoted: 143 Post(s)
Liked: 165
All great suggestions and I thank you for the input. I think I'll maybe cobble something together or use some old end tables for now. I like the idea of settling on the speaker before buying the stands.
Thanks, guys!
Reply Speakers
