Cube speakers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 03-25-2020, 11:40 AM - Thread Starter
Quoted: 100 Post(s)
Cube speakers
I recently put together a small home theater. Large screen, projector, emotiva fronts & center, and a sub as well. Anyways I know I am going to get a whole bunch of replies posting garbage, but I would have to assume *some* surrounds are better than none. With that said, I am looking for tiny footprint satellites for surround speakers. Wife has come around on the screen and my front speakers are quite large so she has been insisting on small or no speakers for surround. Anyone have recommendations on like 3x3" or 4x4" cubes?
Patrick Flaherty is offline
post #2 of 8 Old 03-25-2020, 12:47 PM
afrogt's Avatar
Quoted: 2326 Post(s)
Liked: 1520
Maybe something like this would interest you? Basically 3x3x3"
https://www.cambridgeaudio.com/usa/e...rs/minx-min-12
I have a lightly used set of Energy RC Micro, still have the original box if you're interested. Just the speakers, not the sub.
https://www.crutchfield.com/S-DsVdJ7...Micro-5-1.html
PM me if interested...
Afro GT
afrogt is offline
post #3 of 8 Old 03-25-2020, 01:43 PM
Zorba922's Avatar
Quoted: 8298 Post(s)
Liked: 6333
Could you live with 5.5" W x 9" H x 5" D sealed cabinet?
NHT SuperZeros, $68 ea. on Amazon
~ Are you a "geek hobbyist" obsessed with squeezing out that last 5-10% improvement? The economy will thank you...especially the Chinese one. Or are you more of a get-set-and-forget "casual user" who simply wants to increase your enjoyment of movies, TV and gaming? Relax, HT isn't rocket science, nor does it have to cost an arm and a leg---especially if you ignore the aforementioned vocal minority. And remember to smile...it's just a silly hobby, after all. :)
Zorba922 is offline
post #4 of 8 Old 03-25-2020, 02:26 PM
RayGuy's Avatar
Quoted: 3334 Post(s)
Liked: 3132
From a recent post:
As to smaller speakers, they vary quite a bit in price and performance, but none will give you much in the way of bass performance. Your subwoofer will need to be capable up to 150 Hz, perhaps higher, to fill in the mid-bass for these channels. Some of the better options are: Focal Dome Flax Satellite, Gallo A'diva / Micro, Cambridge Audio Minx Min 12 / 22, Monitor Audio Mass Satellite Mist (new version is a small cube vs old hexagon shape). There are also lesser (and less expensive) options on Amazon, etc. That should be enough to get you started.
It's a VIRTUAL channel unless stated otherwise.
RayGuy is offline
post #5 of 8 Old 03-25-2020, 03:41 PM
Quoted: 953 Post(s)
Liked: 778
Use in-walls with paintable. You won't have to look at them...
sigpig is offline
post #6 of 8 Old 03-25-2020, 08:09 PM
Elihawk's Avatar
Quoted: 2063 Post(s)
Liked: 2226
The CA Minx, the Kef egg and the Orb speaker were the best small speakers around...maybe 5 years ago when I was interested. Those Energy 5.1 were amongst the most recommended budget systems a few years back, i didn't know they still made them.
Set up #1: EMP e5Ti, e5Ci, and EMP e5Bi surrounds, Outlaw LFM1 Plus sub, SVS NSD SB12 sub, Integra AV receiver
Set up #2: Def Tech CA Aero 2, CLR2002, SLS Qline surrounds and EMPtek10i10i sub, Slimline AV receiver
Set up #3: Philharmonics- BMR in a 2.0 system, music only, Integra AV receiver
Elihawk is online now
post #7 of 8 Old 03-25-2020, 08:20 PM
aerodynamics's Avatar
Quoted: 311 Post(s)
Liked: 136
I use a pair of Cambridge Min 12s for side surrounds and have been amazed by the sound they put out. I've always been curious what a full Atmos setup would sound like as their dispersion is so wide.
Chiq B5U | 100” Snowhite UST Screen | Pioneer Elite LX-503 | 7.2.4 Surround | Sony Core Series LCR + Atmos | Cambridge Min 12 Side Surrounds | Monoprice Rear Atmos Surrounds | Bic V1020 x2
aerodynamics is offline
post #8 of 8 Old 03-25-2020, 08:49 PM
afrogt's Avatar
Liked: 1520
They stopped making those Energy RC Micro a long time ago. I used mine for a little while then moved up to bigger speakers. I think they'd be good as surround/Atmos speakers.
The Minx look good and I've read positive things about them.
Afro GT
afrogt is offline
Reply Speakers
