Getting ready for a speaker shootout - AVS Forum | Home Theater Discussions And Reviews
 17Likes
  • 2 Post By aarons915
  • 1 Post By Zorba922
  • 1 Post By Gary Mertz
  • 1 Post By torii
  • 2 Post By Elihawk
  • 2 Post By craig john
  • 1 Post By thebrieze01
  • 3 Post By PhilharmonicDennis
post #1 of 26 Old 03-25-2020, 07:22 PM - Thread Starter
Quoted: 107 Post(s)
Liked: 78
I have ordered 4 pairs of bookshelves from different manufacturers. I'll be making a thread for that with the contenders being from PSB, Ascend, Aperion, and Chane. I wanted to add Emotiva but they are out of stock. Hoping they will get them so I can add them into the fray. Yes there are others I could add, dozens of them in fact. My choices are based on reviews and measurements I have read.
In the interim I'd like to run my methodology by you and see if you have any input.
1. Run all speakers through a 72-hour break-in period. Probably around 80-85 dB pink noise run 24/7.
2. Arbitrarily pick 2 sets at a time to go head-to-head. Loser is returned.
3. Listen to the same base playlist then expand from there depending on what I hear. So, for example, if I listen to John Rutter's Requiem and question the choral sound maybe I'll put in something from Chanticleer or King's Singers to investigate more.
4. Take copious notes along the way of course.
5. Room setup: The actual theater needs to be painted and carpet installed so the setup will be my PC playing FLAC audio through an Integra 9.9 in a guest bedroom. Amp will be a Bryston 9BST, XLR connection to the Integra. I have some nice Analysis Plus Oval 12 wire that I'll use. I'll have to set the speakers on old end tables, something I'll cobble together to get the tweeters at ear height.
6. Level match using my trusty Radio Shack decibel meter.
Any opinions/changes/etc that you think I should consider before I start the fun?
Gary Mertz is offline
post #2 of 26 Old 03-25-2020, 08:59 PM
rhelliott2's Avatar
Quoted: 297 Post(s)
Liked: 558
IMO REW sweeps would be nice along with your impressions. Also, would playing music instead of pink noise be better for break-in?
rhelliott2 is offline
post #3 of 26 Old 03-25-2020, 09:06 PM
aarons915's Avatar
Quoted: 1147 Post(s)
Liked: 921
Those are good choices for speakers, I also think the KEF Q150 is a great budget speaker and are 299 right now. As far as your methodology, the break-in isn't really necessary but you could play each speaker a couple hours if it gives you peace of mind. It all depends on how serious you want to take it but the more biases you can remove the better, level matching is good. I personally find it easier and simpler to compare speakers in mono now, just have some way of switching back and forth instantly. If you have some kind of brand bias you'll probably want to do it blind but if not I don't think it's as big of a deal as some make it.
vzphoneman and Lp85253 like this.
aarons915 is online now
post #4 of 26 Old 03-25-2020, 10:17 PM
Zorba922's Avatar
Quoted: 8251 Post(s)
Liked: 6299
1. The Emotiva B1 is out of stock, but you could still get the T-Zero to hear the Emotiva house sound because even though it's a tower, it's only $400/pr so it's very close to the same price range as the other speakers you're considering (possibly less once the cost of stands is figured in). The fact that it's a a small tower while the others are bookshelves will be largely nullified if you do #3 .
2. Great instructions on speaker break in: https://www.cambridgeaudio.com/usa/e...w-run-speakers
3. If your system is going to have a subwoofer(s), then I would test the speakers WITH the subwoofer(s) turned on and with a standard 80Hz crossover. Why? Because otherwise your selection of which is the "better" speaker will be heavily biased by which speaker puts out the most mid-bass when running full range...which is completely useless if your planned system is going to have them running crossed over with a sub, not running full range.
4. When comparing speakers head to head, be sure to stagger them: A B A B not A B B A. This ensures that each pair will be the same distance from your main listening position.
sigpig likes this.
~ Are you a "geek hobbyist" obsessed with squeezing out that last 5-10% improvement? The economy will thank you...especially the Chinese one. Or are you more of a get-set-and-forget "casual user" who simply wants to increase your enjoyment of movies, TV and gaming? Relax, HT isn't rocket science, nor does it have to cost an arm and a leg---especially if you ignore the aforementioned vocal minority. And remember to smile...it's just a silly hobby, after all. :)
Zorba922 is offline
post #5 of 26 Old 03-26-2020, 04:23 AM - Thread Starter
Quoted: 107 Post(s)
Liked: 78
Excellent points all. I think I will cross all of them over but without the sub. If the sub is in play I know I'll be distracted if it is not optimally placed. In my last theater I spent weeks upon weeks getting it just right and I really don't want to go through that right now especially since this testing is all going to be done outside the theater. There aren't really any speaker bias issues because I haven't heard any of them before. Im thinking of setting the speakers as different zones but I think I'll still need to level match and im not sure if I can set the integra to do that automatically from zone to zone. I'll have to look it up in the manual. I also like the idea of blind testing, which I will follow.
Lp85253 likes this.
post #6 of 26 Old 03-26-2020, 04:46 AM - Thread Starter
Quoted: 107 Post(s)
Liked: 78
I meant also to add that the Emotiva suggestion was good too but they weigh 80 pounds for the pair and are larger of course. Return shipping would be quite expensive.
Lp85253 likes this.
post #7 of 26 Old 03-26-2020, 06:57 AM
josh6113's Avatar
Quoted: 304 Post(s)
Liked: 144
I'd recommend the JBL 530 bookshelves....free shipping both ways.I just bought my second pair and they will be here in a few hours...
Sent from my MHA-L29 using Tapatalk
Doing what I do best...LIVIN!
josh6113 is online now
post #8 of 26 Old 03-26-2020, 09:23 AM
Zorba922's Avatar
Liked: 6299
Maybe consider the HTD Level 3 bookshelves too, since these come with free return shipping.
rhelliott2 likes this.
Zorba922 is offline
post #9 of 26 Old 03-26-2020, 09:29 AM
torii's Avatar
Quoted: 4105 Post(s)
Liked: 2384
I would come up with some fun/unique tests outside of your normal regime. maybe some sort of port wind or vibration test, best hear a pn drop test, best sound while balancing on head, largest spl from your kitchen....idk, something outside of norm...
MUDCAT45 likes this.
Power: Marantz sr7008, NAD C 275Bee x 2, Video: Oppo 103, Samsung 75un6300 LG oled c9 77
Speakers: Focal aria 948, Focal cc900, Klipsch synergy KSF 10.5, Magnepan LRS, Audioengine A2+
Subs: Rythmik FV25HP, Rythmik FV15HP, Velodyne HGS 12, Velodyne VA1512
torii is online now
post #10 of 26 Old 03-26-2020, 09:42 AM
Elihawk's Avatar
Quoted: 2048 Post(s)
Liked: 2211
That will be an excellent analysis...I look forward to your impressions. What, you aren't doing a double blind study with NASA scientists (Harmon) and independant companies doing your data analysis!?
Zorba922 and MUDCAT45 like this.
Set up #1: EMP e5Ti, e5Ci, and EMP e5Bi surrounds, Outlaw LFM1 Plus sub, SVS NSD SB12 sub, Integra AV receiver
Set up #2: Def Tech CA Aero 2, CLR2002, SLS Qline surrounds and EMPtek10i10i sub, Slimline AV receiver
Set up #3: Philharmonics- BMR in a 2.0 system, music only, Integra AV receiver
Elihawk is online now
post #11 of 26 Old 03-26-2020, 12:28 PM
craig john's Avatar
Quoted: 1439 Post(s)
Liked: 1733
I get your sarcasm. Nonetheless, I think an element of blind testing is very useful. Someone else mentioned removing as many biases as possible. I agree with this. The biggest bias that can be introduced is *seeing* which speaker is being heard. Making a portion of the testing blinded adds considerably to the complexity of the comparison. However, it would make the results much more interesting and useful, IMO.
Craig
Edit: I also agree with another poster that in-room measurements would be enlightening.
rhelliott2 and DavidK442 like this.
Lombardi said it:
"Perfection is not attainable, but if we chase perfection we can catch excellence.
My System
(Edited Feb. 2020 to add 4K and Atmos updates)
craig john is offline
post #12 of 26 Old 03-26-2020, 02:53 PM - Thread Starter
Quoted: 107 Post(s)
Liked: 78
All great ideas again. I ordered the JBLs so that will be 5 contenders. I'm keeping it to a max of 6 so I'm leaving that 6th slot open in case Emotiva gets their bookshelves in stock, and I hope they do.
Interestingly enough the last pair I ordered, the PSBs, showed up first today. Off I go to get the room set up. As soon as anything else comes in, let the listening begin! Again, I'll start a new thread for that and I may go ahead and set up the thread tonight or tomorrow just to get it started.
post #13 of 26 Old 03-26-2020, 03:17 PM
Quoted: 2320 Post(s)
Liked: 1988
speaking as an emo b1 owner, you don't need(imo) to include them right now..other good options out there.. one thing you may want to try ... if you can swing it , grab some elac dbr 62's.. i would think they would blow away the rest of that crowd ,, and probably be easily returned ..edit: the ascend cbm 170's are darn good if those are the ones you ordered.. i'll be interested to see how you like them..
YAMAHA TSR 5790.. front l/r Dennis Murphy modded emotiva b1's ..BIC v1220.....Emotiva basx10.... infinity alpha 20 center.. polk t15 rears..samsung 55" j620d
bedroom .. YAMAHA r-xv 383... front l/r.. ascend cbm 170 se... kef q100 center ... Emotiva basx8... samsung ku6300 50 in
Lp85253 is offline
post #14 of 26 Old 03-26-2020, 03:30 PM
Quoted: 131 Post(s)
Liked: 72
Seconded. The Elac DBR 62, is definitely worth a listen. They have measured “very” well if you google for the review with measurements. There is a you tube video as well where Andrew Jones talks about about all the bracing in the cabinet and new drivers.
Lp85253 likes this.
thebrieze01 is offline
post #15 of 26 Old 03-26-2020, 03:48 PM
Quoted: 404 Post(s)
Liked: 979
That would be my pick as well, based on the Audio Science measurements, which suggest that Andrew might have finally got it right. Unfortunately, I believe they're out of stock now.
dbPlan, Lp85253 and BufordTJustice like this.
PhilharmonicDennis is offline
post #16 of 26 Old 03-26-2020, 03:51 PM
Quoted: 115 Post(s)
Liked: 411
elac dbr62
dbPlan is offline
post #17 of 26 Old 03-26-2020, 04:16 PM
Liked: 1988
everything i've seen & heard leads me to believe that the db62's are going to sound a whole bunch like those b1's you modded with a better woofer and cab..i'm gonna grab a pair at my earliest opportunity..
Lp85253 is offline
post #18 of 26 Old 03-26-2020, 04:22 PM - Thread Starter
Quoted: 107 Post(s)
Liked: 78
The Elacs are indeed out of stock. I can find them but I would have to pay shipping both ways if I return them and that's not a cost I'm willing to absorb on top of what I've already got out there on the 5 pairs I have coming.
Lp85253 likes this.
post #19 of 26 Old 03-26-2020, 04:32 PM
Liked: 1988
oh well there's always "next time"..you might get my review soon..
Lp85253 is offline
post #20 of 26 Old 03-27-2020, 01:30 PM
gajCA's Avatar
Quoted: 9760 Post(s)
Liked: 6762
$600/pair.
Geoff A. J., California
gajCA is offline
post #21 of 26 Old 03-27-2020, 02:33 PM
Liked: 1988
Originally Posted by gajCA View Post
$600/pair.
yep ..and the sierra 1's he ordered are about 675.. i would love to hear a head to head review on those 2.i'm likely going to get the elac's but the sierra 1's are an option as well
Lp85253 is offline
post #22 of 26 Old 03-27-2020, 04:20 PM - Thread Starter
Quoted: 107 Post(s)
Liked: 78
Question about center channels: What would be the match for the Elacs and JBLs? The JBLs are coming, heavily interested in the Elacs.
post #23 of 26 Old 03-27-2020, 05:21 PM
Zorba922's Avatar
Liked: 6299
The JBL 520c is the supposed "matching" center for the 530s. Opinion seems fairly split on them; some people find their 4.5" woofers underwhelming, some are fine with them. If ordering from JBL you'll get free return shipping though.
The ELAC's center has gotten slightly more mixed reviews.
If it were me, if I decided on either of them, I'd go with a mismatched center that's a proven performer like the Emotiva C1/C2, Chane A2.4 or Ascend 340SE.
Zorba922 is offline
post #24 of 26 Old Yesterday, 05:58 AM - Thread Starter
Quoted: 107 Post(s)
Liked: 78
Good points, all, good feedback as always!
post #25 of 26 Old Yesterday, 12:06 PM
gajCA's Avatar
Liked: 6762
I have not read much criticism of JBL or Elac centers on AVS.
To be honest the only center I can think of that consistently gets low marks is the Pioneer SPC 22.
Some prefer the Polk S30 to the S35 but most that have to settle for the soundbar like size of the S35 are pleased.
gajCA is offline
post #26 of 26 Old Yesterday, 12:20 PM
djp2k7's Avatar
Quoted: 407 Post(s)
Liked: 327
Why are there two threads about this?
The dbr62's are in stock at music direct
Polk LSIM 703 / ADS L710 / AKG K240 Studio cans / Martin Logan Dynamo 300
NAD 720Bee / Schiit Modi 3 / Yamaha CD-S300 / XBOX One X
djp2k7 is online now
Reply Speakers
