Raising Center channel height? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By Transmaniacon
post #1 of 2 Old 03-26-2020, 04:32 AM - Thread Starter
mboy's Avatar
Quoted: 34 Post(s)
Liked: 45
Hey all. Currently running Chane 5.5s with a 2.4 as a center channel. Very happy with the setup Btw
TV is wall mounted and we're getting a new TV console which is a good deal shorter than our current (which the 2.4 is about perfect height at horizontally).
My plan was to turn the 2.4 vertical and rotate tweeter, but that now puts me 2" too high.
SO, I need to keep it horizontal, but raise it 6-8" to get tweeter height where it should be.
Anyone reco an inexpensive solution?
Didn't see much in way of center channel stand that makes sense so far. Thought about high density foam pads, etc.
TCL 65 6 Series
Firec TV Cube 4k
Denonn X3500H
Chane A5.5 L/R, A2.5 C, JBL E10s surrounds
HSU VTF 3 MK 5
mboy is online now
post #2 of 2 Old 03-26-2020, 05:50 AM
Transmaniacon's Avatar
Quoted: 1797 Post(s)
Liked: 1659
You could use a center channel wall mount like this: https://www.amazon.com/Pyle-Speakers...s%2C137&sr=8-3
You could get some angled speaker pads and point it at your ears.
They make some short center channel stands, but they are probably a bit too high. You could however get a monitor riser like this: https://www.amazon.com/VIVO-Ergonomi...226975&sr=8-26
That gets you pretty close and is right around the same footprint as the A2.4. You could get some slim foam wedges to angle it slightly as well and help decouple the speaker.
mboy likes this.
5.1: Samsung PN60F5300 | Sony BDP-S1700 | Denon AVR-1713 | EMP E55Ti | EMP E56Ci | EMP E5Bi | Outlaw Ultra-X12
2.0: Oppo DV-980H | Apple Airport Express | Schiit SYS | Topping D30 | Parasound HCA-1500a | Chane A1.4
Transmaniacon is offline
Reply Speakers
