Atmos heights, oh good grief... - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 25Likes
post #31 of 57 Old 05-16-2020, 06:38 AM - Thread Starter
Quoted: 411 Post(s)
Liked: 577
It looks like I've got several good options, that's excellent and of course thank you as always for the help. I think I'll make some basic cardboard cutouts to see how far the speakers would project. I'm really only concerned about how far down they will be when angled.
I'm in the process of building a new computer strictly for the theater and the parts should all arrive by the end of next week. The old computer I was using decided to throw a fit with the old Win 7 OS so I thought well screw it, just build a new one with better parts. I say all of that because my ability to run REW will be down for a little bit so my tuning-in phase is temporarily on hold. I think it wise to run some REW sweeps and potentially move the fronts back/forward, which of course would affect where the MLP is located.
Here's a pic of what I'm dealing with. Yes its sideways but it was the only way I could show you everything. The Studio 530 you see on the right hand side is how the sides will be situated regarding distance from the side wall. My position of the pilot holes are spot on as far as their distance to the side walls are as well. I think I will end up actually using those holes and mount speaker connectors there. That way there's no splicing and I'll need something up there anyway. Shouldn't look too bad, really. I have plenty of Sewell banana plugs and 12-gauge wire to make the runs from there to the speakers a perfect length. This is strictly a front-to-back positioning situation for the heights.
Gary Mertz is offline
post #32 of 57 Old 05-16-2020, 06:40 AM
EAS
EAS's Avatar
Quoted: 48 Post(s)
Liked: 30
How about some of those Kef on-wall speakers like T101's?
EAS is offline
post #33 of 57 Old 05-16-2020, 06:44 AM - Thread Starter
Quoted: 411 Post(s)
Liked: 577
Good idea about the KEF's, I didn't know such a thin speaker even existed! Another great option but they are pretty expensive for heights.
post #34 of 57 Old 05-17-2020, 07:58 AM
EAS
EAS's Avatar
Quoted: 48 Post(s)
Liked: 30
Another Kef option is the shallow depth speakers. Ci160TR's. They only need about 1.4 inches from the surface.
What kind of ducting do you have there? Rigid or Flex? How far is it from the sheetrock?
EAS is offline
post #35 of 57 Old 05-17-2020, 11:34 AM - Thread Starter
Quoted: 411 Post(s)
Liked: 577
It is 1/2" sheetrock. Metal duct. I believe the duct work to be about 2-3 inches above the ceiling. I don't think it is any higher than that. I saw it when we were building out the room but after pouring over the pictures I don't have a clear shot of it and I question my memory this long after I closed it up. The other problem as I've just measured with a stud finder, is that there is a joist and a crazy network of blocking running (no clue what the builders were doing up there) right across where the rear heights would be. I think I'm going to be left with having to ceiling mount. I could drill a ton of pilot holes and might not be any closer to knowing whether or not I can fit a ceiling speaker up there.
post #36 of 57 Old 05-17-2020, 02:08 PM
taz291819's Avatar
Quoted: 459 Post(s)
Liked: 354
That looks like a very strong option. I wonder though how they would sound on their side? Of course they aren't designed for that but I'm not sure it would make that big of a difference in a height application. Any thoughts? The reason I ask is because I'm going to try to keep the heights as tight to the ceiling as possible. Mounting with the longest dimension of any of the speakers parallel to the floor is going to be preferable.
The Control-X's look like my N24's (which are all-weather as well). And I had to order the Control-X mounting kit for my N24's.
Gary Mertz likes this.
Vizio P65-C1 (2016)
Onkyo Tx-NR656 (5.1.2 setup)
JBL Studio S-Center, JBL Studio S26ii (FL/FR), JBL N24 (LS/RS), JBL N24 (Overhead Atmos), JBL Studio SUB250
Nvidia Shield TV 2019 Pro / Fire Stick 4K
taz291819 is offline
post #37 of 57 Old 05-17-2020, 03:14 PM - Thread Starter
Quoted: 411 Post(s)
Liked: 577
Polk S10
Looking at the Polk S10 there's a large plastic piece on the back of it that seems to serve no purpose except to contain the keyhole slot. Does anyone know if it is removable? Having it removed would make it easier to mount as a height speaker should I go that direction.
post #38 of 57 Old 05-17-2020, 03:35 PM
Ryan Statz's Avatar
Quoted: 1294 Post(s)
Liked: 1062
That *could* be what's holding the driver in place.
Home Theatre: Marantz SR6014 | KEF Q750 Front L/R | KEF Q650c Centre | KEF Q150 Surround L/R | HSU ULS-15 MK2 Subwoofer | Sony XBR55X900E | PS4 Pro | Xbox One S | Nintendo Switch
Music: Cambridge Audio AXR100 | Fluance RT85 | Ortofon 2M Blue | Cambridge Audio AXC35 | Neat Motive 3
Ryan Statz is online now
post #39 of 57 Old 05-17-2020, 04:13 PM - Thread Starter
Quoted: 411 Post(s)
Liked: 577
Ah well then I guess it might be frowned upon to remove!
It looks like a big heat sink although I know its not.
post #40 of 57 Old 05-17-2020, 04:48 PM - Thread Starter
Quoted: 411 Post(s)
Liked: 577
Just found a pic on Amazon, the piece on the back is part of their "Power Port." As such I doubt it can be removed.
post #41 of 57 Old 05-17-2020, 08:57 PM
Quoted: 1275 Post(s)
Liked: 1114
Gary, if you have to ceiling-mount your speakers, maybe give a thought to outdoor speakers. RSL, Plok, PSB, etc all make pretty darned good speakers that just happen to inhabit a weather-resistant cabinet.
The good thing about these is that they have their own mounting brackets: https://rslspeakers.com/rsl-outsider-ii-lp/
sigpig is offline
post #42 of 57 Old 05-17-2020, 09:02 PM
Ryan Statz's Avatar
Liked: 1062
Another option could be PSB Alpha P3: https://www.psbspeakers.com/product/...shelf-speaker/ - looks like you can screw mount something into the back
even lighter than the Polk S10, too.
post #43 of 57 Old 05-17-2020, 09:30 PM
Liked: 1114
I use these, and you can, since I did... lol
They actually have mini pilot holes so you don't have to worry about screwing into the crossover.
Ryan Statz and Gary Mertz like this.
sigpig is offline
post #44 of 57 Old 05-18-2020, 07:57 AM
EAS
EAS's Avatar
Quoted: 48 Post(s)
Liked: 30
I think you want to take into account the speaker coverage angle. You may be better off using an in-celing speaker by creating a little wart of drywall or a frame on the ceiling to give you enough depth and cavity for the speaker.
I suppose you have given up on the idea of upfiring Atmos speakers? You have a nice smooth ceiling that should reflect in a predicable way.
EAS is offline
post #45 of 57 Old 05-18-2020, 08:59 AM
BeeAVision's Avatar
Quoted: 97 Post(s)
Liked: 35
I had come across this video a few weeks ago when I was demoing the S20 in my home theater. Very interesting regarding the back rear port plate.
Projector: EPSON Home Cinema 1060 | Screen: 100" Silver Ticket (fixed/white) | Receiver: DENON X3600h (5.2.4) | Receiver fan: AC Infinity Aircom T8 | Blu-ray: Panasonic DP-UB420 | Logitech Harmony Hub | Amazon Echo Dot 3rd Gen. | Center: Emotiva Airmotiv C2+ | Front L/R: JBL Studio 530 & Klipsch RP-600M | Surrounds: Klipsch R-51M | Atmos: N/A | Sub: SVS PB-2000 Pro (dual) | Other: ELAC Debut 2.0 B6.2 & Polk Audio S20
BeeAVision is offline
post #46 of 57 Old 05-18-2020, 05:30 PM - Thread Starter
Quoted: 411 Post(s)
Liked: 577
I did think about upfiring modules but I am still of the belief that a direct firing speaker is going to outperform an upfiring unit. Good suggestion though, of course.
post #47 of 57 Old 05-18-2020, 05:52 PM - Thread Starter
Quoted: 411 Post(s)
Liked: 577
Some of the speakers, including those PSB Alpha P3's have waveguides. I wonder how much it would impact sound in a horizontal ceiling mount location?
I think it goes without saying that I'm probably overthinking the CRAP out of this. In my own defense though I've come so far I need to make sure I'm making the best decision.
It really comes down to timbre matching. If anyone has any additional input on that aspect of the search it would be greatly appreciated.
post #48 of 57 Old 05-18-2020, 06:46 PM
Ryan Statz's Avatar
Liked: 1062
I would not really be all that concerned with timbre matching Atmos. So little information actually gets passed through those speakers that it can be literally any speaker.
And as someone who is currently in transition with my own HT - I have a KEF Q650c as my CC running alongside the Polk mains, and I've not noticed a lick of difference unless, of course, they're voiced identically... which I doubt.
post #49 of 57 Old 05-18-2020, 06:46 PM
EAS
EAS's Avatar
Quoted: 48 Post(s)
Liked: 30
Maybe, but even Dolby suggests up firing speakers can sound better in a smaller room or a room without high ceilings. Rather than reinvent the wheel here I found another thread that discusses it. There are a couple of interesting posts from @RayGuy and @SuperFist .
https://www.avsforum.com/forum/91-au...l#post59542528
SuperFist and Gary Mertz like this.
EAS is offline
post #50 of 57 Old 05-18-2020, 06:59 PM - Thread Starter
Quoted: 411 Post(s)
Liked: 577
Good points, of course. If I don't concern myself with timbre matching it would go to the smallest contender, which I think would be the NHT Superzero.
Using an upfiring module would make wiring difficult. I'd have to open some of the side walls again, what a mess that would be.
post #51 of 57 Old 05-19-2020, 03:05 PM - Thread Starter
Quoted: 411 Post(s)
Liked: 577
Here's a question. Let's say I end up going for a speaker that really only plays well to, say, 100 Hz (I'm thinking here of the Superzeros, they are rated to 85 on the website but I'm not sure I believe that). I would think I'd want to cross them over at around 100 Hz. If I do so, then where do the frequencies between 100 and the standard crossover at 80 go for the heights? It seems there would be a gap that may (or may not) affect things. I don't plan on crossing the subs at anything higher than 80. Or it could be that I'm not thinking this through properly?
post #52 of 57 Old 05-19-2020, 04:22 PM
Ryan Statz's Avatar
Liked: 1062
Atmos shouldn't really need to be set at a crossover lower than 120 - 150Hz anyway.
khcoach likes this.
post #53 of 57 Old 05-19-2020, 05:24 PM - Thread Starter
Quoted: 411 Post(s)
Liked: 577
Super, I wasn't sure if there was substantial low frequency energy coming from the heights.
post #54 of 57 Old 05-19-2020, 05:31 PM
Ryan Statz's Avatar
Liked: 1062
Very little information goes through Atmos speakers - much less than surrounds.
post #55 of 57 Old 05-19-2020, 06:11 PM
Falonious's Avatar
Quoted: 142 Post(s)
Liked: 136
What about diys speakers? Some decent choices....if one is not opposed to that rout. I'm just asking if you ever thought of it.
All men dream: but not equally. Those who dream by night in the dusty recesses of their minds wake in the day to find that it was vanity: but the dreamers of the day are dangerous men, for they may act their dreams with open eyes, to make it possible.
T. E. Lawrence
Falonious is offline
post #56 of 57 Old 05-20-2020, 02:58 PM - Thread Starter
Quoted: 411 Post(s)
Liked: 577
Yes, indeed, and an excellent suggestion. However I'm already knee deep in building twin Devastators, had to fabricate a new top for my TV stand (not wide enough to support the new TV), and just today got the components for the new HTPC. I think I'm going to be all out of motivation to do much of anything else other than enjoy the system and start dialing it in!
However that being said, what would be some extra small options for a ceiling mount application?
post #57 of 57 Old 05-20-2020, 05:06 PM
Liked: 1114
Outdoor speakers usually come with their own mounting brackets and are ablt to be aimed wherever you want. RSL have some at $200/pr.
sigpig is offline
Reply Speakers
