Are towers they best way to go? - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 29Likes
post #31 of 69 Old 05-19-2020, 04:20 PM
Quoted: 49 Post(s)
Originally Posted by joxr View Post
If a choice between towers or large monitor speakers .. are towers the way to go if you can fit them even if you are running subs ? Because with subs you would be running the towers are small right ?
I struggled with the same question and ended up with JBL 590's which are a huge tower. I paired the JBL's with two SVS sb3000's I am wondering now if I could have achieved as good of sound with bookshelves such as the Chanes. My listening is more music than HT so I thought the towers were the way to go but now am leaning the other way.
Gary Mertz likes this.
JBL Studio 590's, Klipsch RP-450C, Polk TSI 500's, 2 SVS SB 3000's and a Sony 65" 850
mdildine is offline
post #32 of 69 Old 05-19-2020, 04:39 PM - Thread Starter
joxr's Avatar
Quoted: 120 Post(s)
Liked: 41
Originally Posted by bear123 View Post
Haha I was actually thinking about being able to repurpose the monitors if needed whereas tower speakers will always be tower speakers.
yup
5.2.4
joxr is offline
post #33 of 69 Old 05-19-2020, 04:39 PM
torii's Avatar
Quoted: 4378 Post(s)
Liked: 2540
most towers that can go low to 40hz or below will sound great with music and w/out a sub. ofc 1% of music out there goes really low...but my towers sound just fine without a sub and play over 100db. I only have some 4ohm maggie lrs which I can compare to bookshelves...they get to maybe 90db w/out subs.
Power: Marantz sr7008, NAD C 275Bee x 2, Video: Oppo 103, Samsung 75un6300 LG oled c9 77
Speakers: Focal aria 948, Focal cc900, Klipsch synergy KSF 10.5, Magnepan LRS, Audioengine A2+
Subs: Rythmik FV25HP, Rythmik FV15HP, Velodyne HGS 12, Velodyne VA1512
torii is online now
post #34 of 69 Old 05-19-2020, 05:31 PM
Quoted: 359 Post(s)
Liked: 510
I have the 590's, just getting used to them. Depends on the music whether or not the added benefits of the tower would be worth it. I'm still a proponent of towers over bookshelves.
To the OP, we're still waiting to hear your budget.
Ryan Statz likes this.
Gary Mertz is offline
post #35 of 69 Old 05-19-2020, 06:17 PM - Thread Starter
joxr's Avatar
Quoted: 120 Post(s)
Liked: 41
My budget is basically around what the arendals are. I was considering the PSAs but I just dont like the way they looks since it is not going into a dedicated theatre room.
5.2.4
joxr is offline
post #36 of 69 Old 05-19-2020, 06:17 PM
Ryan Statz's Avatar
Quoted: 1209 Post(s)
Liked: 891
State a number.
Home Theatre: Marantz SR6014 | Polk Audio RTi A3 Front L/R | KEF Q650c Centre | KEF Q150 Surround L/R | HSU ULS-15 MK2 Subwoofer | Sony XBR55X900E | PS4 Pro | Xbox One S | Nintendo Switch | TBA: KEF Q750 Front L/R
Music: Cambridge Audio AXR100 | Stanton T.62 | Cambridge Audio AXC35 | Neat Motive 3
Ryan Statz is offline
post #37 of 69 Old 05-19-2020, 06:33 PM - Thread Starter
joxr's Avatar
Quoted: 120 Post(s)
Liked: 41
Originally Posted by Ryan Statz View Post
State a number.
around 4k
5.2.4
joxr is offline
post #38 of 69 Old 05-19-2020, 06:38 PM
Ryan Statz's Avatar
Liked: 891
around 4k
Ascend Sierra towers w/ RAAL tweeter, and don't look back.
post #39 of 69 Old 05-19-2020, 07:23 PM
rhelliott2's Avatar
Quoted: 396 Post(s)
Liked: 715
I like that. Maybe two smaller sealed subs from Rythmik or RSL? IIRC OP's budget was a total $5k
rhelliott2 is online now
post #40 of 69 Old 05-19-2020, 07:25 PM
Quoted: 359 Post(s)
Liked: 510
Yes, they should be on a very short list in their price class. I know they are on my short list for when I want to upgrade!
post #41 of 69 Old 05-19-2020, 07:54 PM
Ryan Statz's Avatar
Liked: 891
He'll also have room left over for Dual HSU or Rythmik subs.
post #42 of 69 Old 05-20-2020, 04:38 AM
Quoted: 381 Post(s)
Liked: 155
It’s all personal preference.
What electronics are you planning to use?
Boombox13 is offline
post #43 of 69 Old 05-20-2020, 06:11 AM
Red MC's Avatar
Quoted: 369 Post(s)
Liked: 296
Unless I am looking at the wrong specs, its 89 for the monitors and 92 for the towers. This makes sense since doubling woofers adds 3 dB sensitivity. Am I looking at the wrong specs?
Monitors Freq response
Sealed 58-20kHz (+/-3dB)
2 vents 34-20kHz (+/-3dB)
89dB
Towers Freq response
Sealed 55-20kHz (+/-3dB)
3 vents 38-20kHz (+/-3dB)
2 vents 34-20KHz (+/-3dB)
92db
Sorry guys, my bad. I had mistakenly checked out the 1723 S series, where the difference was 88.7 vs 89.
I agree that 3 dB is a meaningful difference. However, it's rather impossible for me to believe. Sensitivity is measured with pink noise in the midrange, typically 300 Hz -3 KHz. The woofers in the tower model contribute nothing in that range. With the same mid-woofers and tweeters, 1500 Hz crossover, and nominal impedance, the sensitivity should be close to the same.
HT: Dynaudio C2, Contour S CX, 2x BM14S, Aperion surrounds, Simaudio Titan, Marantz AV8801, Oppo 103, Linn Majik DS, and a Pioneer Kuro
Stereo: Dynaudio Focus 160, Simaudio W-5 LE or Luxman M-600A, Linn Akurate DSM, 2x Rythmik F12G
Other interests: motorcycling, skiing, being active
Red MC is offline
post #44 of 69 Old 05-20-2020, 08:01 AM - Thread Starter
joxr's Avatar
Quoted: 120 Post(s)
Liked: 41
Probably a denon x4500 until the 2.1 avrs roll around. Monoprice or some comparable amp down the road.
bear123 likes this.
5.2.4
joxr is offline
post #45 of 69 Old 05-20-2020, 06:13 PM
bear123's Avatar
Quoted: 3479 Post(s)
Liked: 5314
It's a 2.5 way design. So one or more of the woofers are the midrange. Probably not as cut and dry as you assume.
bear123 is online now
post #46 of 69 Old 05-20-2020, 10:19 PM
Zorba922's Avatar
Quoted: 9076 Post(s)
Liked: 6974
What's a 2.1 AVR?
~ Are you a "geek hobbyist" obsessed with squeezing out that last 5-10% improvement? The economy will thank you...especially the Chinese one. Or are you more of a get-set-and-forget "casual user" who simply wants to increase your enjoyment of movies, TV and gaming? Relax, HT isn't rocket science, nor does it have to cost an arm and a leg---especially if you ignore the aforementioned vocal minority. And remember to smile...it's just a silly hobby, after all. :)
Zorba922 is offline
post #47 of 69 Old 05-20-2020, 10:53 PM
nathan_h's Avatar
Quoted: 2972 Post(s)
Liked: 2083
Budget, output needs, and whether you are serious about bass management are all factors. When set up well within their design limits, and mated well with subs, you’d be hard pressed to tell the difference in a blind listening test.
But pushed beyond their limits, or not set up well, the monitor style speakers can disappoint.
My current setup.
Recommended podcasts: The Next Picture Show, the /filmcast, AV Rant.
nathan_h is online now
post #48 of 69 Old 05-21-2020, 07:26 AM
badtlc's Avatar
Quoted: 608 Post(s)
Liked: 271
Originally Posted by zorba922 View Post
what's a 2.1 avr?
hdmi 2.1.
Zorba922 and joxr like this.
Front: Polk S55
Center: Polk S30
Rear: Polk S10
Sub: P̶L̶-̶2̶0̶0̶I̶I̶ | (̶2̶)̶ ̶F̶V̶X̶1̶2̶ | V1812
badtlc is online now
post #49 of 69 Old 05-21-2020, 07:34 AM - Thread Starter
joxr's Avatar
Quoted: 120 Post(s)
Liked: 41
I am leaning towards just ordering the towers.
5.2.4
joxr is offline
post #50 of 69 Old 05-21-2020, 07:41 AM
nathan_h's Avatar
Liked: 2083
I’m sure you’ll like them.
You can see from my build thread in my signature I’ve used several in my room.....and now I strongly prefer LCR speakers which admittedly look like monitors but have the output of towers in the region that counts. 🙂
Budget, output needs, and whether you are serious about bass management are all factors. When set up well within their design limits, and mated well with subs, you’️d be hard pressed to tell the difference in a blind listening test.
My current setup.
post #51 of 69 Old 05-21-2020, 08:48 AM - Thread Starter
joxr's Avatar
Quoted: 120 Post(s)
Liked: 41
So let me run something by you guys. I originally was interested in getting the Klipsch RF7-III and RC64-III instead of the Arendals. What are your opinions on those Klipsch speakers ? It seems like Klipsch gets a bad rap because they sell cheap stuff in Best Buy etc. At least online on some forums or youtube they consider them like the bose of the home theatre world. One thing I love about the RF7-III towers is the massive 10" woofers .. but it is weird how the rest of the line goes down in size. And you have to mix and match lines to complete a setup.
5.2.4
joxr is offline
post #52 of 69 Old 05-21-2020, 08:54 AM
Zorba922's Avatar
Liked: 6974
I'm sure it'd be ample for your 8-9ft listening distance.
Zorba922 is offline
post #53 of 69 Old 05-21-2020, 09:40 AM
rhelliott2's Avatar
Quoted: 396 Post(s)
Liked: 715
Those are amazing Speakers, what state you in? I have some for sale near me , which are basically brand new for a steal.
post #54 of 69 Old 05-21-2020, 09:51 AM - Thread Starter
joxr's Avatar
Quoted: 120 Post(s)
Liked: 41
nj
5.2.4
joxr is offline
post #55 of 69 Old 05-21-2020, 09:58 AM
rhelliott2's Avatar
Quoted: 396 Post(s)
Liked: 715
nj
Nevermind... This guy selling them is in California.
post #56 of 69 Old 05-22-2020, 11:19 AM
Red MC's Avatar
Quoted: 369 Post(s)
Liked: 296
What speakers do you currently own and what kind of sound do you like? Klipsch is a love it or hate it kind of brand, so be sure to listen to them first. I would describe their sound as boom/sizzle, i.e. having boosted mid-bass and treble. I can listen to them at lower volumes, but when you turn the volume up those horn tweeters become too hot for my ears. Their fans enjoy the sharpness. They're more dynamic than average and more sensitive than average, but their claimed sensitivity is overstated.
It doesn't matter if it's 2.5 way or 3 way. The lower crossover is at 120 Hz, which means the woofers contribute very little to sensitivity, which is measured 300-3000 Hz. I am always skeptical of manufacturers' claimed sensitivity. Most manufacturers exaggerate it, some by a lot. 92 dB is at the very top end of what you can achieve with a conventional loudspeaker and dynamic drivers. Very few measure that high, so I was immediately skeptical. But 89 dB for the newer 1793 'S' tower model sounds more believable, especially when compared to it's stand-mounted sibling.
Red MC is offline
post #57 of 69 Old 05-23-2020, 03:39 AM
Jon AA's Avatar
Quoted: 180 Post(s)
Liked: 213
Quite often in speaker design, it's the woofers that are the limiting factor to sensitivity (Hofmann's Iron Law tradoff). In those cases, the tweeter is brought down in level in the crossover to match. In a tower with a larger box and more bass drivers, the same tweeter can be brought down less to match the output of the bass, resulting in a more sensitive speaker and higher output capability.
bear123 likes this.
Jon AA is offline
post #58 of 69 Old 05-23-2020, 05:25 AM
MUDCAT45's Avatar
Quoted: 727 Post(s)
Liked: 483
Have you listened to the newest line of Klipsh Heritage speakers? IMO they are not as you describe Klipsch.
All series within a brand do not always have the same sound characteristics. My first experience with Dynaudio was the Audience series and the Contours. The Audience is one of the harshest sounding speakers I ever heard and the contours were only slightly better.
The earlier Focus series were boomy. The last generation of Focus (160 and 260) IMO were very good IMO.
My last trip to the Dynaudio dealer I listened to the S40. I have heard much better at 1/3 the price. The S25 was one of their best. Again, IMO.
The only way to buy a speaker is to listen first and not depend on opinions. We hear differently.
MUDCAT45 is online now
post #59 of 69 Old 05-23-2020, 05:38 AM
Red MC's Avatar
Quoted: 369 Post(s)
Liked: 296
That doesn't apply here because both speakers have the same mid-woofers covering the same frequency range, same tweeter, same crossover between them. The tower model simply adds two more woofers and has a lower bass reflex tuning, but those differences are below the frequency range of a sensitivity measurement.
Red MC is offline
post #60 of 69 Old 05-23-2020, 06:20 AM
Red MC's Avatar
Quoted: 369 Post(s)
Liked: 296
Only the Heresy of the newest Heritage models. I have a friend who is a bit of a Klipsch fan, and has the Forte II and K-horns, both powered by Bottlehead SET kit amps. I'm not a fan.
But you're right that my comments were mainly about the HT speaker line.
I totally agree re: auditions. There are a few brands/models that I would be comfortable buying online w/o audition, those that have a consistent house sound that I'm familiar with, but only if they don't cost too much.
I've never heard any of the Dynaudio Audience models.
Both the Special 25 and the Sapphire are too bright for my ears.
But I have heard most of the Contour models released in the last 20 years and I've never found any of them to be bright or harsh. The latest ones are pretty neutral. The Contour S models were a bit too dark, with the possible exception of the S5.4. And the Contour 1/2/3 models before that were pretty neutral too. IMHO, YMMV.
I am surprised you liked the Focus 160 but not the S40. That's a head scratcher.
Red MC is offline
Reply Speakers
