why have woofer on bookshelf / tower if I have a dedicated sub? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By Jonas2
post #1 of 4 Old 05-22-2020, 07:44 AM - Thread Starter
Liked: 0
This is probably a newb question to the experts, but if I have a separate subwoofer, wouldn't I be better off getting 2-way L/R speakers with a dedicated midrange driver and tweeter vs. a 2-way L/R speaker with a dedicated woofer + tweeter?
Thanks for your expert opinions.
kh85 is offline
post #2 of 4 Old 05-22-2020, 09:09 AM
Jonas2's Avatar
Quoted: 3319 Post(s)
Liked: 2199
With a 2-way speaker, the woofer, will be responsible for some of the lower frequency and the mid frequencies. That's just the way it is. You can certainly look for a speaker with a driver that perhaps does not play down as low, and maybe that delivers a better mid-range. It really depends on the speaker's design and implementation of the various components, like the crossover components and cabinet design. I don't know that such a speaker exists with a dedicated mid-range and tweeter? That'd leave a big frequency gap and you'd be required to have a sub-woofer - not sure there is really a market for that. Probably wouldn't sell well when the sales guy says, "This is a great speaker, but you need to spend a lot more because it can't play very low...."
In simple terms, what you're saying makes sense - yes. Problem is, it's not quite as simple as that! But it is not an uncommon approach - investing in good bookshelves and a sub-woofer (or two) to deliver what towers would try to deliver otherwise. And a good combo of these two can outperform towers - but again, it is very dependent on the overall design.
Just my opinion, we can leave the "expert" part out of it....
kh85 likes this.
7.2.4 System: Display: Sony XBR-65X930D; Processing: Anthem AVM60
Mains:
Paradigm Prestige 85F and 55C; Side / Rear Surrounds: Totem Acoustic Tribe III / Tribe I; Amplification: D-Sonic M3a-2800-7 (7ch. x 400w)
ATMOS:
Definitive Technology DI8R; Amplification: Class D Audio SDS-470C (4ch. x 300w)
Subwoofers:
2 x SVS-SB13Ultras; Media: Oppo UDP-203, Pioneer CLD-59
Jonas2 is offline
post #3 of 4 Old 05-22-2020, 02:01 PM
_tk
Quoted: 807 Post(s)
Liked: 403
You don't really want your subwoofer playing above 100Hz as you can start to localize sounds around that frequency. So you need your "woofer/mid-bass" driver playing down to at least that.
_tk is offline
post #4 of 4 Old 05-22-2020, 02:24 PM
A9X-308's Avatar
Quoted: 2035 Post(s)
Liked: 1750
Midbass. This is where the majority of musical content is in all genres.
“You are not special. You are not a beautiful and unique snowflake.” Chuck Palahniuk
A9X-308 is offline
Reply Speakers
