Speakers too big! Looking for smaller ones to fit on desktop under monitors - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By RayGuy
post #1 of 14 Old 05-22-2020, 11:30 AM - Thread Starter
vecctor's Avatar
When I was speccing out my office remodel I'd planned to use a set of Ascend Sierra-2 speakers I had from another room along with a new Emotiva amp. I badly misjudged how much space I'd have available on the desk, so there is no way the speakers will fit.
So I'm looking for something smaller that will fit under the monitors in the picture below. To be safe I'd say less than 7 inches tall (or able to be placed on their sides without issue - there might be 9-10 inches in width available in that case).
We'll say the budget is $1000 - but I'm open to anything if it's good.
They could be passive or powered/active - but near-field/monitors probably aren't the best because I might be in other parts of the room or at my workbench and not in the "perfect" spot. I was also planning on a sub at one point, but that would be a seperate discussion/budget - just looking for the speakers for now.
Usage will be primarily music coming from DAC (FLAC collection)
Any ideas would be much appreciated!
vecctor is offline
post #2 of 14 Old 05-22-2020, 12:05 PM
Quoted: 172 Post(s)
Liked: 145
If you're a fan of the Sierra 2 I would imagine you've looked at their Luna? You can have them rotate the tweeter and lay them sideways with over an inch to spare. I would try to tilt them up towards your ears.
http://www.ascendacoustics.com/pages...luna/luna.html
doctors11 is offline
post #3 of 14 Old 05-22-2020, 12:21 PM
gajCA's Avatar
Quoted: 10068 Post(s)
Liked: 7073
Passive KEF LS50 on its side is within budget at the moment due to discount but might not fit.
7-15/16"W x 11-15/16"H x 10-15/16"D
KEF LSX would fit but over budget though they are amplified.
Geoff A. J., California
gajCA is offline
post #4 of 14 Old 05-22-2020, 12:23 PM
Quoted: 172 Post(s)
Liked: 145
Monitor Audio Apex A10 on its side would be nice too. You would not use the stand. Again, tilt them up towards your ears.
https://www.crutchfield.com/p_893A10...igh-Gloss.html
post #5 of 14 Old 05-22-2020, 12:30 PM
Zorba922's Avatar
Quoted: 9076 Post(s)
Liked: 6974
I'd try out a pair of RSL CG23, $400/pr combined with their Speedwoofer 10S for another $400. All with free return shipping.
~ Are you a "geek hobbyist" obsessed with squeezing out that last 5-10% improvement? The economy will thank you...especially the Chinese one. Or are you more of a get-set-and-forget "casual user" who simply wants to increase your enjoyment of movies, TV and gaming? Relax, HT isn't rocket science, nor does it have to cost an arm and a leg---especially if you ignore the aforementioned vocal minority. And remember to smile...it's just a silly hobby, after all. :)
Zorba922 is offline
post #6 of 14 Old 05-22-2020, 01:52 PM
Quoted: 1155 Post(s)
Liked: 1012
Have you thought of wall mounts for your Sierra 2s?
sigpig is offline
post #7 of 14 Old 05-22-2020, 08:31 PM - Thread Starter
vecctor's Avatar
Thanks for these ideas!
I didn't realize Ascend had a smaller set, I bought the Sierras a while ago and I don't think they had this Luna at the time - I'll keep those in mind.
I think I had seen the A10s and read that because of the cabinet material they weren't ideal when not on their stands.
See I would have never thought to look at something that big, but you are correct, they could squeeze in there. I like the package deal with the sub.
It's possible, but a couple things are at play. The desk is in front of a window (you can see the blinds), so the speakers would have to be off-center or on-center and very far apart. It is also a sit-stand desk, so the height changes. If they were high enough up I guess that might not be as much of an issue.
I had seen the KEF LSX and the more I think about it the more I like the idea of powered speakers like this for desktop use since it is a tidier package for a smaller listening area.
Does anyone have experience with the Vanatoo Transparent Zero? The fact that they are sloped downward on the back would put them safely underneath the monitor arms, they have a built in tilt that would seem good for the space, they seem to review well and have sub out.
vecctor is offline
post #8 of 14 Old 05-22-2020, 08:31 PM
RayGuy's Avatar
Quoted: 3471 Post(s)
Liked: 3283
One of these?
https://www.amazon.com/dp/B01LW76AKC...osi&th=1&psc=1
A pair of these (add a small sub of your choice)?
https://galloacoustics.com/adiva/
Got a few extra bucks laying around?
http://neatacoustics.com/iota/
Go cheap?
https://www.accessories4less.com/mak...ck-each/1.html
It's a VIRTUAL channel unless stated otherwise.
RayGuy is online now
post #9 of 14 Old 05-23-2020, 05:02 AM
Quoted: 172 Post(s)
Liked: 145
As a stand up/sit down desk I would eliminate all the ribbon tweeter suggestions. You'll be moving in and out of the sweet spot.
The Apex are fine on their sides. It says in their literature if using them as a horizontal center channel, simply don't use the stands, and affix the little pads to the bottom. I believe they're cast aluminum.
post #10 of 14 Old 05-23-2020, 05:04 AM
Quoted: 172 Post(s)
Liked: 145
Originally Posted by RayGuy View Post
One of these?
Go cheap?
Ray, how does one buy Neat speakers in the U.S.? I've been intrigued by the Iotas for awhile.
post #11 of 14 Old 05-23-2020, 05:14 AM
Quoted: 460 Post(s)
Liked: 359
FWIW if you're talking about the A-100 as the speaker amp, it doubles as a great headphone amp and will drive anything you may want to plug in. I got one for my desk and love it for both functions.
KSpan is offline
post #12 of 14 Old 05-23-2020, 07:20 AM
gajCA's Avatar
Liked: 7073
This guy seems to get a kick out of giving snarky reviews and likes nothing better than show his superior knowledge by trashing a speaker.
The more well regarded the better it makes him feel it seems.
He liked the Vanatoos!
http://noaudiophile.com/Vanatoo_Transparent_Zero/
gajCA is offline
post #13 of 14 Old 05-23-2020, 07:34 AM
Zorba922's Avatar
Liked: 6974
He liked the Vanatoos! ]
No doubt that's because they are mostly unknown/unheard-of in audio enthusiast forums.
Yep, methinks he has some unresolved adolescent-rebellion issues.
Zorba922 is offline
post #14 of 14 Old 05-26-2020, 12:22 PM
RayGuy's Avatar
Liked: 3283
I did not check if they had a US distributor. If not, bad rec on my part. If it were me, I'd fill out the form and see what comes of it ...
http://neatacoustics.com/contact/
OK @doctors11 , I happened to run across this US Distributor of Neat products:
http://www.hifiservices.com/?s=Neat+iota
doctors11 likes this.
Reply Speakers
