Center Channel match for Paradigm Atom v5 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 05-22-2020, 02:02 PM - Thread Starter
avs_user_9's Avatar
I have a very constrained problem to solve b/c of imposed furniture
I have 2 Paradigm Atom v5 speakers plus a BW CC6 and a BW Sub
I like the paradigms enough, but their tone is different than the center channel. At times it bothers me at movies.
What would be a suitable center channel to match the tone of paradigms which must fit in 6 1/8" height?
I can consider replacing paradigms with some BWs, but then the bookshelf height must be below 12 1/2"
avs_user_9 is offline
post #2 of 3 Old 05-22-2020, 02:48 PM
RayGuy's Avatar
Quoted: 3471 Post(s)
Liked: 3283
The RSL CG23 is a good neutral speaker which should blend well with the paradigms and fit your space. Monitor Audio Radius 200 (or 225) will fit, and tends towards a more aggressive stance, which might be sympatico with your paradigms, but for significantly more $ than the RSL. Rear port may be problematic, depending on your set-up. The Monitor Audio A40 has front ports and is very WAF friendly. Probably the best of the group, but for more $ still. If you like it, you could always go for the A10s at a later date to have a seamless front stage.
It's a VIRTUAL channel unless stated otherwise.
RayGuy is online now
post #3 of 3 Old 05-22-2020, 03:48 PM
Zorba922's Avatar
Quoted: 9076 Post(s)
Liked: 6974
Are you getting decent voice clarity out of the CC6? If you're 100% satisfied with it, I'd move the Atoms to surround duty and get FL/FR speakers with at least 5.25" woofers, especially if music is a significant % of your usage.
If not, the aforementioned RSL CG23 would be worth a try.
~ Are you a "geek hobbyist" obsessed with squeezing out that last 5-10% improvement? The economy will thank you...especially the Chinese one. Or are you more of a get-set-and-forget "casual user" who simply wants to increase your enjoyment of movies, TV and gaming? Relax, HT isn't rocket science, nor does it have to cost an arm and a leg---especially if you ignore the aforementioned vocal minority. And remember to smile...it's just a silly hobby, after all. :)
Zorba922 is offline
Reply Speakers
