Bookshelf speakers mounted to 9' ceiling - AVS Forum | Home Theater Discussions And Reviews
 5Likes
  • 1 Post By gajCA
  • 1 Post By gajCA
  • 1 Post By Zorba922
  • 1 Post By gajCA
post #1 of 10 Old 05-24-2020, 01:54 PM - Thread Starter
Carneiro's Avatar
Quoted: 40 Post(s)
I'm planing on running speaker wire in-ceiling for 7.1 surround, but I'm not sure if it is ok to use bookshelf speakers mounted to a ceiling that's 9' (~2.75 meters). In that case, should I be using an atmos setup? Maybe I should be coming up through the floor instead?
When I look at the manual for my receiver, the read and side channels are always illustrated at about head-height for a seated adult. I've tried to google it, but no luck so far.
Carneiro is offline
post #2 of 10 Old 05-24-2020, 02:04 PM
gajCA's Avatar
Quoted: 10174 Post(s)
Liked: 7203
So you don't want 5 speakers on the floor or on stands you want all in or on the ceiling?
Carneiro likes this.
Geoff A. J., California
gajCA is online now
post #3 of 10 Old 05-24-2020, 02:25 PM - Thread Starter
Carneiro's Avatar
Quoted: 40 Post(s)
I don't have a problem with speakers on the floor on stands per se, but I do have a problem with speaker wire running on my floor.
I have bookshelf speakers for the rear and side surround channels, and I'd rather not buy in-ceiling speakers to replace them. Ideally, I could just mount my speakers on the ceiling and be done with it.
Carneiro is offline
post #4 of 10 Old 05-24-2020, 02:28 PM
gajCA's Avatar
Liked: 7203
So your front three are at ear level when seated but you want the surrounds in ceiling.
That precludes atmos but, yes, bookshelves on mounts or something like this which is designed for on ceiling placement would work.
https://www.svsound.com/collections/...hoC8tUQAvD_BwE
gajCA is online now
post #5 of 10 Old 05-24-2020, 02:32 PM - Thread Starter
Carneiro's Avatar
Quoted: 40 Post(s)
Yes, though I'd say I want the surrounds on-ceiling, not in.
Thanks for the quick replies. I have some universal speaker mounts, so now that I know it's not incorrect to have the surrounds 6' higher than the front channels, I'll just use those.
Thanks again.
Carneiro is offline
post #6 of 10 Old 05-24-2020, 02:38 PM
Zorba922's Avatar
Quoted: 9534 Post(s)
Liked: 7357
No Atmos if doing ceiling rear surrounds, kind of defeats the whole purpose of Atmos.
That said, some of us find Atmos to be grossly overhyped.
A compact sealed cabinet speaker like NHT SuperZeros (less than $70 apiece on Amazon) would work well for on-ceiling mounting.
~ Are you a "geek hobbyist" obsessed with squeezing out that last 5-10% improvement? The economy will thank you...especially the Chinese one. Or are you more of a get-set-and-forget "casual user" who simply wants to increase your enjoyment of movies, TV and gaming? Relax, HT isn't rocket science, nor does it have to cost an arm and a leg---especially if you ignore the aforementioned vocal minority. And remember to smile...it's just a silly hobby, after all. :)
Zorba922 is offline
post #7 of 10 Old 05-24-2020, 02:45 PM - Thread Starter
Carneiro's Avatar
Quoted: 40 Post(s)
Hi. Thanks for the reply.
Are you saying that I should not go with the bookshelf speakers I already have, which came with the front and center channel speakers?
Carneiro is offline
post #8 of 10 Old 05-24-2020, 02:46 PM
gajCA's Avatar
Liked: 7203
You'll be fine.
gajCA is online now
post #9 of 10 Old 05-24-2020, 02:51 PM
Zorba922's Avatar
Liked: 7357
No, for your front 3, it doesn't matter. But for mounting surrounds flush against the ceiling, a sealed cabinet or front ported design is optimal. But if you have to use rear ported speakers on your ceiling it won't be the end of the world, since you can just use a high crossover point to avoid any boominess and there's likely very little mid-bass coming out of them anyway.
Zorba922 is offline
post #10 of 10 Old 05-24-2020, 03:43 PM
mmiles's Avatar
Quoted: 1235 Post(s)
Liked: 641
Check out Tannoy AMS 6DC or 8DC.
Black or White metal cabinet. Industrial look but hey they are up on ceding.
I’ve used the 6DC for Atmos.
Mike Miles
[email protected]
mmiles is online now
Reply Speakers
