Sapphire compatible expansion - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By sigpig
post #1 of 17 Old 05-25-2020, 02:51 PM - Thread Starter
4HiMarks's Avatar
Quoted: 33 Post(s)
Hi All, I'm preparing to renovate my basement into a HT/bar/man cave and am ;looking for some advice. I am currently running a 7.1 system with a Denon 3311 driving 7 Sapphire speakers and a Velodyne sub. I just ordered a new Denon X4500 for the new space and want to expand to 9 speakers at least, maybe 11. Since Sapphire went out of business some time ago, I was wondering what current speakers are out there that would be compatible with them, so I can avoid buying all new.
The new space will be about 14x25 with concrete floor covered either by luxury vinyl or epoxy, with some area rugs. Three walls are cinder block, but will probably get covered with drywall.
4HiMarks is offline
post #2 of 17 Old 05-25-2020, 03:05 PM
Kini62's Avatar
Quoted: 2948 Post(s)
Liked: 2824
You'd likely be better off using what you have, getting another or better subs and going with Atmos speakers.
Def Tech SC8000
Onkyo RZ820
Roku Ultra, Apple TV, Sharp 70" Quattron
Kini62 is offline
post #3 of 17 Old 05-25-2020, 04:36 PM
Zorba922's Avatar
Quoted: 9550 Post(s)
Liked: 7367
Almost *any* in ceiling speakers will work with your current speakers...being Atmos, they will do a miniscule % of the HT output, so any notion of "matching" is for greedy salesmen and incredibly nit-picky listeners only.
I agree with the previous poster: upgrading your sub would make a much more noticeable impact. I would not spend more than $100 per Atmos speaker, tops.
~ Are you a "geek hobbyist" obsessed with squeezing out that last 5-10% improvement? The economy will thank you...especially the Chinese one. Or are you more of a get-set-and-forget "casual user" who simply wants to increase your enjoyment of movies, TV and gaming? Relax, HT isn't rocket science, nor does it have to cost an arm and a leg---especially if you ignore the aforementioned vocal minority. And remember to smile...it's just a silly hobby, after all. :)
Zorba922 is offline
post #4 of 17 Old 05-25-2020, 05:05 PM - Thread Starter
4HiMarks's Avatar
Quoted: 33 Post(s)
I have ideas on the sub situation, but that is for a different thread.
I was not considering in-ceiling. It may not even be an option as I have a drop ceiling and am strongly leaning towards keeping it in one form or another.I would prefer bookshelf.
4HiMarks is offline
post #5 of 17 Old 05-25-2020, 05:44 PM
Zorba922's Avatar
Liked: 7367
Oh, if you are thinking of wall mounted "height" speakers, the easiest thing to do would be the SVS Elevations---very convenient, easy to install, and aesthetically pleasing.
https://www.svsound.com/collections/prime-elevation
But overpriced.
You could use compact bookshelf speakers like RSL CG3 ($135 ea. with free return shipping) or NHT SuperZeros ($70 each on Amazon) on L-bracket mounts and tilt them downwards.
Zorba922 is offline
post #6 of 17 Old 05-25-2020, 08:26 PM - Thread Starter
4HiMarks's Avatar
Quoted: 33 Post(s)
I am thinking mostly of duplicating the surround channels. Only one speaker on a 25' wall doesn't seem like enough. But I want both to be as close as possible in sound quality.
4HiMarks is offline
post #7 of 17 Old 05-25-2020, 08:30 PM
Zorba922's Avatar
Liked: 7367
Then prepare for some trial-and-error, no way to avoid that.
Speakers that come with free return shipping are ideal for doing just that:
  • HTD
  • Infinity
  • JBL
  • RSL
  • SVS
Zorba922 is offline
post #8 of 17 Old 05-26-2020, 03:38 AM - Thread Starter
4HiMarks's Avatar
Quoted: 33 Post(s)
  • HTD
  • Infinity
  • JBL
  • RSL
  • SVS
I was hoping to avoid that sort of thing by coming on here and asking the experts. Does anyone know the properties of Sapphires that other speakers might share?
4HiMarks is offline
post #9 of 17 Old 05-26-2020, 06:23 AM
Zorba922's Avatar
Liked: 7367
There are no "experts" who can predict what YOUR ears may or may not hear/notice. Not here. Not anywhere.
Judging from the lack of response to your question, it appears that no one who's read this thread has had any experience with your specific speakers at all.
I wouldn't waste time overthinking this silly hobby, or chasing unicorns.
Good luck.
Zorba922 is offline
post #10 of 17 Old 05-26-2020, 06:33 AM - Thread Starter
4HiMarks's Avatar
Quoted: 33 Post(s)
Of course not. But there ARE experts who might know the frequency response of the drivers, the specific materials those drivers are made of, the impedance of the speakers, the resonance properties of the cabinets, and many other objective, physical characteristics of the speakers in question and how they compare to the same properties of OTHER speakers. That is the answer I'm looking for.
4HiMarks is offline
post #11 of 17 Old 05-26-2020, 06:39 AM
Zorba922's Avatar
Liked: 7367
Sure there are...somewhere, somehow, in this or another parallel universe.
Good luck!
Zorba922 is offline
post #12 of 17 Old 05-27-2020, 09:54 AM
Quoted: 1281 Post(s)
Liked: 1120
Giving us some actual model numbers of your speakers would help.
Frankly, if you like what you have, then some neutral-sounding in-ceiling speakers would be great for Atmos. Some common ones are these: https://rslspeakers.com/c34e-ceiling-speaker/
An additional Rhythmik sub would probably match your Velodyne better than any other manufacturer, as they share their servo technology.
Zorba922 likes this.
sigpig is online now
post #13 of 17 Old 05-27-2020, 10:08 AM - Thread Starter
4HiMarks's Avatar
Quoted: 33 Post(s)
They only made one model of surround speaker - Sapphire SS Surround. Same for bookshelf and center channels. Only the front towers came in multiple models. I have the ST3 Mk IIs. I managed to find a used pair of the surrounds on ebay and they're even in the same county, so I should be set.
4HiMarks is offline
post #14 of 17 Old 05-27-2020, 10:34 AM
MUDCAT45's Avatar
Quoted: 740 Post(s)
Liked: 491
Various posts on AVS ;
https://www.avsforum.com/forum/searc...8&pp=25&page=3
MUDCAT45 is offline
post #15 of 17 Old 05-27-2020, 10:38 AM - Thread Starter
4HiMarks's Avatar
Quoted: 33 Post(s)
Originally Posted by MUDCAT45 View Post
I get "Sorry - no matches. Please try some different terms." Believe me, I searched the forum for any mention of Sapphires and came up empty.
4HiMarks is offline
post #16 of 17 Old 05-27-2020, 10:54 AM
MUDCAT45's Avatar
Quoted: 740 Post(s)
Liked: 491
I went to SPEAKER forum. Under search block in upper right just type in sapphire and select "show posts".
MUDCAT45 is offline
post #17 of 17 Old 06-16-2020, 08:30 AM - Thread Starter
4HiMarks's Avatar
Quoted: 33 Post(s)
So I got the used SS Surrounds and replaced my rear surround speakers with them. Now I'm trying to determine the best use for the SB bookshelf speakers that were originally rear surround. I'm thinking front height, maybe?
4HiMarks is offline
Reply Speakers
