The best clamping bookshelf speaker mounts? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 05-26-2020, 10:21 AM - Thread Starter
Quoted: 22 Post(s)
What is the "GO TO" clamping speaker mount for bookshelf speakers? I need to mount a set that doesn't have any mounting holes. I have been reading about clamping mounts. However I am not sure which is the best brand. I am sort of tempted to drill the bottoms and mount them that way. I could tilt them a lot more if so, but run the risk of screwing up the speakers too..So, I am going to try the clamp mounts ...Any advice from owners would be appreciated .
RonnieBlack2nd is offline
post #2 of 8 Old 05-26-2020, 10:27 AM
Quoted: 56 Post(s)
I use these for my surrounds and they work great. I bought them on Amazon for $30
Mount-It! Speaker Wall Mounts, Pair of Universal Side Clamping Bookshelf Speaker Mounting Brackets, Large or Small Speakers, 2 Mounts, 55 Lbs Capacity, Black
JBL Studio 590's, Klipsch RP-450C, Polk TSI 500's, 2 SVS SB 3000's and a Sony 65" 850
mdildine is offline
post #3 of 8 Old 05-26-2020, 10:42 AM - Thread Starter
Quoted: 22 Post(s)
Those are in my cart...You're okay with the swivel and tilting?
post #4 of 8 Old 05-26-2020, 11:12 AM
Quoted: 56 Post(s)
They work good for my purposes. I am not tilting them a lot, maybe 15degrees? The swivel works as it should. I have Polk tsi200's on them and they hold them easily.
mdildine is offline
post #5 of 8 Old 05-26-2020, 11:52 AM
MRAYB's Avatar
Quoted: 547 Post(s)
Liked: 2230
I have tried a couple different ones, and like these the best. Good swivel, tilt can be increased if you shim it a little with washers. Velcro on the sides, and Blu-Tack on the bottom makes the whole thing rock solid. Two mounting holes with "Toggler" drywall anchors work great even in a hollow wall.(no stud).
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
MRAYB is online now
post #6 of 8 Old 05-26-2020, 12:37 PM
Red MC's Avatar
Quoted: 371 Post(s)
Liked: 300
I'm using the B-Tech BT77
https://www.crutchfield.com/S-aNYdV2...T77-Black.html
They replaced a different pair of clamping wall mounts that couldn't stop the speakers from swiveling when bumped. The speakers I'm using weigh about 15-20 lbs. The B-Tech stands hold them solidly in place. I accidentally smacked my shoulder into one hard enough to hurt and it didn't budge.
HT: Dynaudio C2, Contour S CX, 2x BM14S, Aperion surrounds, Simaudio Titan, Marantz AV8801, Oppo 103, Linn Majik DS, and a Pioneer Kuro
Stereo: Dynaudio Focus 160, Simaudio W-5 LE or Luxman M-600A, Linn Akurate DSM, 2x Rythmik F12G
Other interests: motorcycling, skiing, being active
Red MC is offline
post #7 of 8 Old 05-26-2020, 01:54 PM
Quoted: 17 Post(s)
Liked: 9
These are a little different in that they clamp front-to-back vs side-to-side. Might be a safer tilt. Sorry, no personal experience with them (yet).
https://www.amazon.com/Side-Clamping...525975&sr=8-15
bac2040 is offline
post #8 of 8 Old 05-26-2020, 01:57 PM
Ryan Statz's Avatar
Quoted: 1295 Post(s)
Liked: 1088
I use these: https://www.primecables.ca/en/p-3704...ck-primecables
They work great.
Home Theatre: Marantz SR6014 | KEF Q750 | KEF Q650c | KEF Q150 | HSU ULS-15 MK2 | Sony XBR55X900E | PS4 Pro | Xbox One S | Nintendo Switch
Music: Cambridge Audio AXR100 | Fluance RT85 | Ortofon 2M Blue | Cambridge Audio AXC35 | Neat Motive 3
Ryan Statz is offline
Reply Speakers
