Home Theater 5.1 - AVS Forum | Home Theater Discussions And Reviews
 27Likes
post #1 of 44 Old 05-30-2020, 06:46 PM - Thread Starter
Quoted: 21 Post(s)
Liked: 3
Send a message via AIM to Venu Bandi
Home Theater 5.1
Hello,
I am planning buy 5.1 speakers.
to start with for budget : 800 or below
Receiver - Denon 1300x $400 is it a good one?
center - Center - BIC America FH6-LCR Dual 6.5-Inch
do i need to buy subs,surround, front and back from the same brand for better performance?
would appreciate if you could give me some recommendations for a 5.1 home theater?
Venu
Venu Bandi is offline
post #2 of 44 Old 05-31-2020, 10:02 AM
gajCA's Avatar
Quoted: 10176 Post(s)
Liked: 7206
Originally Posted by Venu Bandi View Post
Hello,
Venu
If new that is a good price for the very nice Denon.
If you like the BIC center, I'd get BIC front left/right and then less expensive for surrounds.
Subwoofer brand does not need to match but with that sort of budget BIC is a decent choice.
Venu Bandi likes this.
Geoff A. J., California
gajCA is offline
post #3 of 44 Old 06-01-2020, 09:30 AM - Thread Starter
Quoted: 21 Post(s)
Liked: 3
Reeciver - Denon X1600
do you recommend any model other than BIC America RLC speakers and Sub woofer to start with .
will buy surround speaker if get it cheaper.
what else do I need ? can please let me know the brands/models work for Denon X1600
Right and left speakers - 1 each
Center Speaker 1
sub woofer - 1
Surround speaker- 2 or 1
Venu
post #4 of 44 Old 06-01-2020, 09:35 AM - Thread Starter
Quoted: 21 Post(s)
Liked: 3
Center Speaker 1
sub woofer - 1
Venu
what else do I need ? can you please let me know the brands/models work for Denon X1600
budget for the below 600 USD or below
Center Speaker 1
sub woofer - 1
Surround speaker- 2 or 1 ?
Venu
post #5 of 44 Old 06-01-2020, 09:35 AM
Tuba4me's Avatar
Quoted: 50 Post(s)
Liked: 50
Just out of curiosity, where are you located?
Tuba4me is offline
post #6 of 44 Old 06-01-2020, 09:38 AM - Thread Starter
Quoted: 21 Post(s)
Liked: 3
USA - Atlanta
post #7 of 44 Old 06-01-2020, 09:51 AM
gajCA's Avatar
Liked: 7206
Center Speaker 1
sub woofer - 1
Venu
As you like the FH6 LCR get two more for left and right.
Here in the states they are $119 each at Parts Express.
I'd get these at $126/pair for the rear:
https://www.parts-express.com/bic-ve...-pair--303-402
And I'd get this subwoofer.
https://rslspeakers.com/products/rsl-speedwoofer-10s/
gajCA is offline
post #8 of 44 Old 06-01-2020, 10:22 AM
Tuba4me's Avatar
Quoted: 50 Post(s)
Liked: 50
USA - Atlanta
Sent you a PM
Tuba4me is offline
post #9 of 44 Old 06-01-2020, 12:01 PM
Zorba922's Avatar
Quoted: 9572 Post(s)
Liked: 7388
Center Speaker 1
sub woofer - 1
If you are 100% happy with that BIC center, I'd get two pairs of Polk S15 for your front L/R and surrounds, $340 shipped all in:
https://www.amazon.com/Polk-Signatur...dp/B01LVWWZS0/
And then get a decent subwoofer like this:
https://www.monoprice.com/product?p_id=24456
I used to have the FH6-LCR and used it with a bunch of different mismatched L/R speakers, no problems---it provides excellent voice clarity, but being a sealed cabinet it rolls off very high, like 80-90Hz (BIC's specs claiming 40Hz extension are a joke) so sometimes male voices didn't sound very "male" but nevertheless were easy to understand which is the #1 basic requirement of any center speaker.
~ Are you a "geek hobbyist" obsessed with squeezing out that last 5-10% improvement? The economy will thank you...especially the Chinese one. Or are you more of a get-set-and-forget "casual user" who simply wants to increase your enjoyment of movies, TV and gaming? Relax, HT isn't rocket science, nor does it have to cost an arm and a leg---especially if you ignore the aforementioned vocal minority. And remember to smile...it's just a silly hobby, after all. :)
Zorba922 is offline
post #10 of 44 Old 06-01-2020, 12:50 PM - Thread Starter
Quoted: 21 Post(s)
Liked: 3
other option is CG3
cg3-5-1-home-theater-system
Bundle -999 Plus receiver - 550 : Total 1600
is it better one to start with ?
Venu
post #11 of 44 Old 06-01-2020, 01:08 PM
Zorba922's Avatar
Liked: 7388
other option is CG3
Bundle -999
God, no. That bundle sticks you with 5 speakers that only have puny 4" woofers. The RSL 10s is a decent little sub for $400, though for an extra $100 the Monolith sub kills it.
For $500 you would do much better with 2 pairs of Emotiva B1 ($229/pr) and C1 center ($250 but with the 30% off first order discount you'd get it for just $112).
Or if you want 5 identical speakers, 5 x NHT C1s for $128 each from Amazon...those have 5.25" woofers and attractive compact sealed cabinets.
PS. I'd try to spend less on the receiver since it makes diddly difference. Instead of the Monolith sub you could move up to the Hsu VTF-2 or Rythmik LV12-F sub, both around $600 shipped. For instance, the Yamaha RV-683 from Amazon for $355.
Zorba922 is offline
post #12 of 44 Old 06-01-2020, 03:16 PM - Thread Starter
Quoted: 21 Post(s)
Liked: 3
Thank you for sending this!
I would love to do this! I have a couple of questions-
I can switch to Yamaha RX-V683BL 7.2-Channel MusicCast AV Receiver and buy the below Emotiva stuff
1. where can i get 30 percent discount for C1 center?
2. RSL 10s - is not in stock - any alternative with in the same price around 350 to 400 USD- for Yamaha RX-V683BL
Venu
post #13 of 44 Old 06-01-2020, 03:20 PM
Zorba922's Avatar
Liked: 7388
Call or email Emotiva directly to ask about their "Emobucks" program. Hopefully it's still on offer.
I would spend an extra $100 and get the Monolith 10" THX sub, either directly Monoprice or through Amazon.
Even better would be an extra $200 for the Hsu VTF-2 or Rythmik LV-12F.
Zorba922 is offline
post #14 of 44 Old 06-01-2020, 03:38 PM - Thread Starter
Quoted: 21 Post(s)
Liked: 3
Seems like its ended now -Unfortunately, the Emobucks program has ended, so we are unable to offer the promotion at this point.
post #15 of 44 Old 06-01-2020, 03:46 PM
Zorba922's Avatar
Liked: 7388
Bummer.
Even at $229/pr for the B1s and $250 for the C1, that's the best bang for your buck around. If budget requires, I'd just hold off on the rear surrounds and start with a high quality 3.1 setup right now if I were you.
Ryan Statz and Venu Bandi like this.
Zorba922 is offline
post #16 of 44 Old 06-01-2020, 04:58 PM - Thread Starter
Quoted: 21 Post(s)
Liked: 3
Bummer.
Recap -
are these the best 5.1 that we can buy for 1600 USD? feel free to change to make it better without raising the price
receiver - Yamaha RX-V683BL 7.2-Channel MusicCast AV Receiver - 354
Emotiva B1 - 4 no - 450
Emotiva C1 - 1 no - 250
Monolith by Monoprice 10in THX Select Certified 500-Watt Powered Subwoofer - 500
Total - 1600
Cables - 50 to 100 USD
Venu
post #17 of 44 Old 06-01-2020, 05:48 PM
Zorba922's Avatar
Liked: 7388
Recap -
Total - 1600
Yep, only way to beat that would be to wait for the next Infinity speaker sale at infinityspeakers.com --- one just ended about a month ago, there are usually 2-3 per year.
Cables: use generic Mediabridge, Monoprice, Cables2Go, etc. from Amazon (Amazon Basics cables are ok too).
sigpig and Venu Bandi like this.
Zorba922 is offline
post #18 of 44 Old 06-02-2020, 02:47 PM - Thread Starter
Quoted: 21 Post(s)
Liked: 3
ordered as per the above..... excited
Thank you for your time.
Zorba922 likes this.
post #19 of 44 Old 06-04-2020, 08:23 AM - Thread Starter
Quoted: 21 Post(s)
Liked: 3
I have an additional budget of 300 that I can spend on it.
so can I make it 7.1 (2 more B1) or 5.1.2 Atom ?
post #20 of 44 Old 06-04-2020, 12:59 PM
Zorba922's Avatar
Liked: 7388
Definitely 5.1.2 over 7.1 without a doubt.
HOWEVER, if you have a medium or larger sized room, especially one that opens up to adjacent rooms, you'd be best off adding a second subwoofer which would give you a 5.2 system.
What are your room dimensions? And is it totally enclosed, or is this an open plan house?
Zorba922 is offline
post #21 of 44 Old 06-04-2020, 01:13 PM - Thread Starter
Quoted: 21 Post(s)
Liked: 3
Living room and kitchen are connected - refer to the image. length 19 X width 17 Feet (living area only)
if I am adding another sub woofer do I need buy one more Monolith 10in THX ?
post #22 of 44 Old 06-04-2020, 01:27 PM
gajCA's Avatar
Liked: 7206
Yes, not recommended to mix model numbers let alone brands.
But you might find one to be plenty so I'd wait.
Venu Bandi and sigpig like this.
gajCA is offline
post #23 of 44 Old 06-04-2020, 01:30 PM
Zorba922's Avatar
Liked: 7388
The sub(s) will interact with ALL contiguous space, not just your listening area.
If you already ordered the Mono sub then yes, I'd add a second one.
If you have not ordered any sub, you could spend the extra $300 you've found on a single huge sub if you don't have space for two, like the Hsu VTF-15H (currently on sale) or VTF-3.
Zorba922 is offline
post #24 of 44 Old 06-04-2020, 01:44 PM - Thread Starter
Quoted: 21 Post(s)
Liked: 3
ordered from amazon and arriving tomorrow.
In that case can i make it 5.1.2 for now and add one more sub next year? does that make sense?
If i am doing 5.1.2 do i need to buy the Emotiva atoms also ? are there any other cheaper options?
post #25 of 44 Old 06-04-2020, 02:32 PM
Zorba922's Avatar
Liked: 7388
Sure, a single Mono sub will tie you over just fine.
If you want to save some money for Atmos, you could try these Daytons, they have a similar AMT tweeter:
https://www.parts-express.com/dayton...eeter--300-451
Zorba922 is offline
post #26 of 44 Old 06-04-2020, 02:44 PM - Thread Starter
Quoted: 21 Post(s)
Liked: 3
If add 2 of them as rear speakers will it become 5.1.2 or 7.1 ?
post #27 of 44 Old 06-04-2020, 03:06 PM
Zorba922's Avatar
Liked: 7388
If you mount them on or near your ceilings, it'd be 5.1.2
Zorba922 is offline
post #28 of 44 Old 06-04-2020, 04:20 PM - Thread Starter
Quoted: 21 Post(s)
Liked: 3
by mistake I ordered 2 which means 4 AMT tweeter speakers.
can I make it now 5.1.4? I will mount them on ceiling 2 front and 2 back.
if that doesn't make sense I will cancel the order or change the order to 1 pair
post #29 of 44 Old 06-04-2020, 04:48 PM
Ryan Statz's Avatar
Quoted: 1297 Post(s)
Liked: 1088
Yes. 5.1.4 is better than 5.1.2 - if you're going to do atmos/height speakers, do the .4 instead of the .2
Happy accident
Home Theatre: Marantz SR6014 | KEF Q750 | KEF Q650c | KEF Q150 | HSU ULS-15 MK2 | Sony XBR55X900E | PS4 Pro | Xbox One S | Nintendo Switch
Music: Cambridge Audio AXR100 | Fluance RT85 | Ortofon 2M Blue | Cambridge Audio AXC35 | Neat Motive 3
Ryan Statz is online now
post #30 of 44 Old 06-06-2020, 09:58 AM - Thread Starter
Quoted: 21 Post(s)
Liked: 3
ordered emotive 4 B1 and C1 speakers on 1st June. My order not yet shipped and still showing as order unfulfilled.
can you please suggest alternative brands (4 +1 central channel) with the same quality?
Reply Speakers
