Speaker Wire Make a Difference? - AVS Forum | Home Theater Discussions And Reviews
 53Likes
post #1 of 36 Old 06-02-2020, 07:03 AM - Thread Starter
teetertotter's Avatar
Quoted: 58 Post(s)
Liked: 40
There was a thread that was CLOSED and had to post this that was done by @polkandwhat , a couple days ago. I found it interesting whether you prefer Exotic cost or low cost Ordinary speaker wire: Any Differences? By Roger Russell You be the judge
http://www.roger-russell.com/wire/wire.htm
Advertising Claims? Same applies with HDMI cables?
TV: TCL 55" 4K UHD HDR w ROKU
DENON AVR-S910W, 7.2, HDMI 2.0a, 4K UHD HDR, Upscaling, Atmos, Wi-Fi, etc. [2016]
KLIPSCH: L/R: R-51M - Ctr: RP-400C - Sub: R-100SW - POLK S-20 Surround
SPKR Wire:Windy City Wire - 16ga, 2 Cond, Twisted Pair, Shielded, Jacketed [USA]
HDMI: VANCO - 4K, 18Gbps, 2.0b, Certified --- [AT&T - Directv Sat. & DSL 100Mbps]
teetertotter is offline
post #2 of 36 Old 06-02-2020, 07:10 AM
vitod's Avatar
Quoted: 287 Post(s)
Liked: 167
No difference. Snake oil.
Zorba922 likes this.
Panasonic AE-8000, Carada BW 120", Paradigm Studio 40v3 x 2, Paradigm 690v4, Paradigm ADP 470v3 (rears), Micca M-8C x 4, Volt 6 x 2 (SR), SI DS4-18 in 12cuft X 2, Marantz 7702MKII, OPPO 103D, Emotiva XPA-3,
vitod is offline
post #3 of 36 Old 06-02-2020, 07:17 AM
eljaycanuck's Avatar
Quoted: 2170 Post(s)
Liked: 3160
There's no reason (other than "audiophile") to expect that high-/over-priced speaker wire will perform better than / be superior to good-quality, inexpensive speaker wire.
eljaycanuck is offline
post #4 of 36 Old 06-02-2020, 07:33 AM
b curry's Avatar
Quoted: 1291 Post(s)
Liked: 833
Most speaker wires are made of copper. Copper is a naturally occurring element and is found in a free metallic state in nature. Copper is in Group 11 of the Periodic Table of Elements with an Atomic Number of 29, Atomic Weight of 63.546 and is called out by the Periodic Symbol Cu.
Copper used as electrical wire has been around since the 1820's. Modern refining techniques for copper for the use as copper electrical wire requires the wire to be oxygen free in the refining process and a minimum of 99.9% pure with most wire being 99.99% pure or greater.
Copper wire does not know if it's being sold as "Exotic" high cost or "low cost Ordinary speaker wire", it just conducts electricity when it's connected to a source.
Unless the copper wire is somehow mitigated to alter its resistive/capacitive properties, it all has the same conductive properties.
Most anything else is superfluous blather.
b curry is offline
post #5 of 36 Old 06-02-2020, 07:50 AM
JD23's Avatar
Quoted: 1066 Post(s)
Liked: 834
Speaker wire can matter in extreme cases, but that does not mean that the high-end "audiophile" cables are better. It is most important to use cable with sufficiently low gauge for the length of your run. Well constructed cables sold by BJC or Monoprice are more than sufficient. Ignore the claims of uber-expensive audiophile interconnect companies that are not based in engineering or scientific principles.
JD23 is online now
post #6 of 36 Old 06-02-2020, 08:01 AM
Mocs123's Avatar
Quoted: 628 Post(s)
Liked: 413
Any good quality OFC speaker cable of sufficient gauge is fine. For most runs 12/2 is more than sufficient and 14/2 is good enough in all bu the longest runs. Monoprice has nice cable, but Belden 5000 is good too. If audiophiles would spend the money they spend on cables on room treatments (with enough money left over for a nice charitable donation) they would have much better sound.
warnerwh1 likes this.
7.4.4 Theater Room: JVC-RS500, Silver Ticket AT 2.35:1 142”, Onkyo RZ830, Anthem PVA-7, Panasonic UB420, Apple TV 4K, JBL Studio 530’s, Dual Driver VBSS
3.1 Living Room: Samsung 64” F8500 Plasma, Anthem MRX 300, Dynaudio Audience 52’s, Dynaudio Audience 122C, NHT SubOne, Roku Express (2019)
Mocs123 is offline
post #7 of 36 Old 06-02-2020, 08:08 AM
Jawaburger's Avatar
Quoted: 248 Post(s)
Liked: 259
As someone who fell into the trap of expensive wiring, I can anecdotally confirm that my Blue Jeans cabling sounds just as good as my previous Nordost cabling. If you have extra money laying around and nothing to spend it on, then buying some premium, fancy cabling is just fine, but please realize you are buying it for aesthetics more than function. Some of the Norse series from Nordost are extremely good looking cables.
If your budget is limited, buying better or different speakers or acoustic room treatments is a much better way to spend your money. Those are two areas that will make a much bigger difference in how your system sounds.
sealmaniac and Transistorious like this.
Sharp LC-80LE844U | HT PC | Marantz AV8003 | Marsh Sound Design A400s (FL/FR) | Marantz MM7055 (C/SL/SR) | PSA MTM 210T (FL/FR) | PSA MTM 210C (Center) | Phase Tech PC 3.1 (SL/SR/SB) | Dual PSA S1811 Subs
Jawaburger is offline
post #8 of 36 Old 06-02-2020, 09:52 AM
Quoted: 1301 Post(s)
Liked: 1142
The only way speaker wire matters is that it must go from the amp to the speaker.
MUDCAT45 and Transistorious like this.
sigpig is offline
post #9 of 36 Old 06-02-2020, 10:20 AM
zielin's Avatar
Quoted: 375 Post(s)
Liked: 258
A video you might want to watch (i found it useful) ... but short version, for speaker cables it doesn't really matter. That said, don't make them super thick or thin (12-14 gauge is what you should be looking for)
also, https://www.bluejeanscable.com/ makes some sweet cables and you might want check them out. Cheap hi-end cables. (no magic.. just well built.)
The only "fancy" cables i use are for power. No, not because they make any diff coming from the wall... but for the snakenest that is behind my AV gear. Everything is touching everything. Highly shield power keep it from screwing with all the other cables it is touching.
My Hi-Fi setup is super nightmare of over lapping cables in a small spot. xlr, SE, power, speaker wires.. ugh - but if the cables aren't touching.. i'd not stress it to much. I use BJ for everything (other than power.)
TV: LG OLED77C9 | Receiver Denon X8500H | AMP: PrimaLuna EVO 400 | Speakers: ELAC Vela FS407.2, CC401.2, BS403.2, Carina BS243.4, 2x SVS SB-3000
HTPC: i9-10980XE @ 5.0ghz, DDR4 32gigs, Intel Optane 960gb x2, Nvidia 2080 ti (SLI)
Sources:Oppo UDP-203,Tivo Bolt+,Xbox One X,PlayStation 4 Pro,Switch,Bluesound node 2i
CalMan Enthusiast, SpectraCal C6-HDR, VideoForge Pro | Control: Logitech Harmony Elite
zielin is offline
post #10 of 36 Old 06-02-2020, 10:52 AM
Quoted: 86 Post(s)
Liked: 24
Maybe just add that you might need UL certified and CL2 rated depending on your space.
OrangePhile is offline
post #11 of 36 Old 06-02-2020, 11:16 AM
mtrot's Avatar
Quoted: 674 Post(s)
Liked: 289
"Speaker Wire Make a Difference?"
Yes, most definitely, in the case of many of the most expensive and exotic cable designs. Why? Because these are designed, engineered, and manufactured specifically to produce a certain "house sound", by incorporating various gizmos and devices into the cables. They are essentially being used as tone controls, so that users can fine tune their systems. Some even are made with materials such as graphene and some employ magnets along the cables. I actually don't see how they could possibly sound the same at all, given the alterations and disparate designs employed in them. Now, as to more conventional copper cables, it's probably unlikely to hear much difference from them.
stevensctt likes this.
FAMILY ROOM--Legacy Signature II towers(Front L/R), PSB Image 5T towers(Surrounds), Polk LSiM706 center, Denon AVR-X5200W, Krell FPB 400cx, AR ES-1 turntable w/ Audioquest 404-B cartridge, Oppo UDP-203 UHD Blu-ray Player, RCA HD-DVD player, Sony 75" 900E.
MASTER BEDROOM--Dynaudio Audience 82 tower speakers, Outlaw LFM-1 sub, Onkyo TX-NR809, Oppo BDP-83 Universal Disc Player, Panasonic 60-ST60 plasma TV.
mtrot is offline
post #12 of 36 Old 06-02-2020, 11:28 AM
bobknavs's Avatar
Quoted: 2895 Post(s)
Liked: 2094
Definitely a minority report.
leecreek, zielin and Jonas2 like this.
bobknavs is online now
post #13 of 36 Old 06-02-2020, 11:49 AM
JD23's Avatar
Liked: 834
The ones with "fancy gizmos," like batteries across a dielectric, are designed by and for idiots.
N0LA, MUDCAT45, Gary Mertz and 2 others like this.
JD23 is online now
post #14 of 36 Old 06-02-2020, 11:59 AM
Mocs123's Avatar
Quoted: 628 Post(s)
Liked: 413
I think the people designing and selling those "fancy gizmos" cables are genius selling cables for 1000% profit. The people they sell them too are the non electrical engineers with too much money to burn and the gullible.
Transistorious and DavidKirsh like this.
Mocs123 is offline
post #15 of 36 Old 06-02-2020, 12:17 PM
JD23's Avatar
Liked: 834
Touche.
JD23 is online now
post #16 of 36 Old 06-02-2020, 12:42 PM
Kini62's Avatar
Quoted: 2948 Post(s)
Liked: 2824
Funniest thing I've read in a long time.
TokyoJimu and leecreek like this.
Def Tech SC8000
Onkyo RZ820
Roku Ultra, Apple TV, Sharp 70" Quattron
Kini62 is online now
post #17 of 36 Old 06-02-2020, 01:27 PM
mtrot's Avatar
Quoted: 674 Post(s)
Liked: 289
Umm, okay. But do you care to actually comment on the points I made about the cables being designed to have a unique sound? And as to how widely differing the materials and configurations are?
mtrot is offline
post #18 of 36 Old 06-02-2020, 01:55 PM
Quoted: 29 Post(s)
I’m a journeyman electrician and wire definitely matters. When we shop at supply houses we make sure that we can guarantee that the resistance and conductivity meet a certain level. The Home Depot brand wire (southwire i think) you’re buying is crap. You might think you’re getting good, quality connections but you’re not. The voltage can’t make it all the way through that crappy wire and you’re not getting the electricity’s full potential. It downgrades the electricity and it’s no longer as pure and I assure you, your appliances hate that and they don’t run as well.
How ridiculous does that sound? Wire is wire people, there’s no magic copper. Resistance is inherent to the sizing of the wire, it’s all the same.damn.thing.
Transistorious and sigpig like this.
William Nope is offline
post #19 of 36 Old 06-02-2020, 02:38 PM
Liked: 3160
The last thing anyone wants is audio that's been worn down en route from source and arrives at speakers sounding sluggish. Sure, a Shakti Stone or two can perk things up a bit, but do you really want jazzed up audio if you aren't listening to jazz? I know I don't.
post #20 of 36 Old 06-02-2020, 02:59 PM
b curry's Avatar
Liked: 833
Sure.
If it's what you're claiming, it's no longer a speaker wire. It's now some form of resistive capacitive circuit if it alters the sound.
So if that's what you're buying, then you should be aware of or ask what specific frequencies that circuit is altering, how it's altering it (boost or attenuation), and to what degree in dB at those defined specific frequencies.
You should then understand how that RC circuit might interact and affect the playback nature of your particular speakers.
b curry is offline
post #21 of 36 Old 06-02-2020, 04:00 PM
jdlynch's Avatar
Quoted: 409 Post(s)
Liked: 161
I sure hope not. My speakers retailed for over $20K when new and I am totally happy with Belden OFC that I used to wire my entire theater. Anything more is a waste.
Jonas2 and sigpig like this.
Current Equipment: Datasat LS10 w/ Atmos and DIRAC, ATI AT6005, Audio Control Savoy G3, Aerial Acoustics LR5's (LCR), SR3's sides, LR3's (rears),(4) RSL C34E’s (Atmos), Submersive HP, Marantz VP15s1, 123" diag 16:9 Stewart Cima Neve screen, Oppo BDP-103, Palliser Flicks Seating AC Power: Eaton whole-house surge protector at main panel, (3) 20 amp circuits, Surgex XR315 at equipment rack, Cyberpower 1400VA/900 watt, true sine wave UPS.
jdlynch is offline
post #22 of 36 Old 06-02-2020, 04:01 PM
DrJayDub's Avatar
Quoted: 112 Post(s)
Liked: 106
Let’s hope this thread can stay away from the personal insults this time.
IMO if a speaker wire is altering the signal in any way that is measurable then it isn’t doing its job. Ideally it should transparently transmit the signal from the amplifier to the speaker.
I am of the school of thought that if one can’t measure a difference than there is no real audible difference. Human hearing isn’t that sensitive. I am in my 40’s and I can’t hear bumpkis over 15 kHz or so.
I agree that Blue Jeans is a good vendor for quality cable and interconnects. Shouldn’t have to spend any more than that to get that transparent/unaltered signal from amp to speaker.
Yup, I got stuff...
LG OLED65C7P, LG 55EG9100
Marantz SR6012, Classe Sigma Amp5, Oppo BDP-203
PSB Synchrony One mains, Synchrony two center and surrounds, 2x SVS SB12-NSD
XBox One X
DrJayDub is offline
post #23 of 36 Old 06-02-2020, 05:26 PM
bobknavs's Avatar
Liked: 2094
No, I don't care to comment.
All that I meant was that your view might be in the minority of posters here.
I'm not equipped to debunk the claims of audiophiles. Too bad they're not more common. It might be good for the economy.
post #24 of 36 Old 06-02-2020, 05:54 PM
Jonas2's Avatar
Quoted: 3329 Post(s)
Liked: 2202
I would only contradict that by saying that actually they are designed by "geniuses" - because they know idiots will buy them.... Cha-ching!!
sigpig and teetertotter like this.
7.2.4 System: Display: Sony XBR-65X930D; Processing: Anthem AVM60
Mains:
Paradigm Prestige 85F and 55C; Side / Rear Surrounds: Totem Acoustic Tribe III / Tribe I; Amplification: D-Sonic M3a-2800-7 (7ch. x 400w)
ATMOS:
Definitive Technology DI8R; Amplification: Class D Audio SDS-470C (4ch. x 300w)
Subwoofers:
2 x SVS-SB13Ultras; Media: Oppo UDP-203, Pioneer CLD-59
Jonas2 is offline
post #25 of 36 Old 06-02-2020, 05:56 PM
Quoted: 337 Post(s)
Liked: 269
I have heard a difference with a certain cable BUT when it gets into the 100's it makes no sense and is better put toward a better speaker fund.
stngray72 is offline
post #26 of 36 Old 06-02-2020, 05:57 PM
bobknavs's Avatar
Liked: 2094
I'd suggest the famous Jade Egg from Goop rather than a Shakti Stone. https://shop.goop.com/shop/products/...gg?country=USA
Some have trouble figuring where to insert it in an audio setup, though.
Jonas2 likes this.
post #27 of 36 Old 06-02-2020, 06:08 PM
Jonas2's Avatar
Liked: 2202
Whoa....he, he....didn't know what that was exactly until I started reading, was wondering what you meant be insert into the audio setup....now I know...
Mains:
ATMOS:
Subwoofers:
Jonas2 is offline
post #28 of 36 Old 06-02-2020, 06:32 PM
JD23's Avatar
Liked: 834
Attempting to tailor the sound with DSP in a pre/pro or AVR is infinitely more effective than doing so with a passive cable, which is a primitive, blunt instrument in comparison. The best a cable can be is completely transparent; otherwise, it can only added losses to the system, attenuate some frequencies, or contribute to amplifier instability if designed particularly poorly. Engineers involved with RF design or anyone with a decent understanding of transmission line theory would laugh at the fairy dust marketing babble that is ubiquitous on the websites of some audiophile cable manufacturers.
JD23 is online now
post #29 of 36 Old 06-02-2020, 08:55 PM
Liked: 4
Why does this topic always populate forums? and why I'm I commenting on this? if you are an optimizer of systems and have the budget to experiment with the perceived or real tonal changes of wires please do so. That is what a retail sales return policy is for.
nreeque is offline
post #30 of 36 Old 06-02-2020, 08:58 PM
Ryan Statz's Avatar
Quoted: 1298 Post(s)
Liked: 1095
If it's the same gauge/composition (i.e. Oxygen-Free Copper), it makes no difference whether you spend $200 on a 6 foot cable or less than $50 for a 100' spool.
Home Theatre: Marantz SR6014 | KEF Q750 | KEF Q650c | KEF Q150 | HSU ULS-15 MK2 | Sony XBR55X900E | PS4 Pro | Xbox One S | Nintendo Switch
Music: Cambridge Audio AXR100 | Fluance RT85 | Ortofon 2M Blue | Cambridge Audio AXC35 | Neat Motive 3
Ryan Statz is online now
Reply Speakers
