Front Stage Upgrade - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By reclusion12
  • 1 Post By Tuba4me
post #1 of 15 Old 06-02-2020, 11:08 AM - Thread Starter
Liked: 1
Front Stage Upgrade
Just hooked up my Denon x1600h and HSU VTF2-MK5. Front stage are Polk T50 and a T30 center. Micca 6.5 in ceiling, and Polk OMW3 for surrounds. Seating is ~11 feet from the fronts. Room goes back about 20 feet past the seating. "Listening space" is about 13x11. Total room are is larger, 30x16?. See image for layout.
I'd like to hover around $1,000 shipped for LCR. 50% Movie, 25/25 TV/Music. I have a toddler and infant, so towers are preferred due to the risk of falling over. That said, I've spent hours looking at Chane 2.4/5.5, Emotiva (off the table due to emobucks promotion being gone), JBL. There is NO WAF here, she can deal with whatever I choose. Size isn't an issue, would have no problem rolling some JBL 590s down the stairs. I'm just looking for some guiding and convincing on what the best long-term solution will be.
Hetfieldjames likes this.
reclusion12 is offline
post #2 of 15 Old 06-02-2020, 12:09 PM
Quoted: 18 Post(s)
I'm too much of a noob to help you, but I have a very similar thread going and have gotten some excellent advice and questions answered so far. My budget is almost the same as yours, so maybe it would help some? The only real difference is that I'm almost 100% gaming/HT usage, but I can't imagine it would change the recommendations that much with 25% music.
Help replacing Front and Centers on a budget https://www.avsforum.com/forum/89-speakers/3150010-help-replacing-front-centers-budget.html
I wish you luck!
ViperYourMother is offline
post #3 of 15 Old 06-02-2020, 12:42 PM
khcoach's Avatar
Quoted: 96 Post(s)
Liked: 74
could still do Emotiva's if you did T1+ and C1+ for $950 plus any tax.
khcoach is offline
post #4 of 15 Old 06-02-2020, 01:20 PM - Thread Starter
Liked: 1
Worth over the JBL 590s? Also, I'm willing to do bookshelf for the Chane 2.4 I think
post #5 of 15 Old 06-02-2020, 01:29 PM
Ryan Statz's Avatar
Quoted: 1299 Post(s)
Liked: 1097
Emotiva T-Zero towers + C1+ CC. You'd even have room to add a pair of B1+ for surrounds.
Home Theatre: Marantz SR6014 | KEF Q750 | KEF Q650c | KEF Q150 | HSU ULS-15 MK2 | Sony XBR55X900E | PS4 Pro | Xbox One S | Nintendo Switch
Music: Cambridge Audio AXR100 | Fluance RT85 | Ortofon 2M Blue | Cambridge Audio AXC35 | Neat Motive 3
Ryan Statz is online now
post #6 of 15 Old 06-02-2020, 02:00 PM - Thread Starter
Liked: 1
what’s the CC? T-zero better option that the 1+? My surround is fine IMO, not looking to change that at the moment
post #7 of 15 Old 06-02-2020, 04:51 PM
Ryan Statz's Avatar
Liked: 1097
C1+ is the centre channel.
post #8 of 15 Old 06-02-2020, 06:02 PM - Thread Starter
Liked: 1
I read your post differently - got it now . Noticable decrease between the zero and the T1+?
post #9 of 15 Old 06-02-2020, 06:53 PM
Tuba4me's Avatar
Quoted: 56 Post(s)
Liked: 53
I just went through the same scenario. Our children are a little older, 5 and 7, but my wife babysits several children that are in the toddler to infant age, so I was leery of speaker stands as well.
I ultimately went with the Chane A5/2.4 bundle for just over $1200 shipped. It’s a little over budget, but I can tell you the A5 towers are sturdy and seem very well balanced. A grown man would need to use considerable force to knock one over.
I read some review from a google search where a reviewer commented that the T1 towers could be a little tipsy. I can not validate this one way or the other because I have never owned them.
Tuba4me is offline
post #10 of 15 Old 06-02-2020, 07:42 PM - Thread Starter
Liked: 1
You know, that Chane bundle has me coming back every night and pondering hitting that Confirm button
post #11 of 15 Old 06-02-2020, 07:54 PM
Zorba922's Avatar
Quoted: 9591 Post(s)
Liked: 7418
Well, the Emotiva site says the T1s are:
Weight: 40.1 pounds (unboxed). 53 pounds (boxed).
The Chane site says:
Weight (lbs) 55
If the Chane's 55lbs is for unboxed, then it would be 15lbs heavier than the T1s. If it's for boxed, then it'd only be 2lbs heavier.
~ Are you a "geek hobbyist" obsessed with squeezing out that last 5-10% improvement? The economy will thank you...especially the Chinese one. Or are you more of a get-set-and-forget "casual user" who simply wants to increase your enjoyment of movies, TV and gaming? Relax, HT isn't rocket science, nor does it have to cost an arm and a leg---especially if you ignore the aforementioned vocal minority. And remember to smile...it's just a silly hobby, after all. :)
Zorba922 is offline
post #12 of 15 Old 06-02-2020, 08:01 PM
Tuba4me's Avatar
Quoted: 56 Post(s)
Liked: 53
Since you have room under your projection screen, another option might be using 3 matching LCR’s like the A2.4 or Ascend 340SE under the screen. Check out another forum member’s setup using 3 of the 340SE. He posted this picture over in the Ascend SE owner’s thread.
Edit: thinking about the child safety, there is still some risk involved with this.
Tuba4me is offline
post #13 of 15 Old 06-02-2020, 08:05 PM
Tuba4me's Avatar
Quoted: 56 Post(s)
Liked: 53
I think the A5 is 63 lbs boxed. I assume that’s what the 63 pounds means at the top of the A5 product page, near the price. Then the 55 pound number in the specs is unboxed.
Zorba922 likes this.
Tuba4me is offline
post #14 of 15 Old 06-02-2020, 09:01 PM - Thread Starter
Liked: 1
Yea, i'm thinking the kid safety is going to cost me some extra buck. so be it, I guess!
post #15 of 15 Old 06-02-2020, 10:19 PM
Tuba4me's Avatar
Quoted: 56 Post(s)
Liked: 53
It’s going to be an investment that should last a long time. For mostly HT use, and using a subwoofer(s), the A5 towers should be sufficient to last for many years to come to handle the L&R channel duties.
My thought was that some day I might want to try a bigger 3-way center like the Sierra Horizon or possibly one of the new Chane offerings once they get released, but I’m quite satisfied with the A2.4 for now.
Tuba4me is offline
Reply Speakers
