Klipsch rp280f and Rp8000f - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 06-02-2020, 10:31 PM - Thread Starter
kenlunsford's Avatar
Quoted: 36 Post(s)
I’ve been looking at the different lines of this series... aside from aesthetics, and vented tweeter, what’s the main differences? Does sound quality differ between the two?
I was looking at the frequency response measurements of the RP8000f and noticed it has a nasty dip between 1.5k and 4K. Does the 280F have the same issue towards the same range?
I never thought I liked Klipsch. However, I’ve heard the new rp600m and was quite impressed.
Just looking for more info between the 2.
B&W 683s2
B&W HTM61s2
B&W M1 satellites
Onkyo RZ830
Vizio P55-F1
kenlunsford is offline
post #2 of 2 Old 06-03-2020, 03:07 AM
Quoted: 29 Post(s)
Liked: 2
The Rp-280f and Rp8000f were my first choice too. I did a lot of research. Most of what you ask have already been discussed. I was about to get the rp-280f for 850, but decided a on a jbl 590 since someone was selling it used for $600. Good thing I did.
My buddy bought the 8000f and was impressed with it initially. Then 2 month later, he got rid of it. Just hearing it is not good enough, you have to spend some times with it. I think the klipsch reference premier is best suited for movies, not so much for music. I didn't like it either, it lacks detail and doesn't sound smooth. Low mid and bass doesn't sound clean. I have JBL 590. Which my buddy got rid of the 8000f for.
TenjiT is offline
Reply Speakers
