What kind of speakers are these? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By Eddy_Z
post #1 of 6 Old 06-03-2020, 01:37 AM - Thread Starter
PunisaAudio's Avatar
Liked: 0
I have a pair of speakers I got. They're made in Japan and have a single input on the back. How can I use them? All my "normal" speakers have two inputs (black and red). I believe they were part of an old Benytone reciever.
ID:	2736434   Click image for larger version
ID:	2736436   Click image for larger version
ID:	2736438   Click image for larger version
PunisaAudio is offline
post #2 of 6 Old 06-03-2020, 04:40 AM
Quoted: 172 Post(s)
Liked: 168
Looks like a simple RCA connection. You'd need a "Y" splitter cable....... 2 females to 1 male.
HT - 5.2.2 ATMOS With: Klipsch DS Series In-wall/In-ceiling Speakers|2x Rythmik LV12F|Denon AVR-X3300W|Sony UBP-X800|Sony XBR-85X900F|AppleTV 4K
Music - 2.1: Ascend Acoustics Sierra-2EX|Rythmik 12" Sealed Direct Servo Sub|Adcom GFA-5500 With LX-Elite mod by Musical Concepts|Parasound Halo P5|Cambridge Audio ID100 Digital Dock|Audio by Van Alstine Humdinger
Eddy_Z is offline
post #3 of 6 Old 06-03-2020, 04:46 AM
Quoted: 172 Post(s)
Liked: 168
Actually, all you need are these to connect your speaker wire to them....
Eddy_Z is offline
post #4 of 6 Old 06-03-2020, 04:50 AM
eljaycanuck's Avatar
Quoted: 2165 Post(s)
Liked: 3150
Dunno what brand they are but if they're passive (a quick look inside should confirm it) you should be able to use a male-RCA-to-bare-wire cable to connect them to the binding posts on your receiver.
eljaycanuck is offline
post #5 of 6 Old 06-03-2020, 05:03 AM
Quoted: 172 Post(s)
Liked: 168
You could strip an RCA cable as suggested, just be sure to get the wires hooked up to the proper polarities (+/-).
I also found these which are a bit cheaper than the above suggestion:
eljaycanuck likes this.
Eddy_Z is offline
post #6 of 6 Old 06-03-2020, 09:11 AM - Thread Starter
Liked: 0
Thanks for the info guys! Never knew that!
In the meanwhile I found out where they came from, they were a part of an "Benytone 8 Track & Cassette Tape Fm Am Stereo Receiver M7030".
I like how they look, very vintage, maybe the sound is not bad
Will try as soon as possible.
Reply Speakers
