KEF Q750 or Paradigm 700f - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By sigpig
  • 1 Post By monkeysez
post #1 of 5 Old 06-03-2020, 04:42 AM - Thread Starter
monkeysez's Avatar
Question KEF Q750 or Paradigm 700f
Hi folks,
I am torn between the KEFQ750 and the Paradigm 700f. I am leaning towards the paradigms. Which one has more ummmpfff or bass to it. I've read that the KEF is more laid back and I know the answer is to demo, but I am not in a position to do so.
Room setup: not a dedicated theater room, but will be paired with surrounds and subwoofer
Requirements: White Finish for the outside
Primary Usage: Movies and music
Budget: Around $750ish a piece (recognizing the Q750 are a bit more in today's world). The 700f can be had likely for $600 a piece.
I am open to suggestions as well.
monkeysez is offline
post #2 of 5 Old 06-03-2020, 01:15 PM
Quoted: 1279 Post(s)
Liked: 1116
I auditioned comparable Kef and Paradigm speakers and chose the Paradigms.
My wife and I loved the clarity and precision of the Paradigms over the Kefs.
Maybe order in a bookshelf pair of each to audition?
Jonas2 likes this.
sigpig is online now
post #3 of 5 Old 06-03-2020, 03:35 PM
Jonas2's Avatar
Quoted: 3317 Post(s)
Liked: 2197
I've been in a HT with Q-Series, and it sounded pretty good really. I too compared the (previous) R-series to Paradigm Prestige, and did find those laid back as well. Not necessarily in a bad way, but I did go with the Paradigms - they just seemed to add a bit more overall to the performance, bit more "lively", whatever that means (), and just fit my preferences a bit better.
FWIW - I've never heard the 700F, so I can't speak accurately to at least that particular comparison.
7.2.4 System: Display: Sony XBR-65X930D; Processing: Anthem AVM60
Mains:
Paradigm Prestige 85F and 55C; Side / Rear Surrounds: Totem Acoustic Tribe III / Tribe I; Amplification: D-Sonic M3a-2800-7 (7ch. x 400w)
ATMOS:
Definitive Technology DI8R; Amplification: Class D Audio SDS-470C (4ch. x 300w)
Subwoofers:
2 x SVS-SB13Ultras; Media: Oppo UDP-203, Pioneer CLD-59
Jonas2 is online now
post #4 of 5 Old 06-04-2020, 05:28 AM - Thread Starter
monkeysez's Avatar
Thank you all for the suggestions. I'm going with the paradigms.
sigpig likes this.
post #5 of 5 Old 06-04-2020, 07:23 AM
Jonas2's Avatar
Liked: 2197
Let us now what you think once you've got them, and have had a chance to give them a good listen!
Mains:
ATMOS:
Subwoofers:
Reply Speakers
700f , comparison , Kef , Paradigm , Q750
