Which budget subwoofers has an LFE input - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By gajCA
post #1 of 16 Old 06-03-2020, 02:00 PM - Thread Starter
thedjs6's Avatar
Quoted: 33 Post(s)
Are there any budget subs (under $200) that have an LFE input?
thedjs6 is offline
post #2 of 16 Old 06-03-2020, 02:21 PM
gajCA's Avatar
Quoted: 10181 Post(s)
Liked: 7214
All of them do.
Subs with only speaker level inputs are no longer around.
Geoff A. J., California
gajCA is online now
post #3 of 16 Old 06-03-2020, 02:33 PM
austinout's Avatar
Quoted: 35 Post(s)
On your budget you may want to consider some of the Dayton offerings.
austinout is offline
post #4 of 16 Old 06-03-2020, 03:30 PM
afrogt's Avatar
Quoted: 2507 Post(s)
Liked: 1641
afrogt is online now
post #5 of 16 Old 06-04-2020, 10:43 AM - Thread Starter
thedjs6's Avatar
Quoted: 33 Post(s)
Originally Posted by gajCA View Post
All of them do.
Thanks for the reply. I'm new in this and so excuse me if I ask a stupid question. My Sony receiver has a single wire (LFE) outlet for for a sub. (It really has two outlets but that's for two separate subs) Most of the subs I've look at have two input ports so I would think I would need some kind of special wire or connector to make a connection. ( that's not a problem) But if I did this will my auto calibration still set the cross-over, level and other things or will they have to be set manually? Would it be better for me to keep looking and find a sub with a single (LFE) input? Sony has one that will match my speakers and has a single LFE input connection, however, I've seen some mixed reviews on it and that worries me a little.
Thanks again.
thedjs6 is offline
post #6 of 16 Old 06-04-2020, 10:44 AM - Thread Starter
thedjs6's Avatar
Quoted: 33 Post(s)
Thank you. I'll check these out.
thedjs6 is offline
post #7 of 16 Old 06-04-2020, 10:44 AM - Thread Starter
thedjs6's Avatar
Quoted: 33 Post(s)
thedjs6 is offline
post #8 of 16 Old 06-04-2020, 10:54 AM
gajCA's Avatar
Liked: 7214
Thanks again.
An RCA splitter where one plug becomes two, is very inexpensive so no worries whether it has one rca input or two.
Often if there are two one is labeled "lfe" so you just use that one with a single wire.
You just turn the knob on the back of the sub that says "crossover" to its maximum so it does not interfere with the crossover that you set in the receiver.
This right now is the very best under $200 subwoofer bargain out there and it won't last long.
https://www.jbl.com/studio-5-series/...c7012b0a1c0e10
And, sorry if I came off as rude, there are no "stupid" questions.
My apologies.
gajCA is online now
post #9 of 16 Old 06-04-2020, 11:12 AM - Thread Starter
thedjs6's Avatar
Quoted: 33 Post(s)
My apologies.
No need for an apology. I didn't think anything you said was rude. It's just that this is all new to me and I feel like a lot of the time the questions I ask show how little I know. In fact the more I read the more confused I get. Anyway, thanks for the reply and I'm going to check out the sub you mentioned.
thedjs6 is offline
post #10 of 16 Old 06-04-2020, 11:17 AM
gajCA's Avatar
Liked: 7214
No worries.
Most of my friends/family who've had surround systems for years have no clue how to set them up "properly."
Plenty of helpful folks here to answer your questions.
gajCA is online now
post #11 of 16 Old 06-06-2020, 04:39 PM
Quoted: 337 Post(s)
Liked: 269
My apologies.
I just wanted to chime in and say i have that subwoofer and the amp gets hot and starts to have a burning smell if pushed past half way. I dont no if i just got a bad one but i wanted op to be aware of this possibility.
stngray72 is offline
post #12 of 16 Old 06-07-2020, 07:50 AM
gajCA's Avatar
Liked: 7214
First time I've read that about that sub or any JBL sub; hopefully you put in a warranty claim and stopped using it as you do NOT want a fire.
It's actually a good idea any time you travel, well, when you can travel again, to unplug your subs.
gajCA is online now
post #13 of 16 Old 06-07-2020, 09:13 AM
Quoted: 337 Post(s)
Liked: 269
That was playing music for what I consider not to be that long.
post #14 of 16 Old 06-07-2020, 09:23 AM
gajCA's Avatar
Liked: 7214
Obviously a manufacturing flaw and if JBL is notified they'll send a new amp unless it's out of warranty.
Do not use that sub.
sigpig likes this.
gajCA is online now
post #15 of 16 Old 06-07-2020, 04:01 PM
Quoted: 337 Post(s)
Liked: 269
Do you no how long the warranty is?
post #16 of 16 Old 06-08-2020, 06:26 AM
gajCA's Avatar
Liked: 7214
Looks like 5 years, with one year of simply exchanging the product.
Call us: 1.800.336.4525
1 Year / 5 Years Warranty
Products purchased online or from an authorized local retailer and under warranty may qualify for an exchange with a valid receipt.
Purchases made from an unauthorized dealer will not be eligible for exchange.
gajCA is online now
Reply Speakers
