cobbled towers into ceiling or store bought? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By gregoryperkins
post #1 of 4 Old 06-06-2020, 05:00 AM - Thread Starter
Liked: 0
new house with no room for our old technics SB-A52 tower speakers so i'm going to need to put my front left/right in the ceiling. I've though of tearing into these towers and using one of the 12" woofers plus the mid and tweeter to make custom units in the ceiling, angling the speakers towards me. Any thoughts on, if done right, i'd get better sound from doing this or should i just go buy some units made for this purpose, such as some with the angled 8" woofer and adjustable tweeter you can get off amazon?
A Fawcett is offline
post #2 of 4 Old 06-06-2020, 05:04 AM
gregoryperkins's Avatar
Quoted: 761 Post(s)
Liked: 281
Did you forget to post this on April first?
Why would you want to do something like that? What is your purpose, music?
eljaycanuck likes this.
gregoryperkins is offline
post #3 of 4 Old 06-06-2020, 05:11 AM
eljaycanuck's Avatar
Quoted: 2170 Post(s)
Liked: 3162
If it's done right it might work...but it might not. If you're planning to give away or throw away the speakers, might as well experiment with them instead.
eljaycanuck is offline
post #4 of 4 Old 06-06-2020, 07:51 AM
Quoted: 443 Post(s)
Liked: 595
I think trying to cobble something together is a bad idea particularly if you aren't familiar with DIY speaker builds. Do some research and buy some.
Gary Mertz is offline
Reply Speakers
