Desperate for clear dialogue - AVS Forum | Home Theater Discussions And Reviews
 36Likes
post #1 of 133 Old 06-24-2020, 01:20 PM - Thread Starter
Quoted: 37 Post(s)
Liked: 1
I am setting up a home cinema for the first time, solely for the purpose of achieving clear movie dialogue. I want to hear the whispering and mumbling with crystal clear sound.
I am struggling. First let me post my setup and some pictures, a simple 3.0
Monitor C150 center
Monitor C150
Marantz 1501 receiver
(the front speakers in the picture are old ones which i now replaced stupidly. It did nothing to improve clear dialogue)
I've checked the wires and there should be no problem.
The center speaker has doorstops under it which i can use to aim it towards my ears.
I was told the rug would help.
I have tried Dynamic EQ and Dynamic volume. Dynamic EQ seems to muddle dialogue so i am mostly going without it. There is a slight improvement, but even on "heavy" It is not enough for quiet talking scenes. Turning up the center channel also turns up the action from it, which i dislike.
I really hope there is something obvious I am missing, but I find it to be quite terrible. I've got one week to send the stuff back, hopefully you can share your opinions.
My dream would be to have ONLY dialogue come through the center channel.
ID:	2748244   Click image for larger version
Plasmi is offline
post #2 of 133 Old 06-24-2020, 02:05 PM
Vergiliusm's Avatar
Quoted: 376 Post(s)
Liked: 696
Your problem is that everything is upside down.
Nothing immediately jumps out. I would move that table back as close to the TV as possible and move the center to the front edge of the table. I'm not familiar with the settings on Marantz receivers, but there should be some kind of loudness management settings. You can experiment with dynamic range compression and dialog normalization.
You could add a sub and high pass the center from 80-100 Hz so it's not having to try to reproduce the lower frequency signals.
"Rock and roll is alive and alright" Sloan
Vergiliusm is offline
post #3 of 133 Old 06-24-2020, 02:14 PM
MrBobb's Avatar
Quoted: 325 Post(s)
Liked: 149
I have a feeling the Marantz is not firing up the correct CODEX, does the front tell you correctly you are playing DD/DTS etc?
MrBobb is offline
post #4 of 133 Old 06-24-2020, 02:15 PM
philpoe's Avatar
Quoted: 269 Post(s)
Liked: 110
Out of curiosity, what's your budget to resolve all of this? I ask since you said that you had a week to sent the stuff back.
It may be that you need to consider replacing the center channel, among other options.
I am struggling.
philpoe is offline
post #5 of 133 Old 06-24-2020, 02:26 PM
Ryan Statz's Avatar
Quoted: 1317 Post(s)
Liked: 1183
Monitor C150 center
Monitor C150
One thing I would try is to have the centre speaker flush with the front of that end table you have it on right now. Another thing you can do is bump up the trim on the centre on your AVR by 3dB.
It might also be helpful to know what volume levels you normally listen.
Pete7874 likes this.
Home Theatre: Marantz SR6014 | KEF Q750 | KEF Q650c | KEF Q150 | HSU ULS-15 MK2 | Sony XBR55X900E | PS4 Pro | Xbox One S | Nintendo Switch
Music: Cambridge Audio AXR100 | Fluance RT85 | Ortofon 2M Blue | Cambridge Audio AXC35 | Neat Motive 3
Ryan Statz is online now
post #6 of 133 Old 06-24-2020, 03:09 PM
Dave in Green's Avatar
Quoted: 4517 Post(s)
Liked: 4179
... Turning up the center channel also turns up the action from it, which i dislike....
... My dream would be to have ONLY dialogue come through the center channel.
There's not much you can do about each individual program's sound mix. Whatever is mixed into the center channel is going to come out of the center speaker. Some producers emphasize sound effects over dialog so simply turning up the volume on the center channel won't help when sound effects are drowning out dialog. However, some producers emphasize dialog over sound effects so you shouldn't have an issue with this type of programming.
Dave in Green is online now
post #7 of 133 Old 06-24-2020, 03:15 PM
Zorba922's Avatar
Quoted: 9664 Post(s)
Liked: 7474
It's possible that there's some mistake in the receiver settings where it's not processing the source signal correctly. Another poster had the same exact problem recently.
https://www.avsforum.com/forum/89-sp...l-muddled.html
See if anything in that thread is useful for you.
If not, the quickest way to troubleshoot is to hit your closest Best Buy and take home a (preferably open-box) good quality center speaker and see if you're still getting lousy dialogue.
The Klipsch RP-600C would be a good bet.
BB gives you 14 days to return for a no hassle refund.
~ Are you a "geek hobbyist" obsessed with squeezing out that last 5-10% improvement? The economy will thank you...especially the Chinese one. Or are you more of a get-set-and-forget "casual user" who simply wants to increase your enjoyment of movies, TV and gaming? Relax, HT isn't rocket science, nor does it have to cost an arm and a leg---especially if you ignore the aforementioned vocal minority. And remember to smile...it's just a silly hobby, after all. :)
Zorba922 is offline
post #8 of 133 Old 06-24-2020, 03:32 PM
afrogt's Avatar
Quoted: 2527 Post(s)
Liked: 1654
The Marantz NR1501 slimline uses the basic Audyssey Mult EQ, so not XT or XT32.
Actually it uses, MRAC (Marantz Room Acoustic Calibration) auto setup system (microphone included). So that may even be more basic than Audyssey Mult EQ. Could that be part of the problem?
I think the NR1501 is 10 years old.
Afro GT
afrogt is online now
post #9 of 133 Old 06-24-2020, 04:08 PM
LastButNotLeast's Avatar
Quoted: 3068 Post(s)
Liked: 2899
Raising the xo and level of the center speaker is the best you can do with the avr you have. Unfortunately, there's no way to increase only the frequency range that would target dialog.
Michael
LastButNotLeast is offline
post #10 of 133 Old 06-24-2020, 04:14 PM
alan0354's Avatar
Quoted: 2287 Post(s)
Liked: 610
I just conquered this problem of not having a clear dialog, it's the speaker position. You have a low ceiling ( vaulted ceiling), your room might not be optimized for sound. Before getting into sound panels and all, try moving the L and R speakers farther apart or closer. Speaker placement is very very critical.
Try move the speaker forward from the clutter, just experiment. If all else fails, you might have to try sound panels and that can cost and it's a pain.
alan0354 is offline
post #11 of 133 Old 06-24-2020, 04:19 PM
craig john's Avatar
Quoted: 1704 Post(s)
Liked: 2024
Go into the Speaker Config menu in your Marantz and set Center to No. This will engage "Phantom Center" which will send the Center Channel content equally to the L/R speakers. You will then *hear* the Center Channel content as if it was in the center. This works best if you're seated exactly in the central seating position. If this improves dialogue, you can either just stick with it, or you can use that conclusion as the reason to upgrade your center channel speaker. A 3rd speaker identical to your L/R's would be ideal.
Craig
PS. You can download the manual for your Marantz receiver here:
https://www.us.marantz.com/en-US/sho...us=discontinue
See Pages 21 and 22 to read about the Speaker Config menu.
Lombardi said it:
"Perfection is not attainable, but if we chase perfection we can catch excellence.
My System (Edited Feb. 2020 to add 4K and Atmos updates)
craig john is offline
post #12 of 133 Old 06-24-2020, 05:19 PM
pase22's Avatar
Quoted: 3867 Post(s)
Liked: 3332
Monitor C150 center
Monitor C150
Most Denon/Marantz have a dialog adjustment feature. Yours is an older model so that sure that was available for your unit. FWIW audyssey always sets my center too low so have to manually turn it up 3-4dbs.
Kef LS50,Q200C, Q100, Kef Kube 10B (X2) , Denon AVR-X3400H, Emotiva A-300, Panasonic 50" Plasma, Xbox One.
Bedroom: Kef Q100 ,JBL Loft 20, SVS SB-2000, Denon AVR-S710W, PS3, 32" Insigna LED.
pase22 is offline
post #13 of 133 Old 06-24-2020, 05:28 PM
spyboy's Avatar
Quoted: 392 Post(s)
Liked: 339
I don't know about "most Denon/Marantz". AFAIK only the top models of Denon have the dialogue enhancement circuit. I use it with my X8500h to good effect.
spyboy is offline
post #14 of 133 Old 06-24-2020, 06:03 PM
m0j0's Avatar
Quoted: 1475 Post(s)
Liked: 2386
After experiencing similar frustrations with regard to dialog, I upgraded my center channel and bought a receiver with Audyssey XT32. I also needed to move the center a little bit forward to give it some clearance from the wall and tilt the center channel to point directly at ear level.
MartinK likes this.
m0j0 is online now
post #15 of 133 Old 06-24-2020, 06:51 PM
Bill-99's Avatar
Quoted: 1118 Post(s)
Liked: 729
This topic comes up regularly on these forums, churns a while and then goes dormant. It might be a candidate for a dedicated thread one day or a sticky. Until then, here are a collection of ideas gleaned from these forums which have worked in my system. That makes this anecdotal so YMMV when it comes to results in your system.
IMO (no more, no less) it seems to frequently be the case that there isn't one single thing that fixes the problem but rather attention to lots of small things that cumulatively make a substantial difference.
Use a dedicated center channel rather than a phantom center channel. A dedicated center will invariably do a better job and cover more seats in your listening space.
Finding and deploying a quality center channel will usually dictate how much you enjoy your home theater. Fortunately, there are lots of candidate speakers available with fans and detractors of each. Look for one that sounds natural and has good dispersion characteristics that cover the seats that are important in your home theater.
Carefully position all speakers, not just the center channel. A bad setup can create issues with dialog clarity. A good place to look for guidance is the Dolby web site here:
https://www.dolby.com/us/en/home/index.html
Avoid placing a center channel inside of a shelf or cubby since that can create reflections that degrade sound quality. A free-standing center channel below your display is often a good location, but some rooms accommodate that better than others.
Center channel location for best sound can collide with décor priorities. How this is addressed in each home theater depends on the parties involved in the decision. Try to err on the side of placement that gives then best center channel sound quality.
Try to eliminate obstructions between the listening positions and the center channel (e.g. tables, chairs, ottomans, etc.) since these can potentially degrade sound. If you aren't sure that there's an impact, try moving items out of the room one at a time and see if dialog clarity improves.
Verify that the center channel is aimed at ear level for the main listening position.
Consider judicious use of acoustic treatment for a room that's too lively.
Try removing the center channel grill to see if dialog clarity improves.
If your AVR / processor support it, be sure to configure speaker distance and size.
Try using the EQ system that comes with your AVR / processor. It can make a big difference in overall sound quality, including improvements in dialog clarity.
Check to see if your AVR / processor has the ability to increase center channel volume. Sometimes a dB or two can improve dialog clarity.
Experiment with Dolby Volume. It can potentially give a lift to dialog that's muddy.
Try lowering bass and increasing treble. It can improve dialog clarity with some material.
Recognize that there's going to be source material that just can't be rescued. It could well be the case that closed-caption is the best available option with really poor content.
koan and lmidgitd like this.
5.2.4 System: Anthem AVM 60 | Anthem Statement A5 | ATI AT526NC | Revel F208, C208, M106, C763L | Rythmik F12 | Oppo UDP-203 | Roku Premiere+ | DIY HTPC | Samsung UN65KS800DF
3.1 System: Anthem MRX 520 | Revel M106, C205 | Velodyne FSR-12 | Sony XBR-49X900E
Bill-99 is online now
post #16 of 133 Old 06-24-2020, 07:11 PM
pase22's Avatar
Liked: 3332
My low level Denon S710 has that feature. Only the S500 series (not sure about the S600 series) doesn't support it. The OP's AVR is 10 years old and I don't know if that feature was available or if his model doesn't support it.
pase22 is offline
post #17 of 133 Old 06-25-2020, 08:07 AM - Thread Starter
Quoted: 37 Post(s)
Liked: 1
The receiver says "MULTI-IN"
I don't like it very loud. 55-66 is the loudest I enjoy.
I will look into that thread. However, I am afraid of buying another center as if that fails it is probably mean I will never find one, it's just me being picky. I'm kind of dreading to try a new one, as weird as that sounds.
Plasmi is offline
post #18 of 133 Old 06-25-2020, 08:15 AM
Mocs123's Avatar
Quoted: 631 Post(s)
Liked: 417
One option to consider is it may be reflections from your room. It looks like you have low sloping ceilings, and a hard floor, so with all those hard surfaces you may be getting reflections of the sound milliseconds apart from the first and second reflection points. Our brain struggles to determine what is the original sound in those cases and it often sounds muddy, or like the person on screen is mumbling. If that is the case, a new center channel speaker won't help, and you would need to add absorption to your reflection points.
7.4.4 Theater Room: JVC-RS500, Silver Ticket AT 2.35:1 142”, Onkyo RZ830, Anthem PVA-7, Panasonic UB420, Apple TV 4K, JBL Studio 530’s, Dual Driver VBSS
3.1 Living Room: Samsung 64” F8500 Plasma, Anthem MRX 300, Dynaudio Audience 52’s, Dynaudio Audience 122C, NHT SubOne, Roku Express (2019)
Mocs123 is offline
post #19 of 133 Old 06-25-2020, 08:22 AM
Zorba922's Avatar
Liked: 7474
That's what return policies are for!
Trial and error is an inevitable part of life. And you're right to be picky about the CENTER, since it does 70-80% of the HT/TV output and 98% of the DIALOGUE. It is *the* true workhorse/backbone of any HT setup and thus the absolute LAST place you should ever cut corners.
By all means, first make sure there is no error in your receiver settings or source settings, as happened in the thread I linked.
The Monitor C150 is a 2 way MTM, those can be hit-or-miss. A safer bet is a 3-way center, like the Emotiva C1 or C2, Infinity RC263, etc.
Like Polk, Monitor Audio doesn't offer a 3 way center until you get to their higher level series (Silver and Gold), the sneaky mofos---they want the consumer, who is easily bamboozled by the "timbre matching" sales lie, to upgrade all 5 speakers just to get one decent center!
Zorba922 is offline
post #20 of 133 Old 06-25-2020, 08:24 AM
Jawaburger's Avatar
Quoted: 253 Post(s)
Liked: 261
What are you using for your sources? Multi-In means your source is doing the audio processing.
Sharp LC-80LE844U | HT PC | Marantz AV8003 | Marsh Sound Design A400s (FL/FR) | Marantz MM7055 (C/SL/SR) | PSA MTM 210T (FL/FR) | PSA MTM 210C (Center) | Phase Tech PC 3.1 (SL/SR/SB) | Dual PSA S1811 Subs
Jawaburger is online now
post #21 of 133 Old 06-25-2020, 08:28 AM
craig john's Avatar
Liked: 2024
Are you using the analog multi-channel connections? If not, how is the BluRay player connected to the receiver? Do you have the BluRay player's digital output set to send PCM or Bitstream? I suggest setting it to Bitstream so your receiver can do the Dolby or DTS decoding. Then your receiver will read "Dolby Digital" or "DTS", or whatever codec you use.
If all else fails, try phantom CC as I described above just as an experiment to see if it helps. Doesn't cost anything to try it. You can always turn the CC back on.
Craig
Lombardi said it:
post #22 of 133 Old 06-25-2020, 08:41 AM
Ryan Statz's Avatar
Liked: 1183
Like Polk, Monitor Audio doesn't offer a 3 way center until you get to their top-shelf (Gold) series
The Silver C350 is a 3-way. I had inquired about it during my own quest for a different CC, and no one seemed interested to even offer any insight on that one.
post #23 of 133 Old 06-25-2020, 08:43 AM
Quoted: 748 Post(s)
Liked: 398
best 2 way MTM I have had in my system is the Ascend Acoustics CMT 340C
I recently got the Infinity RC263C and it is the best center I have had in the system. its big. a steal at sale prices. and recommendable at list ( 499) unfortunately currently sold out.
as for alternatives, the Emotiva C1 or C2 are often recommended. I can't recall a negative review.
So putting brands aside, I would recommend a 3 way speaker over a 2 way, and a "Nested" tweeter configuration - tweeter is elevated over the woofer horizontal axis. also described as: W t/m W...
good luck.
also worth a mention, if for nothing else but looks, are the Tekton Design center based upon their 7 driver array...
also of note is ...the guy who does extensive measuring - totally blanking - a Revel center has preformed the best in his tests. so much so that he built his whole 7.x system based upon that...
good luck
Main: Sony XBR75900E, Denon AVR-x4400, Denon POA-5200 (L/R(a) Goldenear supersat 60, (b)FW Boston acoustic Bravo 2. C Ascend Acoustics Duo,
SSR DIYSG Volt 6v2. RSS Volt 6, Atmos(.4) Boston acoustics soundware
HSU research ULS -15, Episode ES-IW-Dual 8 / Monitor audio IWA 250 amp 2nd Rm: Visio E55, Denon avr730H, Boston Acoustics CR8, cr400 sub.
smithsabom is offline
post #24 of 133 Old 06-25-2020, 08:49 AM
Zorba922's Avatar
Liked: 7474
Missed that one. Just looked it up, $975...ouch!
I guess KEF is not the only ridiculous price-gouger with 3 way centers, lol.
Zorba922 is offline
post #25 of 133 Old 06-25-2020, 09:14 AM
Ryan Statz's Avatar
Liked: 1183
It still would have been way less than the R2c - which is one reason why it was under consideration. Without any info on the sound signature/performance, I wasn't willing to take that chance. I probably wouldn't have even batted an eyelash if it was 1/3 the price, though.
With the KEFs, I at least had a pretty decent idea on their sound, especially in my space, so it was less of a gamble.
post #26 of 133 Old 06-25-2020, 09:27 AM
Quoted: 12 Post(s)
Liked: 1
A couple other 3 way centers are the SVS Prime and the Aperion Novus. The feedback for SVS Prime is a little hot and cold, so I’m not sure what to think about that option. The reviews I’ve seen of the Aperion Novus center have been pretty strong, but I haven’t seen any real user comments.
DblDeuces222 is offline
post #27 of 133 Old 06-25-2020, 01:28 PM - Thread Starter
Quoted: 37 Post(s)
Liked: 1
I just set my PS3 to Dolby Audio, the receiver recognized It but sadly no noticeable improvement for me.
Also, I think I might have messed up by posting here as I am from North Europe, so the center I need has to be purchasable from there. I tried posting in AVforums but they seemed very insistent on a phantom center, which to me did not really solve the problem.
Plasmi is offline
post #28 of 133 Old 06-25-2020, 02:42 PM
Zorba922's Avatar
Liked: 7474
Just look for a 3 way center then, that will greatly improve your chances.
If you're able to get delivery from Amazon.de this is a good bet:
https://www.amazon.de/Canton-GLE-455...6V6/ref=sr_1_3
cocrh likes this.
Zorba922 is offline
post #29 of 133 Old 06-25-2020, 03:42 PM
Quoted: 628 Post(s)
Liked: 562
As Zorba mentioned 3 way is the way to go.
Another Canton 3 way with a bit better tweeter but more money of course.
https://www.amazon.de/Canton-03594-C...s=ce-de&sr=1-1
Zorba922 likes this.
cocrh is online now
post #30 of 133 Old 06-25-2020, 04:52 PM
Ryan Statz's Avatar
Liked: 1183
It might, though. Try it, and also try just moving your centre forward on that table you have it on in the photos. That'll cost you $0.
Reply Speakers
center , dialogue
