Help on surround speakers for B&W 700s - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 06-29-2020, 06:39 PM - Thread Starter
Liked: 2
I appreciate your recommendations on what surround speakers to buy, this is my current setup:
Left+Right: B&W 702S2
Central: B&W HTM71 S2
Sub: B&W DB4S
Diego Latorre is offline
post #2 of 7 Old 06-29-2020, 07:01 PM
Quoted: 2103 Post(s)
Liked: 1724
Maybe try some Micca’s or something with a whacky frequency response to match them?
Low end Monitor Audio?
Of course best case scenario would be 705’s but I’m guessing the reason you’re asking is because they’re too pricy for surround duty?
Leave it at 8 ohms and call it a day :)
Russdawg1 is online now
post #3 of 7 Old 06-29-2020, 08:50 PM
Quoted: 1318 Post(s)
Liked: 1170
That's pretty condescending.
OP, if you tell us your budget, room dimensions, budget, setup restrictions, budget, pictures, budget, etc we will be able to help you better.
Basement 5.1.4: Anthem MRX 720, Monoprice 2-channel amp, Paradigm Prestige 85F/55C/15B. PSB Alpha A1/P3 for Atmos HSU STF-2, ATV4K, XBox OneS, Harmony Ultimate, Samsung 65" Q7D.
Living room: Yamaha YSP-6000 with 10" Yamaha sub, ATV3, Harmony Ultimate, 55" Insignia 1080P.
sigpig is offline
post #4 of 7 Old 06-29-2020, 09:13 PM
Liked: 1724
He could try Wilson Audio’s, but again, no idea what the OP wants so why not throw a bunch of brands out at different price points?
post #5 of 7 Old 06-29-2020, 09:57 PM
markmon1's Avatar
Quoted: 6846 Post(s)
Liked: 4968
Sub: B&W DB4S
I think 705S2 or 706S2 would both be equally fine in your situation for surround speakers and be really a perfect match. The main difference with 705S2 vs 706S2 is the decouped tweeter which helps on sound staging but for rear speakers I don't think this matters so much. So I'd probably go with 706S2. A compromise would be 707S2. I have 4 706S2's in my room mounted up high for Atmos speakers.
JVC Control - my software for controlling JVC projector via IP control.
Smart Masking - See my automatic smart screen masking system.
JVC IR Codes - free online pronto code converter for JVC IR codes.
markmon1 is offline
post #6 of 7 Old 06-29-2020, 10:34 PM
Quoted: 114 Post(s)
Liked: 48
I'd grab a couple of 707S2, as they are just rear surround speakers and are the cheapest 700 series.
I plan on using my gloss black M1's as height speakers in a 5.1.4 system.
Denon X3200W
Bower & Wilkins HTM72 Centre, M1 & PV1 Sub
Samsung 2014 75 inch and Samsung 2018 NU8000 82 inch 4K
QED Speaker Cables and HDMI
Bryn23 is offline
post #7 of 7 Old 06-30-2020, 01:27 PM
Liked: 0
I recommend 707s2. I test A/B switch 706s2 and 707s2 small difference, without sub there its little bit more body 706s2, but with sub and 80hz crossover, difference its even less.
Staafe100 is online now
Reply Speakers
