Garage Speakers suggestion - AVS Forum | Home Theater Discussions And Reviews
 3Likes
  • 1 Post By _tk
  • 2 Post By MRAYB
post #1 of 10 Old 06-29-2020, 07:00 PM - Thread Starter
Liked: 2
I'm thinking in adding a pair of speakers on my Garages as Zone 3. Any suggestions? Should they be outdoor rated? the Garage gets really hot during summer in West Texas.
Diego Latorre is offline
post #2 of 10 Old 06-29-2020, 09:50 PM
DJ_JonnyV's Avatar
Quoted: 58 Post(s)
Liked: 48
I don't think you necessarily need outdoor speakers if within a garage environment. There was just recently a similar post to this about garage speakers. I'm i St. Louis where we get plenty of heat and humidity and have been running some in-wall 5.1 (except the .1) speakers for the past 10+ years without any issues. I went in-wall in order to keep them out of the way and no issue of knocking speakers off of mounts, walls, etc. Don't overthink it. You're not in a critical listening environment.
DJ_JonnyV
DJ_JonnyV is offline
post #3 of 10 Old 06-29-2020, 10:04 PM
Zorba922's Avatar
Quoted: 9656 Post(s)
Liked: 7471
These are worth a shot, what with the free return shipping:
https://rslspeakers.com/products/rsl-outsider-ii/
~ Are you a "geek hobbyist" obsessed with squeezing out that last 5-10% improvement? The economy will thank you...especially the Chinese one. Or are you more of a get-set-and-forget "casual user" who simply wants to increase your enjoyment of movies, TV and gaming? Relax, HT isn't rocket science, nor does it have to cost an arm and a leg---especially if you ignore the aforementioned vocal minority. And remember to smile...it's just a silly hobby, after all. :)
Zorba922 is offline
post #4 of 10 Old 06-30-2020, 08:55 AM
Quoted: 748 Post(s)
Liked: 398
While you don't state budget, there are some other questions to ask.
what do you do in the Garage? Workshop? hang out area for the guys? what music profile do you prefer? what type of listening?
what will you use to be driving zone 3? onboard amps/speaker terminals or pre-outs to an outboard amp?
Generally speaking, and as previously mentioned, you don't need to spend a lot. - find some used speakers and be done - craigslist, goodwill, thrift store,etc.
also considering placement and what you do in the space as well, i.e. do you make a lot of dust? can impact your decision process.
typical indoor/outdoor - type speakers with an integrated bracket could do you very well and many can be found for less than 100/pr. ( parts-express.com or outdoorspeakerdepot.com) just make sure you get ones with at least a 5" woofer.
if you need durable, but potentially powerful, and mountable - check out the stage right PA speakers at monoprice -both passive and powered versions
good luck, rock on
Main: Sony XBR75900E, Denon AVR-x4400, Denon POA-5200 (L/R(a) Goldenear supersat 60, (b)FW Boston acoustic Bravo 2. C Ascend Acoustics Duo,
SSR DIYSG Volt 6v2. RSS Volt 6, Atmos(.4) Boston acoustics soundware
HSU research ULS -15, Episode ES-IW-Dual 8 / Monitor audio IWA 250 amp 2nd Rm: Visio E55, Denon avr730H, Boston Acoustics CR8, cr400 sub.
smithsabom is offline
post #5 of 10 Old 06-30-2020, 09:03 AM
smbsocal's Avatar
Quoted: 90 Post(s)
Liked: 93
You could always look for a inexpensive pair of speakers on Craiglist, etc.
I am in NC which is very hot and humid in the summer. I just use a pair of 32 year old 3-way floor standing Mitsubishi speakers that I got when I was a kid. They may not have the clarity of some of the newer speakers but for the garage ( and yard when loud) they are more than enough. I have definitely gotten my moneys worth on these and then some.
If I was going for something new I would go with the JBL AWCs with a old sub.
smbsocal is offline
post #6 of 10 Old 07-01-2020, 06:35 PM
_tk
Quoted: 808 Post(s)
Liked: 405
Yeah, we just had this thread. My recommendation was the parts express Dayton B652's. Cheap, no port for critters to get into, non-paper cone woofer and don't sound half bad.
They also have a tab on the back so you can hang on the wall.
MRAYB likes this.
_tk is offline
post #7 of 10 Old 07-01-2020, 10:21 PM
head_unit's Avatar
Quoted: 784 Post(s)
Liked: 422
Then you need something with a "cool" sound
If they are IN the garage and I assume this is not huge money, get normal speakers. But you need to tell us how the size you can fit and how big the $$$
head_unit is offline
post #8 of 10 Old 07-02-2020, 12:27 AM
MRAYB's Avatar
Quoted: 549 Post(s)
Liked: 2307
I second the recommendation for the Dayton Audio B652 AIR speakers. Really a great value for what they are. I run four of them on my screened in patio with an older Sony Craigslist receiver. Same kind of setup my garage, Sony from Craigslist, an old JBL HTIB sub and two Dayton AIR's. They are currently out of stock til the end of July. https://www.parts-express.com/dayton-audio-b652-air-6-1-2-2-way-bookshelf-speaker-with-amt-tweeter-pair--300-651,
their links never seem to work here.
ID:	2751880   Click image for larger version
ID:	2751882   Click image for larger version
wassup and Zorba922 like this.
MRAYB is offline
post #9 of 10 Old 07-02-2020, 06:55 AM
Quoted: 122 Post(s)
Liked: 53
those Dayton Air look nice ... what a price¡!
I would try the Monoprice powered 15 inchers ... set the up to stream and you are totally set ...
some guys use room correction on these and they are supposed to sound very good
wassup is offline
post #10 of 10 Old 07-02-2020, 11:55 AM
_tk
Quoted: 808 Post(s)
Liked: 405
Don't even need the AIR versions for such an environment. The normal ones will do just fine for $36:
https://www.parts-express.com/dayton...-pair--300-652
Out until end of July though. I've never seen those things out of stock.
_tk is offline
Reply Speakers
