COnnect Front High and Front Mains Together - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 06-30-2020, 11:31 AM - Thread Starter
jjcdennis's Avatar
I have a Marantz SR7013 receiver in an 5.1.4 setup. The Front High speakers became redundant in this setup. My question is, is there an issue with connecting the front high speakers to the front mains via the speaker posts. Then run Odessey. Serial or parallel connection?
What I have is Polk Audio Monitor 70's on the floor and RC85i's as the Front High.
Appreciate your help with this question.
jjcdennis is offline
post #2 of 5 Old 06-30-2020, 02:15 PM
RayGuy's Avatar
Quoted: 3580 Post(s)
Liked: 3397
Not a good idea. However, if you are set on doing it, get yourself an impedance protected speaker switch to connect both sets of speakers. Something like this with separate volume control (since the odds of the speakers having perfectly even response are slim).
https://www.amazon.com/Monoprice-108...-9&tag=mh0b-20
It's a VIRTUAL channel unless stated otherwise.
RayGuy is offline
post #3 of 5 Old 06-30-2020, 07:28 PM
afrogt's Avatar
Quoted: 2526 Post(s)
Liked: 1653
Redundant because of why? Are the front high speakers set up as Atmos speakers? I see no logical reason to connect them to the front mains. What is that supposed to gain you? It certainly doesn't help you with the Atmos experience.
Afro GT
afrogt is online now
post #4 of 5 Old 07-01-2020, 06:19 AM - Thread Starter
jjcdennis's Avatar
Thanks for your note.
I have a Niles SVL-6 that I used in my last home to power multiple zones with an Onkyo TX-NR3008.
My thinking was, the speakers are there, why not try to use them to fill the sound field a bit. Re: Atmos, I have listened with Atmos versus other sound fields and really I don't hear much of a difference, if any. Every sound field makes use of the 11 speakers and that makes it difficult for me differentiate. The DTS sound fields are much more distinct to me..
post #5 of 5 Old 07-01-2020, 11:27 AM
RayGuy's Avatar
Liked: 3397
To properly use your 11 speakers, you really need to invest in a receiver that can process all 11 channels. That said, rules are made to be broken, so go for it and see what you get.
RayGuy is offline
Reply Speakers
