Paradigm Owners Thread - Page 1147 - AVS Forum | Home Theater Discussions And Reviews
 5985Likes
post #34381 of 38569 Old 03-18-2017, 05:29 PM
519audiofan's Avatar
Quoted: 46 Post(s)
Liked: 84
Originally Posted by Arnold van Opstal View Post
Really important question here guys
I have the choice between the signature s8s and the Persona 3h
The price difference doesnt matter to me, is the Persona significantly better?
It's not even close. Go for the 3Fs.
It took me a week to begin enjoying my S6s again after hearing the 7Fs.
I'll be upgrading at some point.
Sent from my Nexus 6 using Tapatalk
Scarriere likes this.
519audiofan is offline
post #34382 of 38569 Old 03-20-2017, 03:07 AM
Kevin. W's Avatar
Quoted: 250 Post(s)
Liked: 117
Currently have Studio 100v3/CC690 combo up front. Looking for a change and was thinking of going with Klipsch. In perticular the RP-280 and RP-450. How would the Klipsch compare.
Kevin. W is offline
post #34383 of 38569 Old 03-20-2017, 03:48 AM
KenM10759's Avatar
Quoted: 3665 Post(s)
Liked: 2112
You may discover a much wider but less defined soundstage. That was my take when I heard them against Paradigm Prestige 75F (and KEF R700) with their mating center speakers.
A lot more bass came out of the Klipsch, but far less defined. That was the most notable characteristic, but I really didn't care for how the Klipsch soundstage had no depth to it and imaging of the performance was muddled compared to the precise presentation offered by the other two. With a a well integrated subwoofer all did a good job with bass in movies.
KEF R500, R200C, R100, R50, SVS SB2000 sub, NAD T758v3 AVR, LG UP875 4K BlueRay, Samsung UN55JU6500F 4K LED TV, Sony CDP-CE500 CD changer. Office: NAD M10, KEF LS50, KEF Kube 10b, E.A.T. C-Major TT w/Ortofon Quintet Blue cart. Guest room: Adiosource AMP 1/A, Bluesound Vault 2, KEF iQ 10 pair.
KenM10759 is offline
post #34384 of 38569 Old 03-20-2017, 03:58 AM
Quoted: 1958 Post(s)
Liked: 1137
Klipsch is a totally different sound, more in your face with more bass. Its horn has more limited dispersion which hurts its sound stage and can be more difficult to place. It will depend on how your room is to see how it interacts with your room. Although the Klipsch specs has some exaggeration with its sensitivity rating it is still more sensitive than the Paradigm and will be easier to drive and play louder than the Paradigm.
The only way to really know is demo it in your room and make sure you level match them and set a crossover if you use a sub. Comparing with no crossover the added bass of the Klipsch will make you gravitate towards it and if you don't use a sub it is a consideration. Personally, I would like the Paradigm better but YMMV.
Ellebob is offline
post #34385 of 38569 Old 03-20-2017, 05:38 AM
Quoted: 383 Post(s)
Liked: 135
Originally Posted by thousandaire View Post
Does anyone here have vintage (20-25 year old) Paradigm Phantom, Titan, or Atom bookshelf speakers? These were Paradigm's entry-level speakers from around 1990. I have some I bought around 1992 to use with Denon 2 channel receivers (which still work). The speakers sold for about &80 to $150 each new.
I've got 2 pairs of Atom v2. They have the rounded plastic back instead of the flat wood panel.
I've had to replace the surrounds on my center and sub from ~1999. Need to visually check the Atoms. They sound OK though.
I'm considering replacing the capacitors in the crossover as I've read that cheap capacitors can degrade and the capacitance changes which will change the crossover properties. Also there is the possibility of replacing the entire crossover as generic versions can be bought for low prices like $30.
You may not like the generic crossover. Changing the caps may help. Use a decent quality cap.
ST Dog is offline
post #34386 of 38569 Old 03-20-2017, 06:30 AM
Tapidlittle's Avatar
Quoted: 105 Post(s)
I have a 5.1 setup in a 15x11 room. I want to put ceiling speakers for Atmos.
I already own:
- Studio 20 v.5
- CC-490 v.5
- ADP-590 v.5
I will be sitting 4-5 feet away from the back wall so I was wondering if I should go with 2 or 4 ceiling speakers for Atmos?
I was looking at the Pro P65-R, would it be a good match with my Studios? What about the Home series?
thanks.
Tapidlittle is offline
post #34387 of 38569 Old 03-20-2017, 07:45 AM
Liked: 1137
4 is definitely better and depending on the height of your ceilings and placement, Paradigm's angled speakers might be a better option. The Pro is probably a closer match than the home but neither is from the same series or an ideal match. If the angled speakers work better for your situation and price is a concern I would look at the home H65-A angled speaker instead of going to the Pro non-angled version.
Speakers sound better when they aim at you and angling of the speakers is in the Dolby Spec. While the spec states 35-45 degrees from the listener many speaker will not have good off axis much past 45 degrees. If you only care about one money seat than this might not be an issue to get all the speakers with good off axis. However to cover all the listeners in most homes that do not have 10' or taller ceilings, angled speakers tend to work better.
Ellebob is offline
post #34388 of 38569 Old 03-20-2017, 08:19 AM
Quoted: 105 Post(s)
Thanks, I have standard ceiling around 8 feet.
From what I read on Paradigm web's site is that all the HOME, PRO and ELITE in ceiling speakers (if you click on ATMOS speakers) are 30 degree angled guided soundfield.. is that what you are talking about?
post #34389 of 38569 Old 03-20-2017, 08:51 AM
Quoted: 105 Post(s)
Sorry I think your right the P65-R doesn't seem angled, the product sheet was for the whole Pro series, not only for this model.
post #34390 of 38569 Old 03-20-2017, 09:05 AM
Liked: 1137
I think Paradigm listed all their in ceiling models under Atmos. Any of them will work but it depends on the situation which will be a better choice for a given situation. The ones with -A at the end of the model number are the 30 degree angled guide field models and with 8 foot ceilings would be a better choice if you have more than one seat you care about.
Ellebob is offline
post #34391 of 38569 Old 03-20-2017, 11:30 AM
Quoted: 105 Post(s)
Thanks, and my room is large enough for 4 Atmos Speakers?
post #34392 of 38569 Old 03-20-2017, 11:55 AM
Liked: 1137
If your seating is 4-5 feet from the back wall then yes. You can get two behind and two in front of the seating.
Ellebob is offline
post #34393 of 38569 Old 03-20-2017, 01:32 PM
Quoted: 105 Post(s)
Thanks, you are saying that any Paradigm would not match perfectly my Studios, can I go with any brand of speakers? If so any suggestions? Paradigm are very expensive only to use them as Atmos speakers...
post #34394 of 38569 Old 03-20-2017, 03:57 PM
Liked: 1137
I'm not sure about any brand as very few offer 30 degrees of angle, some offer 15 degrees. Paradigm is probably the least expensive for models that angle 30 degrees or more. The Studios used to have matching in wall/ceiling models (SA Series) but they have been discontinued. They used to also have models that matched the Monitor series (AMS series) but have also been discontinued. Which makes me think the monitors are due for an upgrade especially since the CI Pro series doesn't really have a match. The CI Elite are matched to the new Prestige line.
Ellebob is offline
post #34395 of 38569 Old 03-20-2017, 04:01 PM
Kevin. W's Avatar
Quoted: 250 Post(s)
Liked: 117
I already own:
- Studio 20 v.5
- CC-490 v.5
- ADP-590 v.5
thanks.
I just added some Klipsch RP-140sa Atmos Modules to the tops of my Studio 100's. Time to test them out
Kevin. W is offline
post #34396 of 38569 Old 03-20-2017, 04:07 PM
Liked: 1137
Ps. If you can find the SA-15R-30 that would be the angled match for your speakers. Maybe you can find them on closeout, they had an MSPR of $670 each and the non-angled SA-15R had an MSRP of $525 each.
Ellebob is offline
post #34397 of 38569 Old 03-20-2017, 04:19 PM
hdtv00's Avatar
Quoted: 296 Post(s)
Liked: 161
Originally Posted by IanB2 View Post
My receiver is a Pioneer Elite SC55 @ 140wx9, so power shouldn't be an issue.
sure you do. Receiver industry great fake spec sheet haha.
Seriously though the person who said not to get the 290 and get the cc 350 -370 is dead right. Although prefer v2 or 3 over 1. That's the real way to go.
Marantz 7702MKII/Outlaw 7140 65" 4k LG C9
i7 4770K/16 gig 2133/970's SLI 840 PRO SSD
Paradigm Studio v3 100/570/20's/470's/2200 Sub
hdtv00 is offline
post #34398 of 38569 Old 03-20-2017, 06:42 PM
Quoted: 105 Post(s)
Top of the Studio series is not flat... How you will seat the Klipsch on it?
post #34399 of 38569 Old 03-20-2017, 06:46 PM
Quoted: 105 Post(s)
Thanks...
The Studios have the G-Pal tweeter, like the SA-15R-30 you mentioned. I might go with the HOME series since I don't want to pay to much for Atmos speakers and they will probably do the job just fine. They won't be use for music.
post #34400 of 38569 Old 03-20-2017, 07:31 PM
Kevin. W's Avatar
Quoted: 250 Post(s)
Liked: 117
The modules sit just fine. Checkout the picture.
Kadath and Scarriere like this.
Kevin. W is offline
post #34401 of 38569 Old 03-21-2017, 05:04 AM
Quoted: 105 Post(s)
Great, let us know if it makes a good difference, I prefer having speakers in-ceiling but it's harder to install.
post #34402 of 38569 Old 03-21-2017, 05:15 AM
Quoted: 105 Post(s)
Any reviews of the H65-A ? I can't find any reviews of these in-ceiling speakers.
post #34403 of 38569 Old 03-21-2017, 08:11 AM
Kadath's Avatar
Quoted: 599 Post(s)
Liked: 354
Interesting, I'd considered that myself but worried about rattling. I'd consider placing a thin rubber layer between the two still.
Buncha savages in this town.... - Clerks
Sam Posten
Kadath is offline
post #34404 of 38569 Old 03-21-2017, 08:49 AM
frontside720's Avatar
Quoted: 78 Post(s)
Liked: 34
Had a delivery this morning. I guess I can officially start posting in this thread.
Can't wait to have these installed in my theatre. It's going to be a long day at the office.
frontside720 is offline
post #34405 of 38569 Old 03-21-2017, 09:07 AM
JKR1963's Avatar
Quoted: 352 Post(s)
Liked: 158
I already own:
- Studio 20 v.5
- CC-490 v.5
- ADP-590 v.5
thanks.
If you can find these at your local Worst Buy........they are killer, and a perfect tonal match for your studio speakers.
http://www.bestbuy.ca/en-ca/product/.../10087413.aspx?
I am using four of these with Studio 100v.5/ cc690v.5 and four Energy RC-70's on the rears.........the Energy and Paradigm match tonally almost perfectly.
I would go with four ceilings if you can......sounds better. Once you have four in your ceiling, you can try switching two off and you will see that four is much better.
JKR1963 is online now
post #34406 of 38569 Old 03-21-2017, 09:29 AM
Quoted: 105 Post(s)
I have been told to install angled speakers on my ceiling since I have a 8' ceiling. Dolby also recommend angled speakers. Thanks for the link.
post #34407 of 38569 Old 03-21-2017, 05:31 PM
BigDaveE's Avatar
Question
My OCD is kicking in... Why is one box gray and the rest red / pink?
BigDaveE is offline
post #34408 of 38569 Old 03-21-2017, 06:30 PM
ginovino's Avatar
Quoted: 13 Post(s)
Gentlemen..... i have in my possession the following "absolutely mint "ONE Owner "SETS" of the following Paradigm units from late 97's, in pairs :
ATOMS V-3 -2PAIRS (4 SPKRS)... WHITE
1pr. MINI MONITORS V-5... BLACK
1pr. TITAN MONITORS V-5 BLACK
1pr CC-290 V-5 CENTER CHNL (OR STEREO)...BLACK
I was a partner in an Audio salon in New York (Long Island) and among the largest purveyors of the entire PARADIGM line... I took these home in the interest of setting up a small theater room in my lower level and share the space with my High End Sound system, You can see in my posts,, the Bryston 7bsst^ pr, Thiel 3.7's, Bryston Pre, [email protected] Sansui Tuners - T-1 & T-919, (Tu-9900 just sold), VPI-TNT w/ Shirly's favorite arm, Grado master. etc.....Kimber KS for everything.. The Theater idea ended quickly as the wife wanted a reading-study room... Everything was re-crated original packing, foam, booklets... and then, she wanted to move to COLORDO---WHICH IS WHERE WE LIVE NOW !!!.... I will assure any person whom may have questions about the v-3 & v-5 series
to post me a quickie.... I go back on this forum since almost its beginning. While we didn't always agree on a number of subjects, "Grumpy" and I go back to the early 90's.....
I will entertain questions.... though, not use Grumpy"s well earned forum for free billboard promotion. Drop me a note with your email or pvt, cell and we will see where it goes.. My apologies in advance if I may have overstepped the new( if any) rules on promoting "commerce" without clarifying such caveats.
ginovino is offline
post #34409 of 38569 Old 03-21-2017, 08:56 PM
Quoted: 78 Post(s)
Liked: 34
Hahahaha I actually turned it around and took a proper picture when I noticed the same.
One side of the box is grey the other is pink. haha
post #34410 of 38569 Old 03-21-2017, 09:35 PM
BigDaveE's Avatar
Ahhhh. Now I can sleep again.
Interested to hear your thoughts. I'm debating between the same setup you just got vs Monitor Audio Gold 300's.
The Gold's are more $ and I'm wondering if it's worth it.
Also curious what color you got. I'm interested in the walnut but it looked a little orange to me at the place I demoed them....
BigDaveE is offline
Reply Speakers
Paradigm , Speaker Systems
